MiNi Beast
Everything posted by MiNi Beast
  1. wade is a sexy mofo. 1000 post
  2. sweetness. did good Pete. damn stove pipe looks to big for the stove. wheres that heat reclaimer??
  3. so added a "junk hideaway colset" (more likley for the womens "extra shoes" literally. ) and then finished her light install and got the switch mounted. either way shes happy and will keep feeding me steak so ill be happy.
  4. swap column easiest. and relatively straight forward and tilt is nice. other wise as long as they work get some rain x and be happy . sucks when they don't work at all.
  5. clutch disc on backwards
  6. clutch disc is bad perhaps. bad syncos in trans itself. is it in any gear or just 1-2?
  7. so have you considered just swapping out the lifters or the collapsed one at that.? be quicker then swapping a engine.
  8. at least a damn cheese platter!
  9. surly when you buy $5 buckets.
  10. surly. ill be around playing in the UP. as long as there's food ill be there.
  11. MiNi Beast
    RR Caboose?
    choo choo goes toot toot
  12. umm if they don't line up then yeah have to cut and weld on for proper fitment.
  13. MiNi Beast
    Dogs!
    MJ
  14. cool. j check out his youtube channel.
  15. na just the kid that always tried putting square block in a round hole.
  16. long way for them cookies to drop.
  17. caribbean eat or drink?
  18. MiNi Beast
    Winches
    I'm always ready to post pics of my setups. i ran a ramsey 8000# with rope for the good part of its adventure workouts. slow but out pulled anything i could use it for. just slow due to thick gear lube packed in it and you get that with alot of them winches that are on the cheaper side. not as big a deal in warm climates but worse in the colder areas. no biggie just swap out to better lube. ramsey has my vote. with that said i got lazy and wanted a bit more reliability and faster line speed and this led me to go with warn as a reliable setup and now have versions more budget friendly with same reliability. so i looked to morris4x4.com as they had a decent online offering and i was able to pick a warn vr-8 up for under $500 and to my door in under a week. I'm very happy with decision. i was looking at the smittybilt x20 with wireless remote, which my buddy picked up just before i got mine. i was after the same but for about the same price i opted for the warn that i can add wireless remote to later on. he has been putting his winch to the test and have several pulls in vs mine. and i support his winch choice as have been tested well and proves reliable. so i suggest either option. rope is nice as i have enjoyed the safety factor and less the extra 10# from the cable. i however went with cable on the warn as cable is more reliable and holds up better with abrasive resistant, i use mine as a tool that sometimes pulls me out. so makes more sense to use cable with wrangling logs and muddy workouts. also cable holds up better to sunlight, uvs or something. so if get rope consider a cover. alot of info out there on winchs, did alot of research but was all about numbers and etc, i wanted real world applications of tested and proven. warn and smittybuilts are most common among those i wheel with and see firsthand. so id stick to them. other wise anyone will work. just a matter of it working when you need it to. some people can't justify 1k for a winch that gets used maybe once in a year, (but it works when you need it too) others say 350 is good if pulls you out once. lol either way having a winch is just something everyone should have as an all purpose tool on the shelf.
  19. with beans red or white sauce?
  20. vhs all day. steak or chicken?
  21. butt warmers are nice when run no doors.
  22. good job Pete.
  23. i have one i just pulled from my jeep. you can have it just cover shipping.
