89 MJ 5spd ax-15 start lockout?
As was stated, this is primarily in newer cars.  A lot of newer jeeps (primarily wranglers, but some others might have this too) also purposefully left it so you could use the starter in 4 low while in gear as a feature so that if you stalled in a tricky obstacle, you could start it in gear to help you crawl without having to do crazy stuff with your clutch and potentially get you in a worse situation.
My 02 TJ had a lockout......it was easily bypassed by inserting a 5A fuse in the "trans" slot in the fuseblock, LOL.
Both of the Focuses I have (01 and 03) have them too.  I had to pull the contact switch connector off and jump them with a short piece of wire to bypass them.
15 hours ago, Eagle said:
I just received confirmation that Mike from NJ's red XJ, which we saw on many, many NAXJA NAC trail rides, is a '92. It had the clutch/start lockout.
Interesting, thanks Eagle.  I know I remembered seeing it before on earlier XJ's, just couldn't remember year range.  Pretty sure I drove that red XJ at least once too.
Rgds,
Andy
