RestoringNV Posted July 14, 2018 Share Posted July 14, 2018 Just what can be done, to lower the interior temps of our Comanches? Here I thought, that my late model Cherokee was bad, it does not 'hold a candle' to a Comanche!!! FYI: My Comanche is now, all Legal Eagle inspected and finally ready to rumble! Quote Link to comment Share on other sites More sharing options...
Alexia Posted July 14, 2018 Share Posted July 14, 2018 Blast the air conditioner or roll the windows down. I have to strip to bare feet when I drive mine. Quote Link to comment Share on other sites More sharing options...
8valvehero Posted July 14, 2018 Share Posted July 14, 2018 Short of installing AC: 1” of jute padding under the floor and 1/2” behind the firewall helped loads for mine. Resealing the damper box and cutting flow of coolant to the heater core in the summer are also critical. Good luck! Quote Link to comment Share on other sites More sharing options...
Minuit Posted July 14, 2018 Share Posted July 14, 2018 Tinted windows will help. Knowing the tendencies of our trucks to leak water onto the floorboards, I'd be very wary of putting things that absorb water on the floor. Duct insulation would keep some heat out, and foil-backed mass loaded vinyl would block both heat and sound. Of course, working air conditioning is better than any of the passive options. Quote Link to comment Share on other sites More sharing options...
8valvehero Posted July 14, 2018 Share Posted July 14, 2018 7 minutes ago, Minuit said: Knowing the tendencies of our trucks to leak water onto the floorboards, I'd be very wary of putting things that absorb water on the floor. LEGIT Quote Link to comment Share on other sites More sharing options...
Crash Posted July 15, 2018 Share Posted July 15, 2018 A good quality tint. Quote Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 15, 2018 Share Posted July 15, 2018 A sunroof really helps while moving.... Quote Link to comment Share on other sites More sharing options...
johnj92131 Posted July 15, 2018 Share Posted July 15, 2018 Properly working A/C will be the best thing to cool the truck interior. No doubt about it. Quote Link to comment Share on other sites More sharing options...
ParadiseMJ Posted July 15, 2018 Share Posted July 15, 2018 It's been damn hot here, 100-105 highs for over a week (and the forecast isn't any better). My commuter car is down with a mystery misfire issue so I'm driving the MJ to/from work. The MJ A/C is barely working. After the truck is sitting in the parking lot for 8-9 hours it is blazing hot. Driving the 20 mile home is brutal. Last week I put on a wet shirt for the 1/2 hour drive home, shorts, no shoes. Problem solved. Quote Link to comment Share on other sites More sharing options...
75sv1 Posted July 15, 2018 Share Posted July 15, 2018 Not sure if this would help. I have a 75 Bricklin. They can and do run HOT. I noticed heat coming through the trans tunnel. When I pulled the engine and trans, I painted the trans tunnel with ceramic paint. It seemed to help. I also, put some aluminum faced insulation on the firewall. Ceramic coated headers helped keep underhood temps down. Quote Link to comment Share on other sites More sharing options...
87MJTIM Posted July 15, 2018 Share Posted July 15, 2018 I have found that leaving the windows open .25" to .5" lets the hot air vent out. Also, a sun shade helps. Quote Link to comment Share on other sites More sharing options...
Dzimm Posted July 16, 2018 Share Posted July 16, 2018 Working A/c is the best thing. If you have a rear window, open that sucker up, it will suck air back into the cab and feel good on your back/neck. Just don't have dirt or leaves in the bed or it will fill the cab. Agree with the above about leaving windows cracked a little and having tint. Quote Link to comment Share on other sites More sharing options...
DesertRat1991 Posted July 16, 2018 Share Posted July 16, 2018 No A/C here. By now, you've probably discovered that the vent setting on the cab blower is useless -- unless you like being blasted with hot air from the engine bay. The rear slider helps a lot. I honestly don't know how you guys without rear sliding windows survive. The truck would be undriveable without one, IMO. In the summer time, I usually take the bed topper off to maximize air flow through that window. Whenever I see guys trying to reduce cab noise by going crazy with Dynamat and new door seals all I can think is --- what's the point? All the windows need to be open anyway..! Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 16, 2018 Share Posted July 16, 2018 1 hour ago, DesertRat1991 said: Whenever I see guys trying to reduce cab noise by going crazy with Dynamat and new door seals all I can think is --- what's the point? All the windows need to be open anyway..! Maybe in AZ... In the winter I'm often wishing I changed the door seals to help keep the heat in. Quote Link to comment Share on other sites More sharing options...
