eaglescout526
Administrators
    13
  1. Ok hardest part is done which is unplugging the C100 and removing the cab side to gain access to the block to remove the retainer to slid the terminal in and putting it all back together. To verify I put it in the right spot I tested continuity from the engine side connector to the pin for slot 15 and I have continuity. Honestly, this mod is not for the feint of heart to do. It requires some hand acrobatics, a second person to push the C100 back together and some know how. If we want I can do a write up of setting an MJ up with the lamp using the info from this thread.
  2. Ok so this isn’t going to be as easy for 87-90 as it would be for the 86’s. I should’ve known looking at the picture of the C100 was going to have different terminals and I put AMC logic into my head and thought why would they use anything different. Well they did and here’s the terminal style everyone else is going to need: I am not sure of the terminal name that goes into C100 but it looks metri.
  3. It really is the visor and grill and regardless it looks damn good.
  4. I have no idea how in the hell you managed such but you made your MJ look like a J-truck from a distance.
  5. It has everything tied to that? Oh my! I need such. Yes they came with air shocks in waggy limiteds and special order XJs. I have the shocks as NOS but need the compressor and everything tied to it. Shoot me a PM and we can discuss this without clogging this soon to be informative thread.
  6. I’d go back and grab it along with the on board shock air compressor in the corner on the passenger side by the firewall. Actually can you just get me that whole engine bay lol. Man that XJ is full of goodies.
  7. Oooo and those are the rare pillars. The early ones don’t have a way to put the screw hole covers on unless someone swapped them. Did you grab the sentry stuff? I’d like to have back up parts for mine along with the computer. And the valve cover.
  8. No problem and ahh. I’m down in the valley.
  9. According to my 84, 85, 86 preliminary and 88 XJ electrical manuals, it is always pin 15 and on the connector itself it is numbered 1-16. But at C100 I can confirm that the electrical manual shows the sensor wire to plug in in different locations for each year except 84-85.
  10. Basically a really flat flat head. There’s the part number. I bought it off of mouser a year or so ago. It has come in handy for removing a lot of pins especially the pack cons and packard 56’s that are all over the AMC era.
  11. *C1 -SA CHARCOAL 166 Zone 66-Orlando 1AA U.S. Dealer Retail 3V3 Customer Preferred Discount 4HA Special Scheduling Condition I 4XA Air Conditioning Bypass ALN APA MONOTONE PAINT ARL BAP 75 AMP ALTERNATOR BCC MAINT. FREE BATTERY BGA POWER FRONT DISC/REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKA CARPET CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDQ 5-SPEED MANUAL TRANSMISSION DMM 3.07 REAR AXLE RATIO DRJ DANA 35 REAR AXLE ERH 4.0L I6 POWER TECH ENGINE GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GFD REAR SLIDING WINDOW GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HCD DO NOT USE - SEE HCA HW1 AIR CONDITIONING - ADD-ON JAY DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER JGB JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER K27 DO NOT USE K2B STRIPE/BADGE/MOLDING/COLOR K3G STRIPE/BADGE/MOLDING/COLOR KKS STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LAP SHIFT INDICATOR WARNING LAMP LBC GLOVE BOX LAMP LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Solid rear window MMG Belt Moldings MMK NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PG5 Hunter Green Metallic QG5 Hunter Green Metallic Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TMW Tires TZH Michelin Brand Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z77 Right Front Spring Group VII Build date 5/13/91 Body code TL61 Sold by FIRKINS CHRYSLER JEEP DODGE RAM, BRADENTON FL
  12. *X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 135 Zone 35-Washington 1AA U.S. Dealer Retail ALA SE DECOR GROUP APA MONOTONE PAINT BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA POWER FRONT DISC/REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKJ BLACK VINYL FLOOR COVERING CSR PASSENGER ASSIST HANDLES CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DCK 4SPD MANUAL TRANS DMD 3.55 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EPD ENGINE - 2.5L I4 TBI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GNA REAR VIEW DAY/NIGHT MIRROR GRV LEFT MANUAL MIRROR GUA OPEN HCD DO NOT USE - SEE HCA JAZ DO NOT USE - SEE JP, KA CLASSES JCA 85 MPH PRIMARY SPEEDOMETER K3Z STRIPE/BADGE/MOLDING/COLOR KDB STRIPE/BADGE/MOLDING LAP SHIFT INDICATOR WARNING LAMP LBC GLOVE BOX LAMP LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RA8 Delete Radio SAA Manual Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z75 Right Front Spring Group V Build date 5/6/90 Body code TL61 Sold by WILLIAM CLARKE JEEP-EAGLE, FREDERICKSBURG VA
