13
I’ve got an old Kodak cinema 8 that I found at goodwill. I’ve seen older pop up and goodwill wants a small fortune for them. That being said I’ve got some floppy’s if you want some Pete.
86 2.5l 2wd restoration/work truck
eaglescout526 replied to strictlyxjs's topic in Member Projects: Your Comanches
Was this one made entirely out of metal? I think strictlys issue as is mine is that these companies get away with making a plastic upper and lower tank for an aluminum radiator all the while not attempting to look factory. -
Yes there’s quite a few local shops out here. Most are mom and pop and I think the other one that’s by sky harbor is 1-800 radiators and I think they either reman radiators or can make new again. -
The only radiator that I have seen that is exact factory is the crown one to my genuine surprise. I bought one on a slight gamble and I got the exact radiator that was made back in the day for the 2.5L. I am awaiting to put it in next weekend. -
Upgrading my “dummy light” gauge cluster??
eaglescout526 replied to Bomberjeep's topic in MJ Tech: Modification and Repairs
Oil-56026782AC Temp-53005309 -
*ZZ -ZZ ADB PROTECTION GROUP PACKAGE AJY Popular Equipment Package BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual DSA LIMITED SLIP DIFFERENTIAL EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LMA HALOGEN HEADLAMPS MCA FRONT BUMPER GUARDS MCB MD8 Delete Front License Plate Bracket MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY RAC RADIO - AM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN WJD WHEELS - 15 X 7.0 STYLED STEEL XEA TOW HOOKS Build date 12/6/85 Body code JM62
*ZZ -ZZ ADA LIGHT PACKAGE AGR AGY AJZ BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY RAB Radio - AM/FM SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN Build date 8/19/85 Body code JP62
*D4 -SA Charcoal 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 21A Customer Preferred Package 21A 2TA Customer Preferred Package 2TA 3VC Customer Preferred Discount ALA APA MONOTONE PAINT BAP 75 AMP ALTERNATOR BCC MAINT. FREE BATTERY BGA POWER FRONT DISC/REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKJ BLACK VINYL FLOOR COVERING CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DCK 4SPD MANUAL TRANS - AISIN SEIKI DMD 3.55 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EPE Engine - 2.5L Power Tech I-4 Cyl. GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GRV LEFT MANUAL MIRROR GUA OPEN HCD DO NOT USE - SEE HCA JAZ DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER K3Z STRIPE/BADGE/MOLDING/COLOR KWX EAGLE/SUMMIT DECALS BL LAP SHIFT INDICATOR WARNING LAMP LBC GLOVE BOX LAMP LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Solid Window MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAE California Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RA8 Delete Radio SAA Manual Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z75 Right Front Spring Group V Build date 8/5/91 Body code TL61 Sold by SEELEY EQUIPMENT CO., WALL TOWNSHIP NJ
*C1 -H9 166 Zone 66-Orlando 1AA U.S. Dealer Retail 26C Customer Preferred Package 26C 2TC Customer Preferred Package 2TC 3VN Customer Preferred Discount 4HA Special Scheduling Condition I 4M1 Retail to Bid Diversion Tracking 4UA SCA Tissue North America LLC ALA APA MONOTONE PAINT BAR 90 AMP ALTERNATOR BCD 550 AMP MAINTENANCE FREE BATTERY BGA POWER FRONT DISC/REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKA CARPETS - FLOOR AND CARGO AREA DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DGS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHA LOCK-UP TORQUE CONVERTER DHT DMD 3.55 REAR AXLE RATIO DRJ DANA 35 REAR AXLE ERH 4.0L I6 POWER TECH ENGINE GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEC FRONT LEFT SIDE SLIDING WINDOW GFD REAR SLIDING WINDOW GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HAA AIR CONDITIONING JAZ DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER K3Z STRIPE/BADGE/MOLDING/COLOR KER KWR STRIPE/BADGE/MOLDING/COLOR LBC GLOVE BOX LAMP LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MBJ Black Bumper MFF Black Grille MHA Black Windshield Moldings MMC Solid Window MMG Belt Moldings MMK NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PW7 Bright White Clear Coat QW7 Bright White Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires TZA Goodyear Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Build date 1/13/92 Body code TL62 Sold by STUART JEEP-EAGLE, STUART FL