Pete M Posted July 16, 2018 Share Posted July 16, 2018 I assume there is a headliner above you? Quote Link to comment Share on other sites More sharing options...
RestoringNV Posted July 17, 2018 Author Share Posted July 17, 2018 My truck has AC, but it does not work. I bought this truck on April 28th, 2018 and I haven't yet tried to clear the heater plenum of a Mickey Mouse nest. So the AC idea, must wait. I can not add a sunroof, due to the JCR Off Road roof rack, will hinder its opening abilities. I have thought about, somehow installing a 12v fan, within the tranny tunnel, but I have yet to locate a suitable fan, to even buy one! My rear slider, functions, but my spare tire, blocks some of the air flow and yes, I have already discovered that whatever is in the bed, it does find its way through the split window! And yes I have a headliner, but it needs reupholstered. I plan to replace the rubber seals as well as fully removing the interior and adding Killmatt to most surfaces. I also will add Napier hood vents, in order to help evacuate some of the under hood ambient temps. Quote Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted July 17, 2018 Share Posted July 17, 2018 Central Florida. No A/C. Haven't had time to try to play with a/c components. No vent windows (yet) No rear slider No sunroof (yet) No floormats or and heat shielding anywhere. Has headliner I do use the a/c vent sometimes the hot air blowing is better then the hot stagnant air... but Friday it stopped working on me again... bugger... Heat level in this thing... some people would just say undriveable. Me.. I'm too stupid and/or proud to own this thing. Daily driving in this stupid heat. Still am! LOVING IT! Quote Link to comment Share on other sites More sharing options...
AZJeff Posted July 18, 2018 Share Posted July 18, 2018 I am reading the interior on my MJ, and part of my planned improvements is the foil lined insulation matting glued to the inside of the roof above the headliner, and on the back wall of the cab behind the carpet panel. Most at of your added heat comes from solar input, and while tinting the windows helps, adding thermal insulation in the roof in particular is really key. Quote Link to comment Share on other sites More sharing options...
carolinajeepman Posted July 26, 2018 Share Posted July 26, 2018 I wired in a USB hub with a switch and 2 USB fans I bought from amazon in my old XJ that didn't have working AC. It worked pretty great. Here's the exact fan I bought: https://www.amazon.com/OPOLAR-Enhanced-Rotating-Adjustment-Personal/dp/B0776VGFDL/ref=asc_df_B0776VGFDL/?tag=hyprod-20&linkCode=df0&hvadid=242051162351&hvpos=1o4&hvnetw=g&hvrand=2335242354016974309&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9009983&hvtargid=pla-398574575937&psc=1 Quote Link to comment Share on other sites More sharing options...
RestoringNV Posted July 27, 2018 Author Share Posted July 27, 2018 Killmat will be applied this weekend, provided that I can remove the seats and carpet. I purchased the 300 mm closed foam kit from Amazon. 2 kits, consist of 36 sqft. total. This should be a huge improvement. Quote Link to comment Share on other sites More sharing options...
RestoringNV Posted July 27, 2018 Author Share Posted July 27, 2018 Does anyone know where I can purchase, dash pad carpeting. My dash pad is pretty cracked, due to years of heat, in Mojave country! Quote Link to comment Share on other sites More sharing options...
DesertRat1991 Posted July 27, 2018 Share Posted July 27, 2018 11 hours ago, RestoringNV said: Does anyone know where I can purchase, dash pad carpeting. My dash pad is pretty cracked, due to years of heat, in Mojave country! https://www.covercraft.com/us/en/product/original-dashmat-custom-dash-cover.DMC Quote Link to comment Share on other sites More sharing options...
RestoringNV Posted July 27, 2018 Author Share Posted July 27, 2018 Awesome! Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
