DzienManche
DzienManche's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Yeah I think tomorrow I’ll get to micro center and see if I can’t source one. Assuming it’s on the board that the screw posts are sticking out of on the type 1 pic above? I hate that it’s all welded and sealed, but the spring should be ok because it still moves when current it passed.
  2. If I knew what kind of resistor I needed I may be able to just solder it on no problem. Lol
  3. Yeah, sorry I included a picture of the tach from the newer cluster that I have that has other gauge issues. My stock one everything works perfectly fine except the tach
  4. Yeah, I tried installing that newer cluster into mine everything else fits. It’s just the gas gauge is broken and I think a couple other gauges have issues when trying to use that one.
  5. Yeah it’s non adjustable. But if it’s as simple as just needing to resolder something I can handle that
  6. I know I probably have a problem with my decameter, but I’m trying to diagnose and see if it may be an electrical issue instead. When I start my truck, the needle goes all the way and maxes out and stays there until I turn the truck off. Which makes me think there may be a Short or something weird going on electrically. All of my other gauges work but I’m trying to find a diagram for the connection in my 86 for the instrument cluster. Any help is greatly appreciated! I wish I could find a drop-in tachometer that isn’t an upgraded one. I have a newer cluster, but the tachometer has a bunch more different connections and stuff, mine does not have an adjustable screw for the potentiometer. That would make life so much easier.
  7. I was recommended to take a look at upgrading my factory carb on my ‘86 XLS. I know nothing on what to look for but they had said a 4 barrel but don’t know where to start. Can anyone link ones that would work for my 2.8L v6? I’m looking into engine swapping but don’t know if the carb is the weak link on drivability. What’s my price range on it?
  8. The tach pic is what I'm working with on the old cluster, the second one is the back of the "newer" cluster with the adjustable Tachometer. It was in the truck and running ok. I think there is just some issues with a couple of things. There are slightly different pins on the back but I was going to swap them again just to see what was and wasn't functioning. maybe move the stock gauges over if I can. I just don't want todrop over $250 for a new cluster just to get a tachometer that works from 86. I can't find any substitutions either.
  9. I think so? Why would I have to change out the speedo cable though? I think this other cluster I have just threads right on. Unless you are meaning to completely change the speedo of that to keep my mileage accurate? I think the gas gauge on the other one was faulty or something. I'll try to drop the old into the "newer" one tomorrow and give that a shot and see if things will work. It's an automatic, so I don't really need the tach to work, it would just be nice to have a fully operational cluster lol.
  10. Yeah I mean there is movement and I can feel resistance when the car is on and I try to move it, testing to see if there is tension. I have an '86 XLS. The tach can spin freely when not connected. When I turn the ignition the tach goes from under 0 to max and stays there until the car is off. Not sure if the battery being continuously connected and disconnected while I had other electrical work going on may have affected it. I was reading that it may be getting too much power? I don't have wiring diagrams for the rear instrument panel connector to test voltage, I'm not sure what goes to what. All my fuses are fine and I have full functionality of all the components on the cluster, so idk if maybe the wires are just messed up.
  11. Everything on the cluster is operating nice enough. The only problem is that I think the spring or something is wrong with the tachometer. I don't want to blow $250+ on a full cluster just to rip out the tacho. Some mechanic swapped the cluster out with a later model XJ or MJ cluster, but there are several gauges that just flat don't work on that one. I tried to use it as a donor and pull the tachometer out of it to swap... but No dice. I think it's 87+. Any thoughts or lines on a new one that can drop in to my stock cluster?
  12. I know this is an old post. But I finally got my toolbar removed and broke a few welds from shotty repair work. Are you still making/selling the rollbar mounting brackets? I would love to purchase a set if so. My wheel well brackets are ok if that will bring cost down, but if it’s too much of an issue I’ll just replace them with new too so the bolt patterns and thread pitches match with the new front brackets
  13. That’s exactly what I wanted to hear. That’s perfect. You’re talking about the Camaro 3.4 I mentioned above? That would be incredible and the pricing of those engines isn’t terrible either. Assuming I can find one locally ha. Thanks for the help