  13. *X1 -SA Charcoal 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 4AF 5AM Largo Tracking 5KN ADA LIGHT GROUP ADL SKID PLATE GROUP ALN APA MONOTONE PAINT BAY 105 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA POWER FRONT DISC/REAR DRUM BRAKES BJA STD DUTY FRT DISC BRAKES BKP 10X2.5 REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKA CARPET CSR PASSENGER ASSIST HANDLES CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDX 5-SPEED HD MANUAL TRANSMISSION DHN COMMAND-TRAC PART TIME 4WD SYSTEM DJH 230MM FRONT AXLE DMM 3.07 REAR AXLE RATIO DRK DANA 44/226MM REAR AXLE DSA ANTI-SPIN DIFFERENTIAL REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GFD REAR SLIDING WINDOW GNA REAR VIEW DAY/NIGHT MIRROR GNB DRIVER SIDE ILLUMINATED SUN VISOR GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HAA AIR CONDITIONING JAA INSTRUMENT PANEL JAY DO NOT USE - SEE JP, KA CLASSES JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH PRIMARY SPEEDOMETER JGB JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER JKB K2X STRIPE/BADGE/MOLDING/COLOR K3C STRIPE/BADGE/MOLDING/COLOR KKE LAF SEAT BELT ALERT-DRIVER SEAT ONLY LAJ HEADLAMPS ON WARNING CHIMES LAP SHIFT INDICATOR WARNING LAMP LBB COURTESY LAMPS LBC GLOVE BOX LAMP LBD ASH TRAY LAMP LBE AMBIENT LIGHT LCJ DOME/READING LAMP B-PILLAR LDH U/HOOD, REMOVABLE/RECHARGEABLE LAMP LHD HEADLAMP OFF TIME DELAY LMA HALOGEN HEADLAMPS LPE CARGO LAMP MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK NAE California Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PQ9 QQ9 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers SUA Tilt Steering Column TAA All Tires TAE TBB Full Size Spare Tire TBM Tire Carrier Winch TRP 225/70R19.5G All Pos Traction Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z59 Left Front Spring Group Ix Z5B Payload Rating - 1800# Z78 Right Front Spring Group VIII Build date 1/19/89 Body code JM62 Sold by QUAID JEEP EAGLE, RIVERSIDE CA
  14. Just a short PSA. Part number 06036045AA is the same bolts we have on the 2.5L and 4.0L that holds the manifolds to the engine, but it has the washer/clamp glued to the nut so it makes it easier to install these bolts with the washers and not lose the washer in the process.
  15. Yup. Those are factory. Someone probably wants a set.
  16. Probably, I just hope AMC used the same has ford, I can see them using the duraspark for just coil control.
  17. Probably or even AMC engines in general should have such. If I was further along on my XJ I would just send you mine.
  18. If they’re factory too they are worth a snag.
  19. Ok so luckily I got a full XJ dash harness recently and I went and thought, oh hey! I can pull the one wire from the harness to put into my MJ and holy fricken crap is this gonna be easy. So here’s pin 15 in the info center connector: (I already started removing it before taking the pic) here’s the wiring for it: Here’s where it was in C100: (red arrow pointing to the empty spot is where I found it. Could be different in other model years.) here's both connectors. I don't know what the cluster pin is as I haven’t tried to locate one on mouser but I know the female pins are packard 56 or series 56 connectors.
  20. *X4 -SA Charcoal 3LX AGJ APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DCB Transmission - 4-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Colorado Red QE4 Colorado Red RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 3/16/88 Body code TM61 Sold by PERRY THOMAS JEEP-EAGLE, DECATUR IL
  21. *X3 -YY AGC APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGW Transmission - 4-Spd. Automatic ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GTZ MIRRORS - MANUAL REMOTE JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL PX6 QX6 RAC RADIO - AM/MTR SBA POWER STEERING TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 1/18/88 Body code JL62 Sold by WILMINGTON A-J-R INC, WILMINGTON MA
  22. I appreciate that. Chrysler made it a tad bit harder to access dealerconnect from home which requires me to log into my work email. Not so much harder but more time consuming.
  23. Crap. I’ll get it done today. Been busy.
