MiNi Beast
Everything posted by MiNi Beast
  1. bad black or white?
  2. noted. thanks for sharing
  3. big green egg shake or fries?
  4. if you lift your mj and get big tires you can just sleep under the mj. works better for pulling trannys as well.
  5. if you ensured all air has been purged from line then you should be fine. 20-60 psi is normal. inline engines have a pressure build up different then typical v6 setups and part by design with spikes. i would switch to 5w30 for sure. but also consider age of your rings as well and if get bored, pull your pan and check the journal's on your crank. otherwise run it till she don't run no more enjoy.
  6. check driveline speedo cable
  7. congrats.
  8. there are none. even most kits available have been added to or parts swapped out for betterment. best to source parts individually per you desired build specs, to ensure complete installation of quality build.
  9. i have a set of these but took them off cause the drivers wouldnt stay in and as i can see they had clips. but these were my favorite compared to the plastic stick on ones that i keep breaking off.
  10. leaving early and just driving east.
  11. i have rear solid window but no heat bars.
  12. perhaps but not sure. thinking its in a rely for delay. factory setup just ran wire to feed at body plug.
  13. yeah i have a swap xj harness in and use that rear defroster time relayed switch to run my rock lights. stays on for like 10 mins and only when key is on. i need bulbs so thanks for the number eh.
  14. winter storage.
  15. so any updates or are you a liar?
  16. well, i like simple. keep us updated.
  17. so what are you doing to aide in the un wanted movement of the stock mounts?
  18. i was reading about different types of rubber and poly mounts as i am in need of solid mounts with yet another failed factory motor mount. will you post a ref pic by chance?
  19. my brother has a rotten framed chevy avalanche that runs good with a slipping tranny that could be replaced with an ax 15.
