eaglescout526
Administrators
    13
  1. Cruise control and the vents for the HVAC settings.
  2. Thanks fiat. I responded late last night and didnt feel like going and getting one of the lenses to get a pic haha.
  3. On the lens of the OEM style, there’s a protruding object on the underside of the lens that has a metal ring on it. When moved up or down it should engage the light in either permanent on or switched on by the door switches(which probably needs to be cleaned too)
  4. Went to the cruise in. Little while later this gem showed up and had to park next to it
  5. Supposedly the 2.5L carb had this as an option of the sorts according to the parts catalog.
  6. Pretty much. Not having much luck finding anything out there, even other vehicles. It looks pretty much like the channel/belt/guide/weatherstrip for the window that goes up and down. But just a 1/4” shorter in height putting the two together with the side that goes into the divider bar flat on the floor
  7. So it looks like this piece here that looks like the regular belt guides for the front and rear Old one is a bit smaller in terms of height and fitting in the divider bar. As seen here I replaced the one on the passenger side and it looks goofy having one of the other regular belts in it’s place Currently working with a glass shop to see if they might be able to locate something as a replacement but apparently Chrysler and AMC(probably but I have my doubts)serviced both the glass and belt together despite being separable and not in a traditional frame.
  8. And you most likely won’t. OEM would be made be Siemens if you can find one of those. Or if you have a vintage parts log in
  9. Is it still a hush hush thing? That’s good I guess. Since I work in parts at a dealer I am able to look at part numbers and see what’s out there. And that’s how I’ve been able to run the VINs too
  10. If I recall, .2VAC is the absolute bare minimum that a Renix engine will run with. But even aftermarket will run at that bare minimum out of the box. There’s still some OEM ones left. If they didn’t cost me a hand I’d order all that’s left and get them out and into hands of folks who need them.
  11. No. It should look like the pin next to it.
  12. I mean to each company is their own way. I can see it being a benefit as the fuel would have better atomization in the chamber if there was no coolant running through it to keep it the same temp as the engine, but it is also aluminum. I feel that the winter it wouldnt struggle that much as long as you have the preheater tube set up and it would help there but other wise winter wouldnt be much different even if coolant was flowing through it.
  13. I’ll take the fronts please haha. That’s a commanding price for a full set that’s not new.
  14. I mean the fuel will probably evaporate too fast from the heated manifold that’s not as cool as the engine but you can give it a shot as I have never heard of anyone doin this to a Renix set up.
  15. Fantastic. If I recall they should be just standard bullet connectors that was used for a long while.
  16. That could be a warranty button. My heads on my MJ and T/A have buttons like that that says “warranty do not remove”. That could just be an older one. And that may not be an HO block with the AMC numbers being there.
  17. I’ll snap a pic when I get home.
  18. I’m glad there is a good amount of interest. I will promptly start working on the proto as soon as I can.
  19. I second this. If you’re not careful with edges and what not the paint will scrape but otherwise it is a great product.
  20. Thanks. I haven’t had a chance to make a prototype harness yet. One of my room mates just moved out over the weekend and thus was helping him pack and prep. I will try to get one in the works shortly.
  21. *D4 TRIM STYLE D4 - VINYL BENCH SEAT -SA CHARCOAL 167 Zone 67-Charlotte 1AA U.S. Dealer Retail 4XU ALA APA MONOTONE PAINT BAF 130 AMP ALTERNATOR BCY 475 AMP BATTERY BGA POWER FRONT DISC/REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKJ BLACK VINYL FLOOR COVERING CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION DMF 4.10 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EPE Engine - 2.5L Power Tech I-4 Cyl. GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HAA AIR CONDITIONING JAY DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER JGB JJA CIGAR LIGHTER K3Z STRIPE/BADGE/MOLDING/COLOR KDP STRIPE/BADGE/MOLDING COLOR KWA STRIPE/BADGE/MOLDING/COLOR LAP SHIFT INDICATOR WARNING LAMP LBC GLOVE BOX LAMP LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank NMC Heavy Duty Engine Cooling PX8 QX8 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires TZH Michelin Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z57 Left Front Spring Group Vii Z76 Right Front Spring Group VI Build date 9/25/90 Body code TL61 Sold by FOWLER MOTORS INC, CONWAY SC
  22. *B1 TRIM STYLE B1 - CLOTH & VNL BENCH SEAT -SA Charcoal 169 Zone 69-Phoenix 1AA U.S. Dealer Retail 4EA Sold Vehicle 5AL ADL SKID PLATE GROUP APA MONOTONE PAINT BAY 105 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA POWER FRONT DISC/REAR DRUM BRAKES BJA STD DUTY FRT DISC BRAKES BKP 10X2.5 REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKJ BLACK VINYL FLOOR COVERING CSR PASSENGER ASSIST HANDLES CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION DHN COMMAND-TRAC PART TIME 4WD SYSTEM DJH 230MM FRONT AXLE DMM 3.07 REAR AXLE RATIO DRK DANA 44/226MM REAR AXLE DSA ANTI-SPIN DIFFERENTIAL REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GFD REAR SLIDING WINDOW GNA REAR VIEW DAY/NIGHT MIRROR GRV LEFT MANUAL MIRROR GUA OPEN HAA AIR CONDITIONING JAA INSTRUMENT PANEL JAY DO NOT USE - SEE JP, KA CLASSES JBF INSTRUMENT PANEL BLACK BEZEL JCA 85 MPH PRIMARY SPEEDOMETER JGB JKB K3Z STRIPE/BADGE/MOLDING/COLOR KWX LAF SEAT BELT ALERT-DRIVER SEAT ONLY LAP SHIFT INDICATOR WARNING LAMP LBC GLOVE BOX LAMP LCJ DOME/READING LAMP B-PILLAR LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MBJ BLACK BUMPER MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PWB QWB RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA Audio SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAE TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 4/30/89 Body code JL62 Sold by JIM MARSH JEEP-EAGLE, LAS VEGAS NV
  23. *X3 -SA Charcoal AGC APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PYC QYC SBA POWER STEERING TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 10/8/87 Body code TL61 Sold by GOWEN CHRYSLER PLYMOUTH JEEP EAGLE, CHARLOTTE NC
