How to get this screw out
  • Replies 235
Posted Images
Realistic:
Get something like this, pry it back straight, and unscrew it like normal.
Image result for mini crow bar
Unrealistic:
Tack weld a link of chain to the head, and use a tow strap through the passenger window connected to another Comanche to yank that sucker out loose tooth style.
Image result for funny loose tooth string trick
Epic:
Leave it, paint that bad boy gold, and clearance the a-pillar trim so that it can be seen and enjoyed for years to come. It is ComancheClub famous at this point after all! :L:
1144TT Metallic Gold Enamel Paint
13 minutes ago, ghetdjc320 said:
Somehow you got the trim off with that screw still in there so why remove it :dunno:. You can just bash it back on.
LMAO
I had a 1991 F-150 that had the countersunk bosses break off the plastic windshield pillar trim.  That meant none of the OEM screws would retain the plastic.
I ended up using sheet metal screws that had an integral washer to span the now oversized hole to mount the plastic trim.
Boy Ford used some really bad plastic resin for their trim back then that got SUPER brittle in the AZ 😡