*C1 -H9 174 Zone 74-Denver 1AA U.S. Dealer Retail 3V3 Customer Preferred Discount ADH HEAVY DUTY ELECTRICAL GROUP ADL SKID PLATE GROUP ALN BODY COLOR BUMPER GROUP APA MONOTONE PAINT ARL BAF 130 AMP ALTERNATOR BCD 550 AMP MAINTENANCE FREE BATTERY BGA POWER FRONT DISC/REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKA CARPETS - FLOOR AND CARGO AREA CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION DHN COMMAND-TRAC PART TIME 4WD SYSTEM DJH 230MM FRONT AXLE DMM 3.07 REAR AXLE RATIO DRK DANA 44/226MM REAR AXLE ERH 4.0L I6 POWER TECH ENGINE GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEC FRONT LEFT SIDE SLIDING WINDOW GFD REAR SLIDING WINDOW GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HAA AIR CONDITIONING JAY DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER JGB JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER K27 DO NOT USE K2B STRIPE/BADGE/MOLDING/COLOR K3A STRIPE/BADGE/MOLDING/COLOR KKS STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LAP SHIFT INDICATOR WARNING LAMP LBC GLOVE BOX LAMP LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Solid Window MMG Belt Moldings MMK NAF High Altitude Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon NHM Speed Control PAC QAC RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TRP 225/70R19.5G All Pos Traction Tires TZA Goodyear Brand Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z58 Left Front Spring Group Viii Z5B Payload Rating - 1800# Z78 Right Front Spring Group VIII Build date 2/20/91 Body code JL62 Sold by RILEY MOTOR COMPANY, SHERIDAN WY
*C1 -SA CHARCOAL 174 Zone 74-Denver 1AA U.S. Dealer Retail ADH HEAVY DUTY ELECTRICAL GROUP APA MONOTONE PAINT ARL BAF 130 AMP ALTERNATOR BCY 475 AMP BATTERY BGA POWER FRONT DISC/REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKA CARPETS - FLOOR AND CARGO AREA CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION DHN COMMAND-TRAC PART TIME 4WD SYSTEM DJH 230MM FRONT AXLE DMM 3.07 REAR AXLE RATIO DRK DANA 44/226MM REAR AXLE ERH 4.0L I6 POWER TECH ENGINE GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GRC ENTIRE FLEET KEY ALIKE (FREQ 7) GUB POWER MIRRORS-BASE HAA AIR CONDITIONING JAZ DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER K27 DO NOT USE K2B STRIPE/BADGE/MOLDING/COLOR K3B STRIPE/BADGE/MOLDING/COLOR KKS STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LAP SHIFT INDICATOR WARNING LAMP LBC GLOVE BOX LAMP LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Solid Window MMG Belt Moldings MMK NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PB3 QB3 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TRP Tires TZA Goodyear Brand Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z58 Left Front Spring Group Viii Z5B Payload Rating - 1800# Z77 Right Front Spring Group VII Build date 9/11/90 Body code JL62 Sold by RILEY MOTOR COMPANY, SHERIDAN WY
*C1 -SA CHARCOAL 166 Zone 66-Orlando 1AA U.S. Dealer Retail 3VQ Customer Preferred Discount 4HA Special Scheduling Condition I 4XA Air Conditioning Bypass ALA ALK APA MONOTONE PAINT BAP 75 AMP ALTERNATOR BCX Maint. Free Battery BGA POWER FRONT DISC/REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKJ BLACK VINYL FLOOR COVERING CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION DMM 3.07 REAR AXLE RATIO DRJ DANA 35 REAR AXLE ERH 4.0L I6 POWER TECH ENGINE GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GRV LEFT MANUAL MIRROR GUA OPEN HCD DO NOT USE - SEE HCA JAZ DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER JJA CIGAR LIGHTER K3Z STRIPE/BADGE/MOLDING/COLOR KDN KWS STRIPE/BADGE/MOLDING/COLOR LAP SHIFT INDICATOR WARNING LAMP LBC GLOVE BOX LAMP LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Solid Window MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 QE4 RA8 Delete Radio SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires TZH Michelin Brand Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z57 Left Front Spring Group Vii Z77 Right Front Spring Group VII Build date 12/17/90 Body code TL61 Sold by BOB DANCE JECP, ORLANDO FL
