Interests
Jeeps, vintage computers, road trips
1868 profile views
ThreeComanches's Achievements
Comanche Aficionado (4/11)
1992 Jeep Comanche 4.0L HO / AW4 Auto / Dana 35 / 2WD / SWB Build date: 8/91 Location: North Miss. Status: Not running, Off the road since around 2020. Owner: myself
Kaede the Eliminator
ThreeComanches replied to Tactical Bacon's topic in Member Projects: Your Comanches
It sounds like there might be air in the system. -
‘86 Diesel
ThreeComanches replied to neohic's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Yep it is the same one. He had it painted. -
1992 Jeep Comanche Sport 4.0L High Output / AW4 Auto trans / 231 TCase / Dana 30 front axle / Dana 35 rear axle Build date: 12/91 Current Location: North AL Status: Not running, Transfer case blew out. Current owner: Gentleman in North AL. Notes: Was originally red but had some ugly camo paint job painted over it.
Ladies and gentlemen, for the first time since September of 1995... the Mississippi Turbo Diesel rides again! After looking in the registry, I also found out this is the latest built factory diesel Comanche. It might even potentially be the last one. This one took about a year and a half to get back on the road and I still got plenty more to do to it cosmetically. Even then. it's a thrill to have another one of these rarities back on the road. I also included a picture of the last inspection sticker. Funny enough, Mississippi doesn't have vehicle inspections anymore! Haha
So a lot of progress has been made... I finally installed the transmission, got the brakes working with a new master cylinder, installed new clutch master and slave cylinders, and bled the cooling system. However, the water pump had a huge leak so that needed attention asap. I was lucky enough to get the last one available off of rock auto. Once I got it in and installed it, the leak finally went away.
1987 Comanche Laredo 2.1 Diesel
ThreeComanches replied to ThreeComanches's topic in Member Projects: Your Comanches
So the first order of business was to remove the old 2.5 engine and its associates hardware. A lot of it had been done already so I mainly just had to unbolt the engine and trans. Once that was finished, I prepared and installed a 2.1 from a Winnebago LeSharo. The main items that needed to be swapped were the motor mount brackets and oil sending unit blockoff bolt. I also had to adjust the turbo inlet so it could connect to the factory intercooler. Speaking of which, all of the parts in the engine bay I installed were just spares I dug out of one of my bins. Since the truck had been gas swapped, the glowplug harness and hardware had been removed by whoever did the swap. With that said, I had a spare timer, a couple of relays, and some scrap wire laying around. Once I found the diagram in my eletrical manual, I got to work on building a new glowplug harness for the truck. Once completed, I installed it and it worked perfectly. I also had to build the main harness for the engine bay which consisted of the fuel shutoff, water sending unit, alternator, and the cold start solenoid. -
Hi all, I got a treat for ya'll. As far as I can tell, this Jeep is the only one of it's kind left. She's a 1987 Comanche Laredo with the factory 2.1 Turbo Diesel. It spent its whole life in Western Oregon until this year. At some point, the diesel was removed and a 2.5 gas was installed. It was driven like that until it stopped around 166k miles. Last registration was in 2022. I got word that the owner tried to convert it to run on natural gas and blew up his shop trying to make said natural gas. The guy that got ahold of it after sold the tailgate off of it (NOS pulloff) and sold the truck to a kid that put a sketchy lift on it, sold the body, and chopped the fenders. After getting in contact with the kid, I managed to put together a deal and drove from Alabama to Oregon to get it. On July 7th, she was on the trailer and I started home. (pictures taken of it before it was mutilated) (when I picked it up) As I was heading home, I had a mishap in Nevada. It was windy and as I was hauling down US-95, the hood flew open and messed up the cowl and firewall. It then occurred to me the kid had removed the hood latches and didn't mention it. After I strapped the hood down, the rest of the trip was smooth sailing afterwards and I arrived back home on July 11th. My main goal on this truck it to get it back to as original condition as I can.
ThreeComanches started following Muncher
Muncher started following ThreeComanches
I have some 1987 Tan parts. Shoot me a PM.
Hi everyone! I'm pleased to announce that another Turbo Diesel Comanche has been saved! Drove all the way to Oregon to get this one. This one is a 1987 Laredo. It's pretty rough at the moment. The guy I got it from tore it up pretty bad. Cut fenders, sold the bed, rattle canned it with primer, and put a sketchy lift on it. It will be getting a full factory spec restoration when time permits.
1987 Jeep Comanche Laredo Turbo Diesel Original specs: 2.1L Turbo Diesel / AX5 5 Speed / Dana 35 rear axle / 2WD Current specs: 2.5 I4 Gas / Unknown trans (AX5 I believe) / NP207 Transfer Case / Dana 35 rear axle / Still has the 2WD front axle Build Date: Unknown Current Location: Oregon Status: It has been off the road for years, I'm in the process of buying it. It's currently missing the bed and the fenders have been chopped by the current owner.
Reproduction Comanche Emblems
ThreeComanches replied to carolinajeepman's topic in Vendors- members making products for MJs
I see, I wasn't aware if @carolinajeepman had a diesel badge yet or not. Thanks for the pointer on the Dodge badges! -
That's wild, where did you find that? -
Any luck finding a turbo diesel emblem?
