eaglescout526
Administrators
    13
  1. I could provide the OEM numbers if that’ll help.
  2. I have one. My XJ came with this option and the PO swapped the lighter and light in place.
  3. If you’re trying to adjust your ISA (idle speed actuator), what you need to do is unplug it on a warm engine, plug in a tach or use your in dash tach if applicable and start the engine. The engine should be running about 3k rpm. If not the screw needs to be adjusted to read 3k.
  4. My exact thoughts too Pete. I got used to it for a while but I figured since I knew where to get the switches and harness, I figured why the hell not add that tidbit. Now I need to see about adding other lamps to the rest of the head liner.
  5. Major progress! New FI harness is swapped in. Committed Jeep blaspheme some might say but i mated the hatch harness by cutting off the old connectors that I have no idea what they are, they look molex, and put on the proper connectors and here we are: And yes everything works with no issues what so ever. Gave my mail man anxiety when he saw what I was doing haha. But no fuses popped and all is good. Just the fuel gauge doesn’t read at all cause I haven’t swapped the sending unit yet. I might adapt the old connector to the new one just for the sake or knowing how much gas I have left. Also I upgraded the rear doors to have the door switch. Funny thing about this is the holes are there and plugged…but not threaded. Talk about wild. And of course I threaded the switches in and here we are: The lights come on! Luckily I snapped the drivers side before putting it switch to show that this is what they looked like I had no idea that this was an option back in the day but at this point, why not just buy a two door? But I digress, maybe if you have passengers, there’s no need for the lights to come on I suppose. Ehh another 84 oddity I will remember. Lots up next.
  6. That is correct. Both tanks are the same but the neck inside the tank the dumps the fuel in is longer and stops the nozzle at the fuel pump from putting more fuel in because it’s the full 16 gallons.
  7. Youre thinking the 18 Pete under the short beds. Mine had the 16 gallon and still used the three straps before converting to the 23 gallon tank. But that being said the 20 gallon tank code is more common to XJs and our tank code probably got replaced at some point after the MJ was phased out.
  8. Well 86 “red” interior is weird. It looks like you have the mid garnet that is about to go to cordovan for 87. But you also have an early 86 which should be more garnet. It looks original to the MJ and probably is.
  9. Yeah some of them are wrong so take them with a grain of salt as Pete says. The axle ratios is what we seem to find to be commonly wrong with the build sheets. Except the D44, that seems to show up right.
  10. Yes. This info is unique to your VIN. I can’t pull these out of thin air like my co workers think with parts they can’t find haha.
  11. Exactly! Lots of stuff to do “while I’m there”.
  12. So I picked up some XJW goodies today. They are the windows with the chrome trim in the molding for the rear quarters and rear hatch. I still am undecided if I want to go full chrome or do a mix of both black and chrome. Oh I also grabbed an upgrade that struck me by surprise, Chunk doesnt have the switches for the rear doors to turn on the interior lights when the rear door opens, so I got both sides and their harness today. I think I am going to try to figure out how to get the rear latch to do the same at some point in the future as well. As I inch closer to putting the interior together, I find more things to do while I am in there. I am going to do the window sweeps next along with the channel guides closest to the fixed windows of each door. Hopefully thereafter or sooner, depending on when I get the 2.5L TBI harness, I can integrate the system sentry with the TBI harness rather than integrate it now since it goes through the same hole as the ECU harness into the firewall. I might start prepping the removal of the present engine management harness and toss it in the engine bay just so I have an XJ to move still.
  13. *Q7 CLOTH LOW-BACK BUCKET SEATS -SA Charcoal 133 Zone 33-Philadelphia 1AA U.S. Dealer Retail 26H Customer Preferred Package 26H 2TH Customer Preferred Package 2TH 3VU Customer Preferred Discount 4EA Sold Vehicle 4HA Special Scheduling Condition I 4M1 Retail to Bid Diversion Tracking ADA LIGHT GROUP ADH HEAVY DUTY ELECTRICAL GROUP ADL SKID PLATE GROUP APA MONOTONE PAINT ARM RADIO AM/FM CASSETTE AWE BAR 90 AMP ALTERNATOR BCD 550 AMP MAINTENANCE FREE BATTERY BGA POWER FRONT DISC/REAR DRUM BRAKES CAC LOW BACK BUCKET SEATS CDB RECLINING FRONT SEATS CKA CARPETS - FLOOR AND CARGO AREA CUF FULL LENGTH FLOOR CONSOLE DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DGS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHA LOCK-UP TORQUE CONVERTER DHN COMMAND-TRAC PART TIME 4WD SYSTEM DHS PUSH TO PASS DJH 230MM FRONT AXLE DMD 3.55 REAR AXLE RATIO DRJ DANA 35 REAR AXLE ERH 4.0L I6 POWER TECH ENGINE GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GFD REAR SLIDING WINDOW GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HCD