6
I failed to mention that I used the tailgate handle and just got longer bolts that way you wouldn't pull the bolts through the holes, if you got any questions just let me know.
I don't have any pictures but I took out the screws for the tailgate handle and made a bracket that I could attach a couple ratchet straps to, then I hooked them to the factory bed tiedowns and pulled it forward until it was straight.
My 87 sportruck
Strokermjcomanche replied to Strokermjcomanche's topic in Member Projects: Your Comanches
So when they installed the window they used beutyl tape and held the window in with screws(it was a mess ) , probably the reason it was leaking and rotted out the floors . So after pulling the window I cleaned all the old crap out and got lucky as there was no rust . I used a rear window from my very first Comanche, the seal was ruined on this truck from the aftermarket slider so I had to use a spare seal I had . Its supposed to rain the next next few days , so if I have no leaks I will be able to install the interior. -
They had just enough parts to make one more in 2009 .
My 87 sportruck
Found the source of the water leak, time for a new back glass ( The correct one) . Surprisingly there's no rust there, I don't think they used urethane for the window. -
This one ?
Serpentine Belt suddenly loose.
Strokermjcomanche replied to QCComanche's topic in MJ Tech: Modification and Repairs
My guess is that the collar broke on the long bolt for the tensioner -
Steering Box Brace/Spacer
Strokermjcomanche replied to WahooSteeler's topic in MJ Tech: Modification and Repairs
Yes they are all supposed to have one, even if it's not power steering. -
As much as I want , it's not going to happen . https://m.facebook.com/marketplace/item/227314391656556/?ref=browse_tab&search_query=Rooftop tent&tracking={"qid"%3A"6813159696437830005"%2C"mf_story_key"%3A"2729760980453101"%2C"commerce_rank_obj"%3A"{\"target_id\"%3A2729760980453101%2C\"target_type\"%3A0%2C\"primary_position\"%3A-1%2C\"ranking_signature\"%3A0%2C\"commerce_channel\"%3A503%2C\"value\"%3A0%2C\"upsell_type\"%3Anull}"}
Rebuilding/Restoring 1987 Comanche
Strokermjcomanche replied to nateppler10's topic in MJ Tech: Modification and Repairs
By advice would be go buy yourself a full service manual, preferably preferably one from a dealership -
Keyparts pan fit really well for my MJ , way better than a c2c pan .
My 87 sportruck
My 87 sportruck
Other side welded , seam sealed and rust sealer /preventative paint applied.i'll try to get it's painted tomorrow. Then sound deadening. -
Speedometer Fluctuations
Strokermjcomanche replied to j_gevans's topic in MJ Tech: Modification and Repairs
The cable is probably sticking a bit, probably need to lube the cable or replace it -
That got there quick!
Full console I'm guessing?
I've heard there are 3 of those currently in the NOS flavor
MJ Leaf Spring Eye Bolts
Strokermjcomanche replied to Dzimm's topic in MJ Tech: Modification and Repairs
WJ has the same bolts for their control arms I believe ,some of the vans do ,there's a lot of vehicles that have the same bolts if you have a junkyard nearby . My yard normally gives them to me for free. -
Sometimes the front crossmember has the Vin number stamped on it as well for another place to look. It'll be in between the bumper in the front of the crossmember generally towards the driver side,sometimes it hides behind that lower valance peace.
Have you looked for a build sheet that's normally hidden somewhere in the interior?
ECU Bracket nut size
8mm hold the Ecu to the bracket and 10mm hold the bracket to the firewall -
My 87 sportruck
Thank you Ben
