Everything posted by Steve Gregory
Try it without a tilt column, real PITA
Bucket Seat Back Lever Stuck
Steve Gregory replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
I understood it :thumbsup: -
I have a short bed and i picked up a brand new tank for about $95 shipped to my door
20 now, 21 in June :cheers:
Let me know how well the floor pans turn out from Classic 2 Current, I'm wanting to go through them
What size bulb did you use for the heater control? every LED I've used was too long for the housing
- 132 replies
- eliminator
- 3link
(and 2 more)
Tagged with:
Thanks for posting this!
Here is a link to make your own harness, if you're ever so inclined. http://gojeep.willyshotrod.com/HowtoHeadlightLoom.htm
I replaced the lights in my dash with led's, no problem yet. That is odd though
Great thread, I can't wait to see the results!
- 59 replies
- leaf spring
- bushing
(and 2 more)
Tagged with:
99 Cherokee front axle and transfer case swap
Steve Gregory replied to MJ Hammer's topic in MJ Tech: Modification and Repairs
The only way you'll find a rear axle that fits directly, without at least moving the spring perches, is from another Comanche. And the only reason to swap one MJ axle to another (other than to change ratio) is if the replacement is a Dana 44. Good luck finding an MJ Dana 44. I found an MJ specific Dana 44 on craigslist....for $400.... :eek: :eek: -
What a transformation!!!
I'm looking for a red full center console, if you have one and want to get rid of it, message me!
I have a 94 parts XJ with a 95 AX15, I want to mate it with my 89 242 t-case, I believe I just need to change the input shaft on the t-case to the 23 spline correct? Any answers will help! Thanks
Is there anyone out there with a Dana 44 limited slip?
Superduty MJ
Steve Gregory replied to dustyinthedirt's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Nice!!! Excited to see the progress -
This is a great build!!
I got my first gallon on Amazon, I love the way it works.
Interior lights ain't workin
Steve Gregory replied to Jackrabbit41's topic in MJ Tech: Modification and Repairs
Definitely, always check fuses first, even before posting. Then go more intrusive if that doesn't work. -
Help! Don't know wiring!
Steve Gregory replied to MJ Madness 87's topic in MJ Tech: Modification and Repairs
Unplug the whole rear lighting harness. I had similar issues on my old truck. -
Washer Fluid Pump
Steve Gregory replied to Steve Gregory's topic in MJ Tech: Modification and Repairs
Sorry, 89 Sport Truck -
Does anyone know where to get a washer fluid pump with a sensor? i looked online at Autozone's website but it doesn't say if it has the sensor or not. I want the sensor so i can have the light turn on when it's low. I know I can tell its low by the amount it sprays, but i like things to work correctly. Also, besides from adding the light to the gauge custer, what else do i nee? i noticed three different connectors for washer fluid pumps next to the one that's plugged in