DO NOT USE - SEE HCA JAY DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER K27 DO NOT USE K2B STRIPE/BADGE/MOLDING/COLOR K3D STRIPE/BADGE/MOLDING/COLOR KLT KWD LAJ HEADLAMPS ON WARNING CHIMES LBB COURTESY LAMPS LBC GLOVE BOX LAMP LBD ASH TRAY LAMP LBE AMBIENT LIGHT LDA UNDERHOOD LAMP LHD HEADLAMP OFF TIME DELAY LMA HALOGEN HEADLAMPS LNJ FRONT FOG LAMPS MB1 Black Front Bumper MBJ Black Bumper MCA MFK Body Color Grille MHA Black Windshield Moldings MMC MMG Belt Moldings MMK NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank NHB Auxiliary Transmission Oil Cooler NMC Heavy Duty Engine Cooling PS7 QS7 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFD Front Extra HD Shock Absorbers SGD Rear Extra HD Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box XEA Tow Hooks YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z83 Right Front Spring Group XII Build date 4/8/92 Body code JL61 Sold by SANDS CHRYSLER JEEP DODGE, QUAKERTOWN PA
  14. *ZZ -ZZ ADA LIGHT PACKAGE AJZ CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS ENA ENGINE - 2.1L TURBO DIESEL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL RAC RADIO - AM/MTR SBA POWER STEERING SUA TILT STEERING COLUMN WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 4/22/86 Body code TP62
  15. *ZZ -ZZ ADA LIGHT PACKAGE ADL SKID PLATE GROUP AGR AGY AJT RADIO PREP GROUP AJZ CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket MWB SPORT BAR NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 10/17/85 Body code JP62
  16. Power locks are working, found a sacrificial harness for the female metri 280 plug I needed. Got that settled in, plugged it and power into the block and the power locks work. They need some help and I’ll probably do a relay upgrade for them in the future to help them out but for now they work and will get lubed for even more help which is probably why these solenoids have such a hard time. Bonus, the power seats are working as they should! Woot! This is gonna be a fun luxurious XJ.
  17. First cross body harness is set up. Mirrors are working. Currently the locks are not and I believe that’s due to not having the metri 280 connectors at the moment to correct this issue.
  18. So I committed some slight blaspheme. I added the power seat switches to both seats and I think for being a completely different seat base than the power seats, I think I landed the install pretty good for both. I also got both passenger doors equipped with the locking solenoids and got the wiring harness for the rear door set up as well. Next will be to install the solenoid on the drivers side and start converting the rear harness to mate with the new body harness.
  19. Late 88 and on is normal to have a bunch of codes. The early 88 and down have little to nothing codes due to transfer of ownership and a flood in the basement where Chrysler stored records prior to digitizing all the documents.
  20. If you’re looking for a post, use our search function and find the advanced search options and have it search for title posts only.
  21. Nope. Renix era does not have this.
  22. That’s for cruise control. Its where the clutch switch would plug in but is more commonly found with automatics.
  23. No problem!
  24. Welcome!
  25. *B1 -SA Charcoal 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 4AF 5AL ADA LIGHT GROUP ADH HEAVY DUTY ELECTRICAL GROUP ADL SKID PLATE GROUP APA MONOTONE PAINT AWE BA1 100 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA POWER FRONT DISC/REAR DRUM BRAKES BJA STD DUTY FRT DISC BRAKES BKP 10X2.5 REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKA CARPETS - FLOOR AND CARGO AREA CSR PASSENGER ASSIST HANDLE CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDX 5-SPEED HD MANUAL TRANSMISSION DHN COMMAND-TRAC PART TIME 4WD SYSTEM DJH 230MM FRONT AXLE DMM 3.07 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEC FRONT LEFT SIDE SLIDING WINDOW GFD REAR SLIDING WINDOW GNA REAR VIEW DAY/NIGHT MIRROR GNB DRIVER SIDE ILLUMINATED SUN VISOR GRV LEFT MANUAL MIRROR GUA OPEN HCD DO NOT USE - SEE HCA JAA INSTRUMENT PANEL JAY DO NOT USE - SEE JP, KA CLASSES JBF INSTRUMENT PANEL BLACK BEZEL JCA 85 MPH PRIMARY SPEEDOMETER JGB JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDB STRIPE/BADGE/MOLDING LAF SEAT BELT ALERT-DRIVER SEAT ONLY LAJ HEADLAMPS ON WARNING CHIMES LAP SHIFT INDICATOR WARNING LAMP LBB COURTESY LAMPS LBC GLOVE BOX LAMP LBD ASH TRAY LAMP LBE AMBIENT LIGHT LCJ DOME/READING LAMP B-PILLAR LDH U/HOOD, REMOVABLE/RECHARGEABLE LAMP LHD HEADLAMP OFF TIME DELAY LMA HALOGEN HEADLAMPS LPE CARGO LAMP MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAE California Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank NMC Heavy Duty Engine Cooling PB3 QB3 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA Audio SBA Power Steering SCB Steering Whl SFD Front Extra HD Shock Absorbers SGD Rear Extra HD Shock Absorbers SUA Tilt Steering Column TAA All Tires TAE TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEA Tow Hooks XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z84 Right Front Spring Group XIII Build date 2/14/89 Body code JL61 Sold by PASADENA JEEP-EAGLE, PASADENA CA