*X2 -SA Charcoal 173 Zone 73-San Francisco 1AA U.S. Dealer Retail 4AF 5AL APA MONOTONE PAINT BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA POWER FRONT DISC/REAR DRUM BRAKES BJA STD DUTY FRT DISC BRAKES BKP 10X2.5 REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKA CARPETS - FLOOR AND CARGO AREA CSR PASSENGER ASSIST HANDLES CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION DMF 4.10 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS EPD ENGINE - 2.5L I4 TBI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GNA REAR VIEW DAY/NIGHT MIRROR GRV LEFT MANUAL MIRROR GUA OPEN HCD DO NOT USE - SEE HCA JAA INSTRUMENT PANEL JAZ DO NOT USE - SEE JP, KA CLASSES JBF INSTRUMENT PANEL BLACK BEZEL JCA 85 MPH PRIMARY SPEEDOMETER JJA CIGAR LIGHTER JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDB STRIPE/BADGE/MOLDING LAF SEAT BELT ALERT-DRIVER SEAT ONLY LBC GLOVE BOX LAMP LCJ DOME/READING LAMP B-PILLAR LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Solid Window MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAE California Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PWB QWB RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA Audio SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z57 Left Front Spring Group Vii Z76 Right Front Spring Group VI Build date 12/1/88 Body code TL61 Sold by WHEELER JEEP, YUBA CITY CA
*X2 -SA Charcoal 174 Zone 74-Denver 1AA U.S. Dealer Retail 4FM Fleet Option Editor 5AL Low Series Tracking APA MONOTONE PAINT BAY 105 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA POWER FRONT DISC/REAR DRUM BRAKES BJA STD DUTY FRT DISC BRAKES BKP 10X2.5 REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKJ BLACK VINYL FLOOR COVERING CSR PASSENGER ASSIST HANDLE CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION DHN COMMAND-TRAC PART TIME 4WD SYSTEM DJH 230MM FRONT AXLE DMM 3.07 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GNA REAR VIEW DAY/NIGHT MIRROR GRV LEFT MANUAL MIRROR GUA OPEN HAA AIR CONDITIONING JAA INSTRUMENT PANEL JAZ DO NOT USE - SEE JP, KA CLASSES JBF INSTRUMENT PANEL BLACK BEZEL JCA 85 MPH PRIMARY SPEEDOMETER JHA VAR INTERMITTENT WINDSHIELD WIPERS JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAF SEAT BELT ALERT-DRIVER SEAT ONLY LAP SHIFT INDICATOR WARNING LAMP LBC GLOVE BOX LAMP LCJ DOME/READING LAMP B-PILLAR LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAD HIGHWAY TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z84 Right Front Spring Group XIII Build date 4/7/89 Body code JL61 Sold by VIDMAR MOTOR COMPANY, PUEBLO CO
*B1 -H9 162 Zone 62-Houston 1AA U.S. Dealer Retail 4FM Fleet Option Editor 5AL Low Series Tracking APA MONOTONE PAINT BAY 105 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA POWER FRONT DISC/REAR DRUM BRAKES BJA STD DUTY FRT DISC BRAKES BKP 10X2.5 REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKJ BLACK VINYL FLOOR COVERING CSR PASSENGER ASSIST HANDLES CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION DMM 3.07 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GNA REAR VIEW DAY/NIGHT MIRROR GRV LEFT MANUAL MIRROR GUA OPEN HAA AIR CONDITIONING JAA INSTRUMENT PANEL JAZ DO NOT USE - SEE JP, KA CLASSES JBF INSTRUMENT PANEL BLACK BEZEL JCA 85 MPH PRIMARY SPEEDOMETER JHA VAR INTERMITTENT WINDSHIELD WIPERS JKB K3Z STRIPE/BADGE/MOLDING/COLOR KWW LAF SEAT BELT ALERT-DRIVER SEAT ONLY LAP SHIFT INDICATOR WARNING LAMP LBC GLOVE BOX LAMP LCJ DOME/READING LAMP B-PILLAR LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Solid Window MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon NHM Speed Control PE8 QE8 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAD HIGHWAY TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Build date 6/18/89 Body code TL62 Sold by BILL MUNDAY JEEP EAGLE INC, AUSTIN TX
