kriswinner
1065 profile views
kriswinner's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. That's what I'm looking for. I was planning on removing the metal trim (permanently). Thanks for the quick replies!
  2. I'm going to have my windshield replaced by Safelite and move to the rubber trim. In an effort to minimize the confusion, am I best off reserving the glass and install as a 1998 Cherokee? For those that have had this done, should I remove the metal trim and clips beforehand or is this something a competent installer should just be able to handle? The prices *are* different between a 1988 Comanche and a 1998 Cherokee. (Cherokee is cheaper.)
  3. Sorry to dust off an old thread, but someone else might have this question as well. I've got a small fuel leak in the hose on the gas tank side of the fuel filter. I'm planning on replacing both sets of hoses, clamps, and the filter. @cruiser54 When you mention 5/16" and 3/8" high pressure fuel hose, I'm assuming that one end of the filter is one size, the other end is the other. Is this correct? Just want to make sure I purchase the correct stuff.
  4. Yeah...if you're burning through wiper motors, you probably have bigger problems.
  5. That's a smart idea. I like the idea of being able to swap things out (or remove them all together).
  6. @Airborne Janitor: Love the idea of this update/upgrade! Great work! One question: Now that you know this works (I understand this wasn't originally a guarantee), would it make sense to modify the MJ wiring (install the plug end from a "newer" XJ) instead of modifying the connector on the new wiper motor? If the wiper motor ever goes bad in the future, this would make the future swaps plug-n-play.
  7. Thanks for the suggestions, Everyone! @Pete M Pelican boxes... wow...you weren't kidding.
  8. It's a 1/3 fold. (last section by cab can't lift) Preferably it would be something that is easy to remove if I need the entire bed.
  9. I have a tonneau cover on my MJ and I'd like to add some sort of storage container for tools and other miscellaneous things to the bed. Whatever I do would need to be beneath the tonneau. Suggestions?
  10. 1988 Tan: Palomino (15323) confirmed.
  11. Good idea. I didn't realize there were so many possibilities. Based on the history of my truck, the panels should be all original from the factory. I think I know someone with an SEM color guide. I'll see if I can borrow it. For an 88 with original panels, it seems like I'm one of 2 SEM colors: Palomino or Santa Fe
  12. It wasn't mentioned specifically, but is 1988 Tan the same as 1987 Tan? From Minuit's "post from the future", it sounds like... Thanks! KW
  13. Alright... totally deserve that. Previous owner (or probably the previous previous owner) did some hokey things to secure the bedliner. I was lazily trying to avoid pulling it out of I didn't have to.
  14. Just confirmed from previous owner... He did a 4WD swap and changed out the bench seat for bucket seats from a Cherokee. The work was very well done. I had no idea.
