MiNi Beast
Everything posted by MiNi Beast
  1. are you emission control state? if not just eliminate it.
  2. you know i had this same shell it came on my little blue mj. had a crack in the roof but all the glass i think was good yet. i wonder about it now, as i may still be able to get to it if its sitting where i last remember. its on the farm though. ill check for the glass. i wonder if it be worth have the fiberglass work done.. not that I need a long bed shell as my aluminum one works. i did rather appreciate the head room room though with these versions. would be nice all lit up, with some carpet on the bed. good bit of weight on the rear as well. if that matters (it does)
  3. no. discover and discoverer are different. cheap tire at walmart, do you think you should buy tires from the same place that sells baby wipes?
  4. went hunting for a couple days and come back with a bellhousing and clutch/flywheel. no deer yet.
  5. or cooper discovers. they're a good tire as well.
  6. wear fast. ran a set on my ford. had one blow out replaced and went to cali and back and was bald. they are cheap as to be cheap tire to get you by or just sell with "new tires". if wanted to be cheaper side look into treadwright.com good reviews.
  7. indeed you did. trail spares.
  8. good deal. lets party...
  9. what about that libby face upgrade?
  10. dog eats what i eat, meat and potatoes.
  11. i show up and work on it. my dog and I need a winter getaway. got food?
  12. I'm just awaiting morning on hunt for such a buck. need some jerky meat.
  13. good news i just bought a new pointed shovel.
  14. may need shims under the leafs to correct angle. angle finder is your friend here. and with the new leafs, are they in properly. front to back that is?
  15. food and trail maintenence. I'm there.
  16. now that there is pirate talk. argh!!
  17. i so do not miss drum brakes. did them cylinders enough to say I'm good but prefer swapping out bad calipers.
  18. nice. the removable cross section will be nice. as i contemplate how ill be swapping tranny with a fully welded Crossmember. coming together though.
  19. they are nice. my mom had a set in her car. great in the winter time, before they had butt warmers.
  20. chitty.
  21. sweetness. I'm hungry.
  22. grab glass with your hand and pull up while slowly cranking it. the handle crank strips out and can be easily fixed with a new crank handle. uni at parts store. i personally just use one and swap sides to close windows. but I'm not running doors m9st of the time to bother fixing legitimaly.
