Pete M
Administrators
    114
Everything posted by Pete M
  1. every project has surprises. I did the swap near 20 years ago so I'm sure there's something I'm forgetting.
  2. the speakers I put in the KJ and the Cruiser were about 25-30 a pair. plenty good enough for a radio with an internal amp. of course in the KJ I stole the rear outputs and fed them into a cheap "1000w" amp for my subwoofer. there's no way it's actually putting out 1k, but it's good enough for a noisy diesel Jeep.
  3. I have a TJ trans/t-case in my 88. you'll want to reuse your MJ shifter handle assembly. bellhousing is fine. the TJ trans will clock (rotate) the t-case up a bit closer to the floorboards. mine is very close but never touched. and I appreciate the bit of extra ground clearance. far as I know your trans mount assemblies should work fine with the new trans. I had a peugeot before and so had to invent a bunch of that because the pegeot and AX-15 share almost nothing. the SYE is not recquired at only 4" of lift, but it is a good strength upgrade. now;s the time to do a good looksie into the health of the new AX-15. you don't want to install it and then find out the gears are all chewed up.
  4. I'm not sure I can even get the crossmember to separate from the transmission without a sawzall. but I'm doing a 4wd swap and I have a spare crossmember so I guess I don't need to.
  5. superduty axles are very popular these days. they are becoming semi-plentiful in the junkyards. just make sure you don't accidentally buy the dana 50 front axle, which was used in some superdutys. they all have a metric 8bolt wheel pattern, so I would grab the 10.5 rear axle to go with it. (I think it was the 10.25 that was the smaller axle used on some). my buddy had an '03 with the 60/10.5 combo and it tore me up a little that he junked it after the accident rather than build something with it. https://torqueking.com/category/2005-2016-ford-dana-super-60-front-axle-id/#:~:text=Ford uses Dana Super 60,F550 Super Duty 4x4 trucks.
  6. excellent job. I need one of these in my life right now a lot of my stuff is outside under a tarp canopy.
  7. Pete M
    1JTHS6613GT094205
    oh right. I knew that.
  8. Pete M
    1JTHS6613GT094205
    @eaglescout526 no dealership on this one?
  9. rotted battery cables smashed crossmember smashed oil pan radiator and heater core full of rusty nastiness instead of any trace of antifreeze tail harness hacked up so bad none of the lights worked right it's hypothetical of course, because the answer is: all of the above. this poor truck suffers immensely from a condition I call previousowneritis. but all of these items (and many, many more) will be fixed before handing it back to the owner.
  10. with less than 20,000 in existence, all MJs are special.
  11. how on earth is it that I can't find a 3rd-brake/cargo-light unit that's flush mount? everything that I find has depth and requires cutting a giant hole. and things that are flush only do brakes or cargo. and yes, I'm sure it's because they are simply replicating factory units (where the trucks already have the hole). I'm just frustrated that more people aren't looking to custom wire their trucks to justify the aftermarket getting off their butts and making the thing I want.
  12. the 91-92 sportrucks decals (the squiggly ones) are rare, but that's mostly because all 91-92s are rare.
  13. Pete M
    Junkyard Haul
    Dakota.
  14. yeah, just a dribble. I prefer to put the gas into a small cup first so I have more control over the pouring.
  15. Pete M
    Junkyard Haul
    brand new dak lights are cheap.
  16. have you tried dumping fuel into the throttle body?
  17. not the relay, the pump resistor. did you mess with the resistor at all?
  18. I've heard of pumps being able to build pressure, but have no flow behind it. might be time to test for flow. did you say you applied 12v to the pump resistor?
  19. does it start then stop immediately as if the key was turned off? or does it chug a bit and die? does it turn off when the key is turned back to run? or does it stay running for a second or 2 longer?
  20. the maintenance light is literally just on a mechanical timer. it's purely a reminder that the 02 sensor should be replaced every 75k miles (and so it pops on after 75k and then you need to replace the timer itself which is the clear thing with all the gears located under the dash). it has no other function. you're thinking of the OBD1 system that started in 91 with the HO.
  21. https://www.ebay.com/itm/221101305580 not entire sure if this matches anything in an MJ the tans all looks the same to me.
  22. the cheapest aftermarket speakers available are better than the factory. can't go wrong really. but if you feel an amp is in your future, then you need something worthwhile.
  23. either way, they look darn good
