114
Everything posted by Pete M
what about General Spring?
laptop or phone? for a laptop you want to zoom in to where you want to drop the marker, then click on the "add marker" icon. then click there and fill in a title. it doesn't have to be your actual house. you can drop it in a city center or wherever.
Odds and ends - Advice requested
Pete M replied to JZLAJeep's topic in MJ Tech: Modification and Repairs
I've never found a factory jack I liked. I put a cheap 2ton hydraulic floor jack in everything now. doesn't fit the MJ cab very well though. I store mine in a box in the bed. my 88 still has a carpet dash cover I bought 20 years ago. infinitely better than a cracked dash. I've seen those rims call "10 hole" wheels. if it had the little fake rivets it'd be an Eliminator rim. If they aren't all corroded, I'd definite;y be happy getting them for a little over 100. if the carpet works for you, I can see it being worth 75. but I'd need to see it in person. -
heck yeah!
new A/C Evaporator is... not quite right.
Pete M posted a topic in MJ Tech: Modification and Repairs
part number checks out with what the manufacturer says it goes to, but those ports are definitely not in the exact same location (even thought hey are spaced apart from each other the same) and that interferes with the plastic on the hvac box. did I get a 97+ or something? -
I keep forgetting about that. do we have it as a writeup in the DIY yet?
bananas. owls or hawks?
interesting. admittedly the lists we get back from chrysler are rarely complete and are fraught with reused codes, but that's the first I've heard about the tach code being wrong.
no, that code is usually wrong. I went through and edited it for ya. do double check your axle ratio. it definitely wasn't the 4.78 that was previously written there but it might not be 4.10 either.
done.
make sure they are the correct "J" keys (stamped on the key). earlier AMC keys look similar but are not usable. correct year keys can go much higher on ebay depending on supply at any one time (it fluctuates widely).
10"wide rims PLUS adapters? crap that's a lot of tire sticking out.
wouldn't that be a 5 on 5.5 bolt pattern? either way it is stronger than a 44, but marginally. I'd still lump it in the d44/8.8/97+8.25/9" family. V8 capable for sure, but not dana 60 levels of strong.
score!
yeah, a cover really cleans it up.
oooooooo! doesn't help me since I was replacing the dash anyways, but we'll need to add that link to the DIY forum (unless it's already in there and my brain just sucks ) so others know it's a possibility.
lots of variables going on here. what's the tire size? bolt pattern? what's the backspacing? 10" wide is a heck of a width. got the lift and axles and gears to support them? just because it's a good deal, doesn't mean it's a good idea.
the stock posi is a clutch based unit and after it wears out, it will do the same. but they are kinda rare so it's probably just open.
If I had the choice between the 2, I'd prefer an LS for all the modernity it brings.
looks like a Fey Westin aftermarket bumper.
oh, just remembered I got my "SUV" box from Lowes many moons ago. it's too tall for you, but I seem to remember they had a smaller version. super heavy duty for a plastic box.
