7
Everything posted by Swampy
"Wendy"- 88 Jeep Comanche Build
Swampy replied to Swampy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Oh okay good to know. I will order those new sensors -
Is there a diagram as to which wire goes to which side of the plug? I know it seems dumb as there are only 2 wires -
The wires on the harness? -
How do you wire the air charge sensor? -
Thanks a ton -
I have not do you have part numbers. But if you have spares that would be amazing. How much for them? -
Working on the new harness (removing cd01 connector) Connector removed and started wrapping the new harness Also made a new head to firewall ground gauge #4 wire Lastly does anyone have, or know where I can find these 2 sensors? One on top of the intake manifold the other is on the side. -
Well Not much of an update, but I got the old harness removed from the jeep. I am in the process of cleaning the engine bay as best as I can, I also have a "New-to-me" 2.5 harness. I am going through the new harness and double checking connects and splices. I removed the CD01 connector already I will see what else I can do to the harness to make it the best possible. Electrical work and rewrapping the harness is definitely something else lol. Will get some pics up soon. Happy Thanksgiving by the way comanche peoples. -
That's sounds even better. I finish university Dec. 2020, so 2021 should be a good year haha -
I see more r2.8 swaps come out of sponsored shop builds. It seems like a fun swap and would definitely be something I consider for my comanche. Only issue is price. ANY SHOP SPONSOR WANT TO BUILD MY COMANCHE???
Unfortunately no. I am away at school right now and the truck is at my hometown. When I go on break for thanksgiving and Christmas I plan on working on the truck and trying to get it running again. I started to pull the harness but I didn't get a chance to finish as I had to leave. So I am planning on getting all that taken care of when I get the chance. -
No there is no grinding the backing plate. just pull of the drum backing plate and put the disc one in its place. As far as I saw on the kj's the only difference was the earlier ones still had drum brakes. so I think 2004/2005 and newer have the disc brakes. I was satisfied with braking performance with the stock booster and disc at all 4 corners. If you do the dual diaphragm booster and the distribution block, braking performance will be greatly increased
- 13 replies
- brakes
- disc brakes
(and 1 more)
Tagged with:
This might be a dumb question but can you change the 5th gear ratio on an ax15? The stock ratio is .79, which is a little too much for my 2.5 to push 35s. I was wondering if you could swap the ax5 5th gear ratio which is .83 I believe so it should help with 5th gear power for driving. I don't know if its even possible or if it'll ruin the reliability of the ax15.
I have been gone from the forums for a while and man I missed looking at this mj. I can't wait to go to moab. I'll make it to mj takeover one day
Grounds and general wiring.
Swampy replied to Jeep Driver's topic in MJ Tech: DIY Projects and Write-Ups
Good to note -
I have been meaning to ask this question, but are all the grounds necessary to have or can I eliminate some? Like on the 2.5 there is one that goes from the head of the engine to the firewall. It doesn't seem to be connected to anything so can I just get rid of it? I just got a new wiring harness for my mj so I am going to be going through all the grounds and wiring to clean it up as much as I can and eliminate what isn't necessary. BTW anyone have mj 2.5 wiring diagrams? -
I have a 2.5 with 5.13s and 35s. It did great in every gear except 5th gear of the ax15. It doesn't like 5th gear not enough power. But that was before my wiring harness fried itself. I'm tempted to run d44s or something similar to get deeper gears in the axles 5.38s 5.71s 6.17s
Question on the swap from 2.5 to 4.0. The driver side frame horn, did you have to do any welding or did it just bolt right up? Also what did you do about the radiator supports on the header panel?
Yeah the coating starts to burn off with the heat lol
Rangers of the time had that funky ttb front axle. Its a solid front axle but also ifs. But technically its not a true solid front axle so yes you are right
I better brush up on my computer programming
Its interesting because I wanted to see what the classic car world/market would look like when I am in my 50s and 60s because I a 2015 mustang would be eligible as an antique in 2045. I wondered what it would take to keep a car like that running for that long because of the computer systems. I guess we just have to see how it goes and adapt.
Thanks for all the support, definitely will get it fixed, just have to figure out what to do. And a fire extinguisher is at the very top of next things to purchase -
That is an inspiration -
Yeah its pretty emotional. But it is not a total loss so that's a good thing. But I am taking a few weeks break to clear my head and really think about what I want to do. The 2.5 was great except foe getting up to highway speeds I wouldn't mind staying with a 2.5 (especially if I can do some engine work to it) unless a 4.0 swap comes cheap
