Pete M
Administrators
    114
Everything posted by Pete M
  1. nice! I would contemplate some 1.5" spacers for the rears. something about the 7" steel rims seems to make the MJ's wide butt more obvious to my eyes.
  2. dang well, at least you caught it before it caught fire.
  3. vid on the f35. it's like living in the future.
  4. wheel bolt pattern and overall tire size are the limiting factors you're going to run into. the 17/18" measurement itself isn't a hindrance.
  5. oh, and when you figure out where you want your work bench desk, put one of these above and put it on a dimmer. I bought one for my mom's laundry room and she loves it. https://www.lowes.com/pd/Lithonia-Lighting-I-BEAM-15000LM-4000K-LED-High-Bay-Light/1001568698
  6. truth. we put lights in the barn (8' ceilings) every 3rd joist and I still want more. (unfortunately it was done juuuuust before LED shop lights exploded on the market and so they are merely next-gen florescents.) I'm thinking on slapping a bunch of tape LEDs along the rest of the joists.
  7. any 2.5L engine throughout the entire XJ run will swap right in.
  8. did you test any of the items or just replace them?
  9. only the AX-15 has a different crossmember. all others use the same one. XJ and MJ shifter assemblies are the same. TJ and YJ transmissions will clock the t-case up a bit. pull the electric parts out of the t-case and insert the mechanical bits. far as I know all AX-15s use the same clutch.
  10. I've always admired my nephews' ability to sleep soundly in positions I couldn't fold myself into while awake.
  11. manual trans? I ask because fluid leaking down from the master cylinder and getting into the fuse box can cause weird things to happen.
  12. I'd assume that they are wired with resistors so as to be compatible with the regular blinker pot, but haven't heard anything concrete yet. I'm very sure that some custom wiring is necessary.
  13. it made mention that the ones shown were prototypes.
  14. MJ and XJ rear wheelwells are different and so the flares are also different.
  15. if you can see the white underneath, it's sun damage to the plastic itself.
  16. Comanches and Dakotas do not share frames. not sure what we can do for you.
  17. jobs have a nasty habit of getting in the way of free time. I assume this new gig is a bit easier on the body?
  18. headlight adhesive is what I've seen most recommended. shouldn't need anything done after that.
  19. I wonder how they connect to the factory harness...
  20. What size tires do you have?
  21. LBs are overall a foot longer than SBs and that's divided into 6" longer in front of the rear axle and 6" longer behind it. note how fullsize trucks do not have the same equal split when going from SB to LB. they put the entirety of the extra bed in front of the rear axle. honestly I don't think either distance will matter more than the fact that you're towing with a 30+ year old tiny soup can. meaning both wheelbases are equally good-ish.
  22. technically a shortbed might be better for towing since the pivot point of the ball will be 6" closer to the rear axle.
