tacticleturtle
    Corona CA
  • Interests
    Jeeps, Beer, Family, Jeeps
1409 profile views
tacticleturtle's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Steal away lol. I had the idea for a long time and I got some inspiration from a lot of guys with toyotas. They build dual swingouts all the time have some clever ideas. I have a lot more pictures I'm pretty sure. I can show you what I did and what I'd change. Just PM any questions you got. Take a look at ruff stuff and there bumper tire carrier kit. I just ordered another hindge for the dual swing out. They were over kill for sure but worked great.
  2. Here is the material I used. MIG welder, band saw and a LOT of flap discs lmao
  3. Lol thanks. Time off for the new kid and holidays helped. 3.5" metal cloak game changer lift, falcon 3.3 shocks, metal cloak steering, chromo rear shafts, rcv front axles, 4.88 gears, 35" cooper sst pro, front and rear driveshafts w/ 1350 u joints. Inner fender liners, front and rear bumpers and tons of stuff inside. It's been fun but another level from the XJ and MJ life I've been living. But it meets the comfort needs of the little ones and most importantly the bosses (wife) lol Thanks. Comanche funded some of it. Sad to sell it but hurt even more to finish it and have it sit. It went to a good home and I'm sure it will pop up somewhere on here. The bumper I used a JCR DIY bumper. Then bought the hindges and tire carrier parts from ruff stuff. They have amazing fab parts and top notch quality. I sourced some square tubing 1/4" wall from a local place to build the rest. Not my first bumper but they are time consuming to get right. That's why the new jeep has off the shelf bumpers. Wife said if I build another bumper bad things will happen lol. I have more pics I can post of the bumper. It was to crazy just lots of measuring because the clearance between the tail gate and where the swing outs mount is tight.
  4. New jeep It's only been a year so you can see it escalated quickly lol
  5. I finished it and it sat for 6 months and I never drove it. Had another kid and bought a new rubicon. Just sat so I had to sell. I can't post pictures for some reason but the thing turned out great. Sorry for the disappointing ending. Good news is my new jeep is siiiiiick lol
  6. Picked up two of these bed boxes for $40. Need keys and new hinges but should help on storing some stuff
  7. Rear main seal Long arms bolted up new upper axle bushing Wheel bearings ball joints disco sway bar IRO OTK steering New brake lines Replaced the calipers and did new pads and rotors. Rear dana 44 is next over christmas. Doing a SOA setup. Also got an HO MJ fuel sender to rebuild with new bosh pump and sock. Hopefully the guage will read correct now lol
  8. https://tuffstuff4x4.com/products/tuff-stuff-84-01-jeep-cherokee-xj-front-winch-bumper/ They are great people to work with. It's out of stock but I'd call and see when they get more in. I'd compare there stuff to smittybilt
  9. You can't beat it. It comes powder coated with like a bedliner texture. For the price there is nothing else close. The metal might be a little thin but I figured after every big recovery I'll check everything. Comes with all the hardware and d rings. I just upgraded all the hardware to grade 8. Thanks the rear was a lot of work hahaha
  10. Currently install iro long arm and otk steering. Doing ball joints, wheel bearings, new brakes including calipers, quick disco, flipping rear axle and putting in a dana 44 I picked up. Since the axle was close to being out anyways I just removed it and did the rear main seal. Way better with the axle out lol.
  11. I didn't take a ton of pics on everything but you get where this is going. I made a gas can holder and a basket for a cooler. I haven't finished the basket yet. On the short arm you can see I welded some square tubing on the arm so I can make whatever attachment I want in the future.
  12. Sorry the pictures keep posting out of order but you get it
  13. With a ton of measurements it knew it was going to be a tight tight fit to get that swing out hindge to fit between the tailight and the tailgate. Once the hinges were in a good location and mounted the bumper one last time. Checked everything again. Once I pulled it off I braced the whole inside of the bumper at the hinge to make sure it was supported good. Once the hinge was burned in I started making the swing outside. The right longer arm is for the tire and left for whatever as you will see later.
  14. I've always wanted a dual swing out. Since nobody makes anything for the mj platform my solution was to do it myself. Since this is going to be a DD adventure rig I need to keep the bed space free. I like the overland rigs with dual arms because you have tons of flexibility. Also with the one swing out the are needed to open it is huge. The dual arm seemed like the way to go. I started with a jcr DIY bumper and ordered a bunch of stuff from ruff stuff. As you can see the hinge for the tire carrier is beefy.
