majastee508
1 Follower
723 profile views
majastee508's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. 1987 COMANCHE 4x4 Image, if available 4.0-AW4-231 dana 30 vacuum disconnect, and D44 Build date unknown Plymouth Ma Parts truck honey tan bucket seats with mini console, had D44 rear but non metric ton leafs. factory cargo bed light. truck had been partially tripped prior to me owning it. I finished the job Preview attachment Image.jpeg Image.jpeg 759 KB
  2. Was able to find a parts MJ with a Dana 44 rear hiding underneath. Picked up what was left of the truck this evening and will get this cleaned up before installing.
  3. Got a bit more work done but not finished with the bedside patches just yet. Waiting on the new key parts driver side rear lower latch panel to arrive. Was able to pick up a grey bench seat locally and got that installed with the mini console. Will be ordering a new carpet shortly. Also tinted the windows and finished off the suspension lift for now.
  4. lets see a photo of what your working with
  5. In order if my memory is correct. Have usually owned two at a time if not more. Currently 35 years old 1988 mustang gt (maroon) 1994 mustang cobra (white) 1998 xj (white) 1986 mustang gt (black) 1984 mustang lx (white) 1982 mustang gt (black) 1987 ford ranger (silver/blue) 1987 Toyota 4 runner (white) 1987 ford bronco (black) 1988 xj (white) 1992 xj (maroon) 1991 xj (white) 1988 yj (red) 1987 yj (red white and blue v8 swapped) 1987 xj 2 door (camo) 1992 xj (green) 1987 metric ton mj pioneer (black) 1985 Toyota Land Cruiser fj60 (black) 1992 mustang lx (black) 1993 mustang gt (reef blue) 1997 xj (green) 1989 mustang lx (blue and still own since 2008) 2001 f350 (black) 2001 xj limited (black) 2008 Escalade ext (white) 1988 mj pioneer (blue) 1997 xj 5 speed (green) 2020 gladiator rubicon (white and still own) 1994 cobra (white and still own) 1986 wagoneer (tan) 1987 grand wagoneer (maroon and still own) 1992 Comanche (still own and multi colored for now)
  6. Thanks Pete, couldn’t figure out how to rotate them so I let it fly
  7. Here it is with the 30”x9.50’s I picked it up with
  8. picked up a grey bench seat locally with good brackets and seat belts. It needed a good scrubbing but the chemical guy’s upholstery cleaner worked really well with minimal effort. Will scrub it down one more time before it goes in. Keeping my eye out for a grey mini console
  9. Picked up a 92 Eliminator 4x4 auto that has seen some much better days but pretty much fit the bill to let me build it as I wanted based on its current status. I was hoping to find something a bit cleaner to start with but I’m actually pretty happy with it so far. Goal is to build a capable little wheeler that I can take with some local clubs. Previous owner had started to swap the nose for the 97+ look which I wouldn’t have done but will likely leave for now. I also picked up a Tomken front bumper that I liked a lot. So far I’ve started with replacing the rotted Sheetmetal components consisting of rockers, rear wheel wells and drivers cab corner. Have a bit more sanding to do on the pass side and it will be finished. Drivers side still needs the lower rear panel patched(which I see Key Parts has just released 👍). Picked up a used set of 31” ko2’s but not sure the 3” RC lift will provide enough extra for my liking. Installed the front coils and shocks first and it really just leveled the truck out with the stock rear springs in place.
  10. I just picked up a bench seat locally to replace my factory buckets. The additional seat option really helps with taking my young kids out and about.
  11. Swapping from buckets with full length center console and want to find a mini console before starting the swap. Are the mini consoles interchangeable between auto and manual? Will the transmission shift indicator from the full length console work with the mini?
  12. Thank you
  13. there is a missing comma in my description unfortunately
  14. may be able to clear a 31x10.5 with the right offset wheels. however a 30x9.50 should clear without trouble
