Everything posted by DesertRat1991
I like this article from P4x4. The bottom 1/3 of the page goes over reading the contact pattern: https://www.pirate4x4.com/tech/billavista/Gear_Setup/ When I looked into this job, I remember the cost for all the right tools was significant. Hydraulic press, pinion depth setting tool kit, case spreader, etc... it was hundreds in new tools that I would rarely use. Could be worth it if you already have that stuff laying around, or you if intend to do the job frequently.
Air Deflector (below front bumper)
DesertRat1991 replied to Jtslick89's topic in MJ Tech: Modification and Repairs
It wasn't until I met Jeepers that I learned there were "car guys" out there that expected you to give away mods for free. If you put a turbo kit, triple adjustable coilovers and a $3,000 set of wheels on an import, the value goes up. But if you lift, stroke and axle swap a Jeep the online community says "Sorry, you never get back what you put in." IMO, those kind of things should add value but the Jeep community perpetuates the contrary notion. Personally, I will part my truck out down to the uniframe before I GIVE away mods to some Bubba for free.
Interesting. I've never seen that crazy looking fastener before. I have aftermarket tow hook brackets and the kit just used carriage bolts through the frame rail.
Which Light Bar Do You Have?
DesertRat1991 replied to comanchefest's topic in MJ Tech: Modification and Repairs
Looks like it would work. The stock bumper is curved and the contour is a good match for a 25-30" curved light bar. -
What is considered not stock
DesertRat1991 replied to CoastChief's topic in MJ Tech: Modification and Repairs
Very interesting hearing the different perspectives. I've always viewed "stock" as a configuratuin of items available from dealer stock, and "all original" as the unmolested, virgin state that rolled off the factory floor. Two questions for you guys: 1) If a guy ordered a Comanche with 15" steelies, then goes back to the dealer a week later to have them swapped out for turbines -- do you object to marketing that vehicle as a "stock" Comanche at the time of resale? 2) A different Comanche goes in for its first dealer service and has the lower control arms replaced with the correct dealer-supplied parts. Stock or not? By my compass, both are in stock configurations but neither is "all original." For that reason, I kind of agree that "stock" is overrated but a 30 year old, low mileage, "all original" is a noteworthy find. -
This parts manual is a nice document to keep around: MJ Parts Manual.pdf In my opinion, if you can find the part in that manual then it is in bounds for "stock" and period correct. Those wheels you bought are on page 7 of PDF. Enjoy them! -
Where to Mount Air Tank at??
DesertRat1991 replied to GrizzzzBear's topic in MJ Tech: Modification and Repairs
Just a thought -- but if you have a stock MJ on tires 33" or less -- do you really need an onboard air tank? As an alternative, I can highly recommend the Viar 88p, portable 12V compressor. It has no problem airing up my 32's from ~17psi back to street pressure. It won't even bat an eye at those tires you're running, and it fits in that canvas bag you see tucked behind the driver's seat: The other thing to notice about this pic would be the 4.5lb fire extinguisher mounted to the bulkhead. I suppose if you insist on installing an air tank you could mount it similarly. -
How do you plan to achieve 10" of lift in the rear?
Anyone need these handles..? Couldn't get the rear driver door to open. Gonna have to bring a crow bar next time.
Transmission crossmember studs
DesertRat1991 replied to mvusse's topic in MJ Tech: Modification and Repairs
This vid shows removal of the crossmember stud. -
I think it looks great! Which JBL amp are you going with? I've been taking a close look at the Kenwood KAC-M1824BT lately. Mostly because it will let me stream tunes from my smartphone via bluetooth, while also keeping the stock head unit. It's also small and should be easy to hide under the seat.
Met 2 local guys through clist parts deals. Spotted 2 passing by on the road. Picked 2 in junkyards. Since 2015.
team cherokee clearance
DesertRat1991 replied to jdog's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
So who got the tail light this time...?? -
Sorry for your loss. At least no one was hurt. I am always curious if the guys with massive parts hordes have a plan to cover their losses in a fire.
He's a big fella! Congrats!
First post, new to the club
DesertRat1991 replied to OtterMobile's topic in Member Projects: Your Comanches
POS 1 POS 2 DECKS FRY OUTER CORN ALLY ALLY ??? ??? Very curious! -
In that price range you might be able to do a set of cross bars that clamp to the drip rails. Those kits are fairly universal. You would just need to cut them down to your preferred width.
Cup Holder - Another One
DesertRat1991 replied to Ronnie's topic in MJ Tech: DIY Projects and Write-Ups
This is a great solution. I trimmed the lip off the tray then rounded the corners with the dremel. Simple, sturdy and completely removable. Couldn't find it at Walmart, Target, or Ebay but Amazon still has them: https://www.amazon.com/Rubbermaid-3318-20-Automotive-Organizer-Hanging/dp/B00S9LK9MQ/ref=sr_1_4?crid=3TUXQPGN4FF3M -
I've also noticed that older Jeeps tend to wave more often. Seems like half of the new Jeeps on the road out here are driven by soccer moms. I have never seen a soccer mom give a Jeep wave.
I think what you are looking at in the pic is the hidden winch kit with a separate brush guard mounted to the front of the bumper. I can't find an OEM part number for a guard/winch combo. Warn used to make one but it's been out of production for ages. This is the Warn Trans4mer kit:
