carolinajeepman
Everything posted by carolinajeepman
  1. Yes it’s the carb to transmission cable
  2. The 4x4 is a lot shorter than the 2x4 apparently
  3. Unfortunately still looking for this. The 4x4 one is different apparently than the 2x4 which is what I need
  4. I’ll take em can’t hurt to have spares
  5. That’s fine, I should still be able to make that work still no problem. Thanks for checking though
  6. That would be fantastic! Thank you! I would also be interested in the other cables, springs, cable brackets and sensors for it just for spares if mine go out.
  7. Still looking for this if anyone has one
  8. I can check tomorrow but I think I have a metric ton in black made already if you’re interested
  9. I am in need of a Throttle Valve cable for my 1986 Jeep comanche with the 2.8 V6 my cable seized and in an attempt to unseize it I broke it. OEM part number is 5300 1372 let me know if you have one you’d part with. Thanks!
  10. Awesome thanks! Appreciate you
  11. Awesome sounds good, thank you!
  12. I’ll take 3D printed for now while I source an original!
  13. Verified that it is not a tilt column
  14. I looked these up and it seems to be the same type as the bjsoffroad one from what I can tell unfortunately
  15. Yeah I bought that one and unfortunately it doesn't fit - it's much different
  16. No I don’t think it does. I can double check after work though.
  17. I am in need of a shift indicator needle for the column shift 1986 comanche. I cannot find exactly what they look like because mine is missing but it appears to be held on by a 7mm bolt on the top of the steering column. Let me know if you have one you’re willing to let go. Thanks
  18. Yes, that is it thanks! PM’d you back.
  19. carolinajeepman
    MS 1700
    I’m interested in buying an MS 1700. If you have one and are interested in selling, please PM me and let me know. Thanks!
  20. Not yet, but I will be putting it in next weekend. Had been working on the backlog of projects I had haha.
  21. Scored a factory roll bar this weekend! Looking forward to putting it on my 88 long bed.
  22. Hey Pete, just came across this - I’m here if you still need me!
