jeeptec1
1037 profile views
jeeptec1's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. I ended up selling the long arm kit to a buddy of mine who has a Cherokee. Then sold the Comanche. I really liked my Comanche but realized I was not going to use it the way I wanted to. I needed a vehicle that can tow 5500 lbs. Comanche was good for 2500. I did buy a WJ so I did NOT leave the Jeep family. Sent from my iPhone using Tapatalk
  2. If you have a 4.7 don’t over heat it. Maintain your cooling system! Sent from my iPhone using Tapatalk
  3. 88 Comanche long bed 4.0 4x4 automatic. I’m getting close to do my spring over. That way I can get rid off all the add a leaf’s and longer shackles. My question is will my driveshaft be long enough to use until I do my slip yoke kit with a double Cardin ujoints at a later date. Sent from my iPhone using Tapatalk
  4. Has anyone done the Volvo G80 locker swap into the front Dana 30 on a Comanche. There are several old articles out there and a few YouTube videos from years past. The Volvo locker is 1/2 the cost of a truetrac and other lockers. I’ve read you do have to 3/8 inch off the left side axle shaft. Not a deal killer! Sent from my iPhone using Tapatalk
  5. Wow my simple question turned into A great chat about other options other than the 95/96 booster upgrade. Thank you all. Eric Sent from my iPhone using Tapatalk
  6. Thanks cruiser54 on the tip. That brake switch looks like what I used on my 87 XJ 15 years ago. I did the rod modification on my 88 MJ. I sold my 87 XJ 12 years and have forgotten most of everything Sent from my iPhone using Tapatalk
  7. Does anyone know if a steering gear from a 97 XJ fit an 88 MJ? Sent from my iPhone using Tapatalk
  8. My 88 Comanche I did the 95/96 power booster upgrade. Well after a couple of years the booster is leaking down vacuum. I just acquired a 97 Cherokee rolling body that still Has the master cylinder and power booster. Will that one bolt up like the 995/96? Sent from my iPhone using Tapatalk
  9. Has anyone stuffed a Dodge truck 9 1/4 diff under there Comanche? Sent from my iPad using Tapatalk
  10. There was an old article years ago on the NAXJA forums for Renix performance tips and tricks. 1 I remember is to relocate the intake temp sensor from the intake manifold of course plug the hole. Extend the wiring. Relocate to either intake tube or intake box. The article stated the computer will think it’s cooler and add a little more fuel for better performance. The article stated Renix engine run on the lean side. Has anyone done this. I know most modern vehicles that use an intake temp sensor are running on the intake tube not in the manifold. Sent from my iPhone using Tapatalk
  11. 91 is obd 1 96 is obd2 May not working. Sent from my iPhone using Tapatalk
  12. No toss them Sent from my iPhone using Tapatalk
  13. Look up cruiser54.com. All the info is there Sent from my iPad using Tapatalk
  14. Thorley headers had made a few prototypes in the early 2000’s for the Renix engines it I don’t think they went into production. I was living in So Ca at the time and they used my 89 Comanche as one of there test vehicles. Sent from my iPhone using Tapatalk
  15. Does anyone know if the map sensor also reads barometric pressure on the Renix fuel injection. I know in the Chrysler injection the map sensor reads both. I’m fighting some drivability issues on my 88 Comanche. I was able to borrow a Chrysler drb2 with the Jeep/eagle diagnostic connector. I found my map sensor reads I have 11.7 hg +_ of vacuum when running my mechanical gauge shows 17 hg. The weather app shows barometric pressure for my area is 29.78 the drb shows 28.2. Yes I’ve done the cruiser54 vacuum line and fitting modification on the throttle body. Sent from my iPhone using Tapatalk
