Swampy
    7
Everything posted by Swampy
  1. would you recommend that lsd up front? I keep going back and forth between lockers and lsd
  2. I love the way it is coming together. Also how did you polish your wheels?
  3. Depends on the tire size and your end goal. I am swapping in 5.13s because I want to have the possibility to daily drive a 2.5l comanche on 35/36s and still have the final crawl ratio to be able to do things offroad
  4. I think its a cool idea and concept. I can't wait to see them out on the road. if only brute conversion or aev could make them
  5. Are you talking about the one that is screwed onto the trans tunnel itself?
  6. sorry about the video, the parts with the time lapse were supposed to have music, Idk what happened
  7. Hey guys, I was able to come home for thanksgiving break from school and was able to work on the manche some. Here is a quick video of what I was able to do. I got rough country control arm drop brackets and I installed some new motor mounts. I need to replace the distributor gasket as well because that is the last place I can see my jeep is leaking from but when I went to do it, I wasn't able to pull the distributor all the way out? Any tricks for this?
  8. Where is that bumper found?
  9. Looks awesome. can't wait to get mine out in the world. That true trac is an lsd right?
  10. Sedona, Arizona! can't wait to take my jeep out west
  11. The 241OR transfer case bolted right up correct? Did you get your speedometer to work after swapping in that tcase? Lastly, your rear driveshaft you had to get that flange welded on? Sorry about all the questions just thinking about getting one for my comanche
  12. anyone have a wiring diagram for the interior lights?
  13. what recaro seats are those? the flop shop bumper is awesome on your truck
  14. Do you need a special table or something to bend the pieces into place? I'm sure it'll help though
  15. good info, will look into the retractor types for the xj's
  16. that's what I am going to do. I found some universal 3 points that should fit in an xj so I'm going to order two
  17. Be sure to remove that support bar that goes through the trans bell housing it certainly helps me
  18. Hey guys wondering if anyone has swapped from the 3 point belt to a lap belt instead? It seems like it'll be easier to install as well. Also on a side note has anyone fixed a seat belt retractor? Mine won't lock if you yank on the seat bolt. It's supposed to lock right?
  19. Thank you I try my best. I have some goodies coming in the next couple of months. Stay posted
  20. Pete linked my build thread, no rub so far with the 36s, I haven't had the chance to flex it out properly hoping to do that soon. If do decide to swap the bench to buckets, there is a nice write up in the DIY section
  21. Not much of an update but got some parts in, still have a bunch of parts to order (hopefully by December) Got my gears new Yukon carrier And new motor mounts, distributor gasket and new sensors
  22. Such a beautiful truck
  23. Swampy
    Side vent windows
    looking for the frame as well
  24. Hey guys bit of a long shot but does anyone have the side vent swing-out windows? The pre-97 xj/mj doors have that front corner piece on the door that can be swung out for more ventilation. looking for both driver and passenger side or mainly just a passenger side one?
  25. Seems doable just those seats are expensive