*X8 -H9 174 Zone 74-Denver 1AA U.S. Dealer Retail 4EA Sold Vehicle 5AM Largo Tracking 5KN Metro Cars of Detroit ADA LIGHT GROUP ADH HEAVY DUTY ELECTRICAL GROUP ADL SKID PLATE GROUP AHL HEAVY DUTY INSULATION GROUP ALN APA MONOTONE PAINT BA1 100 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA POWER FRONT DISC/REAR DRUM BRAKES BJA STD DUTY FRT DISC BRAKES BKP 10X2.5 REAR DRUM BRAKES CAC LOW BACK BUCKET SEATS CDB RECLINING FRONT SEATS CKA CARPETS - FLOOR AND CARGO AREA CSR PASSENGER ASSIST HANDLE CUF FULL LENGTH FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDX 5-SPEED HD MANUAL TRANSMISSION DHN COMMAND-TRAC PART TIME 4WD SYSTEM DJH 230MM FRONT AXLE DMM 3.07 REAR AXLE RATIO DRK DANA 44/226MM REAR AXLE DSA ANTI-SPIN DIFFERENTIAL REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GFD REAR SLIDING WINDOW GNA REAR VIEW DAY/NIGHT MIRROR GNB DRIVER SIDE ILLUMINATED SUN VISOR GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HAA AIR CONDITIONING HGA HOOD INSULATION JAA INSTRUMENT PANEL JAY DO NOT USE - SEE JP, KA CLASSES JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH PRIMARY SPEEDOMETER JGB JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER JKB K2X STRIPE/BADGE/MOLDING/COLOR K3D STRIPE/BADGE/MOLDING/COLOR KKG LAF SEAT BELT ALERT-DRIVER SEAT ONLY LAJ HEADLAMPS ON WARNING CHIMES LAP SHIFT INDICATOR WARNING LAMP LBB COURTESY LAMPS LBC GLOVE BOX LAMP LBD ASH TRAY LAMP LBE AMBIENT LIGHT LCJ DOME/READING LAMP B-PILLAR LDH U/HOOD, REMOVABLE/RECHARGEABLE LAMP LHD HEADLAMP OFF TIME DELAY LMA HALOGEN HEADLAMPS LPE CARGO LAMP MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Solid Window MMG Belt Moldings MMK NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank NHM Speed Control PS3 QS3 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 9/21/88 Body code JM61 Sold by COOK CHEVROLET INC, CRAIG CO
*X1 -H9 3LY AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAF HIGH ALTITUDE EMISS CONTROL PKG PYC QYC RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 6/28/88 Body code TM62 Sold by KEN GARFF SPARTAN CHRYSLER JEEP, MURRAY UT
*X3 -SA Charcoal AGC APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PX6 QX6 TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 12/17/87 Body code TL61 Sold by PETERSBURG CHRYSLER JEEP, PETERSBURG VA
*X1 -H9 3LY ADL PACKAGE - 4X4 PROTECTION AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGW Transmission - 4-Spd. Automatic ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PX6 QX6 RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 7/14/88 Body code JM61 Sold by SKYLAND CHRYSLER JEEP DODGE RAM, ASHEVILLE NC
*X1 -H9 3LY ADA LIGHT PACKAGE ADL PACKAGE - 4X4 PROTECTION AGJ Driver Assistance Group AHL HEAVY DUTY INSUL PACKAGE APA MONOTONE PAINT PACKAGE AWH POWER EQUIPMENT GROUP AWJ BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGW Transmission - 4-Spd. Automatic DSA LIMITED SLIP DIFFERENTIAL DTA ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL NHQ Transmission Heater PYC QYC RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL Z5B GVW/PAYLOAD RATING Build date 4/25/88 Body code JM62 Sold by ROYAL MOTOR COMPANY, MONTGOMERY AL
*Q7 Seat - Cloth Low-Back Bucket -SA Charcoal 3LY ADA LIGHT PACKAGE AGD APA MONOTONE PAINT PACKAGE AWH POWER EQUIPMENT GROUP BCQ Battery - Maintenance Free CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDJ 5SPD MANUAL TRANS ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LNJ DUAL ROAD LAMPS - FRONT LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MWB SPORT BAR NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater NMB ENGINE COOLING - STANDARD DUTY PS4 QS4 RAB Radio - AM/FM SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJH 15X7 ALUMINUM WHEELS XPF Build date 1/15/88 Body code TS61 Sold by COURTESY PONT-JEEP-EAGLE, HONOLULU HI
*X4 -SA Charcoal AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DCB Transmission - 4-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY PWB QWB RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 6/3/88 Body code TM61 Sold by BILL WHITE CHRYSLER PLYMOUTH JEEP, FORT SMITH AR
*X1 -Q8 APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS HCC HEATER W/UPR LEVEL VENTIL - TYPE II K60 BODY SIDE MLDGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PXG Medium Blue Metallic QXG Medium Blue Metallic RCA MONAURAL SPEAKER SYSTEM TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 4/22/87 Body code TL61 Sold by ALAN HYATT JEEP-EAGLE, SMITHFIELD NC
*W7 -YY ADA LIGHT PACKAGE AGL APA MONOTONE PAINT PACKAGE AWH POWER EQUIPMENT GROUP CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGQ TRANSMISSION-4SPD AUTOMATIC DMR 3.55 Axle Ratio ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAE EMISS CONTROL TESTING &&&&&&&& LABEL PYM QYM RAC RADIO - AM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Z1B GVW/PAYLOAD RATING Build date 2/9/87 Body code JP62 Sold by PALOMAR AMC JEEP-RENAULT, ESCONDIDO CA
