13
*X1 -SA Charcoal 3LW ADL PACKAGE - 4X4 PROTECTION AGJ Driver Assistance Group AGP APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT DDQ Transmission - 5-Speed Manual DTA ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL PWB QWB RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJN 15" ALUMINUM WHEELS Z5B GVW/PAYLOAD RATING Build date 7/19/88 Body code JM62 Sold by RENTON JEEP-EAGLE, RENTON WA
*A6 Seats - Vinyl High Back Bucket -H9 3LU AGJ Driver Assistance Group APB TWO TONE PAINT PACKAGE - I APC TWO TONE PAINT PACKAGE - II CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS A881 (JA-41) ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBF REAR BUMPER - STEP TYPE (BRIGHT) MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL PA2 SILVER MET CLEAR CT PRIMARY PAINT - FA2 QYC RAC RADIO - AM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 5/21/87 Body code TM62 Sold by HOMETOWN JEEP-EAGLE, CHILLICOTHE OH
The retainers that sit in the front fascia are GM grill retainers that can be found easily and cheap.
Chunk, A 1984 XJ
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Well while I waited for my wife to nap I decided it was time to do a little addition. Added the Renix 2.5L bottle and 86 specific air cleaner. Doing the bottle was a cake walk compared to the cleaner bracket. Getting the cleaner positioned with the bracket and marking one hole to drill and get a screw in for precise fitment. But I’m happy with where they sit. Currently my issue is the power steering lines and where they meet the preheater hose but i don't know if I am gonna use such yet or not. Currently my main focus is to put the front portion of the interior together ever so delicately. -
Renix Era 2.5 Flywheel
eaglescout526 replied to Zenobian_84's topic in MJ Tech: Modification and Repairs
No problem! -
I’d give the flywheel a light sanding with 1000 grit and don't press hard while sanding, just let it lightly do the work and it should come out looking good. I’d put out a want ad for these flywheels but it’s also not a clean job to get to either. -
Not likely any out there who make this flywheel. You might have to find a used one and at the rate people just toss the 2.5L for the 4.0, there’s a good chance that a second hand flywheel is in great shape still. I lightly sanded mine with 1000grit and it came out fine. What you really need to look for is if the clutch discs worn down the metal on the fly wheel or not to a noticeable point. -
Yes it is supposed to do this. If you press the set button and set it and say you need to drop to a lower speed, you hold the button until you get to the desired speed and it will set. But if you wan to set a new acceleration, use the switch and then press the button and it should set too. But still a neat function.
Has anyone replaced the rear stationary glass channel on the rear door of an XJ with something close to the original? Or have any recommendations?
Different t-cases. One is selec-trac which is always in 4wd operation by the small lever on the console(not the shift handle) and the 207 is just like the 231 but less vacuum stuff.
I feel that. Sometimes I get those who have rekindled memories with an MJ in their life. I will say I did see some get excited to see an old Jeep truck at the most recent car show I attended. But otherwise I feel ya G.
56002684 56002731 ->4773305 56002732->4773306 I only see three hoses in the catalog per your vehicle. You’re not referring to the small one off the dryer are you?
According to the catalog, it is present. probably mostly on 86-87s. Knowing Chrysler they probably stopped the command-trac and said its probably excessive for just 4wd set ups. Well that being said, they didnt do such for selec-trac either for after 87. Pete, I think I have one to spare.
Still missing selec-trac?
I mean I can contribute some nameplates to the wall
Oracle LED tail lamp harness
eaglescout526 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
Really?! I didnt know that. I thought there was a one size bullet connector. -
Damn! Good call. I don't know why I didn’t think about that. -
I shouldve said, "speaking from experience?" haha all good, do appreciate the concern. I am gonna try to get the prototype harness started this weekend. -
Olympic Edition Window Sticker
eaglescout526 replied to boxyjeep's topic in MJ Tech: Modification and Repairs
I’ve seen the sticker and nameplate on all the model years except 86 for the sticker. -
Yes they are. Course I do like to give the benefit of the doubt to members on here with this type of connection. -
*D1 TRIM STYLE D1 - CLOTH BENCH -SA Charcoal 161 Zone 61-Atlanta 1AA U.S. Dealer Retail 5AL APA MONOTONE PAINT BAY 105 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA POWER FRONT DISC/REAR DRUM BRAKES BJA STD DUTY FRT DISC BRAKES BKP 10X2.5 REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKJ BLACK VINYL FLOOR COVERING CSR PASSENGER ASSIST HANDLES DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DGS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHA LOCK-UP TORQUE CONVERTER DHT SHIFT-ON-THE-FLY,P/TIME T/CASE DMD 3.55 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GNA REAR VIEW DAY/NIGHT MIRROR GRV LEFT MANUAL MIRROR GUA OPEN HAA AIR CONDITIONING JAA INSTRUMENT PANEL JAZ DO NOT USE - SEE JP, KA CLASSES JBF INSTRUMENT PANEL BLACK BEZEL JCA 85 MPH PRIMARY SPEEDOMETER JKB K3Z STRIPE/BADGE/MOLDING/COLOR KWX LAF SEAT BELT ALERT-DRIVER SEAT ONLY LBC GLOVE BOX LAMP LCJ DOME/READING LAMP B-PILLAR LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MFF Black Grille MHB Bright Windshield Moldings MMC MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA Audio SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z79 Right Front Spring Group IX Build date 10/30/88 Body code TL62 Sold by AKINS JEEP-EAGLE, ATHENS GA
Hahahaha you SOB. -
Would be a nice sticker to have reproduced. I’d put it on both my Jeeps.
