89eliminator Posted May 22, 2010 Author Posted May 22, 2010 door #2. kept the mirror mount to make it "legal", used lighter thinner metal and didnt warp it this time. also did a slightly different cut to make it more comfortable when you rest your arm on it. painted it flat black again just for simplicity. might break out the colorado red next winter if i decide to keep the door.
500 MJ Posted May 23, 2010 Posted May 23, 2010 Yah, that one looks good! I like it much better with the mirror on.
jpnjim Posted May 23, 2010 Posted May 23, 2010 Even looks pretty good in black on the red Jeep too. :yes: :cheers:
comanche13 Posted June 10, 2010 Posted June 10, 2010 it would look better if you painted just the bottom half of the door red and left the top black imo but they look sweet maybe a future project for me
TNT Posted June 12, 2010 Posted June 12, 2010 Nice job, it looks good. :cheers: I would like to see it in person. :D
TNT Posted June 12, 2010 Posted June 12, 2010 the patch was off of a 2dr XJ. i used a wide jaw vise grip to make a low spot for the new metal to lay on top of. for the inner wheel well i made a new piece that i welded to the fender and inner wheel well. I have a flanger if you ever need to use one at some point(think cowl hood). I also have a couple of extra doors if you need them. If I ever finish my MJ I'll need to find another decent pair of 2dr XJ doors to make myself a pair. With the longer 2dr XJ window openings/extended cab I would like to try to keep the wing windows an inside handle of some sort, mirrors and some speakers. I also plan to add a deep cup holder that is insulated. It would need to fit my BPE free water bottle that has a great cover that will keep the dust out. The marine store has some I like. :brows:
snowboard3r411 Posted June 14, 2010 Posted June 14, 2010 that looks freaking sweet and i want ur roll bar
TNT Posted June 15, 2010 Posted June 15, 2010 So are you going to pad the top and insde edge for comfort and safety? You could run padding up the rear edge to protect your elbow too. ;) A cup holder could be mounted in the forward angle area cut in door still. :cheers: I really like it. My plans that also include plating the outside of the door. :brows:
89eliminator Posted June 15, 2010 Author Posted June 15, 2010 its actually pretty comfortable right now. I'm gonna add a door handle on the inside and i might just put in a cup holder too.
DJM/78 Posted June 15, 2010 Posted June 15, 2010 Looks good , must be nice on these summer days . Are you going to cage it or put a rail in there , I like how you can see the seat from the outside .. ;)
jeeping31 Posted June 15, 2010 Posted June 15, 2010 What size tires your running and what coil spring did you get and from where? I when though all 36 post great write-up dude :bowdown:
89eliminator Posted June 15, 2010 Author Posted June 15, 2010 Looks good , must be nice on these summer days . Are you going to cage it or put a rail in there , I like how you can see the seat from the outside .. ;) yeah i plan to run some sort of interior cage...eventually What size tires your running and what coil spring did you get and from where? I when though all 36 post great write-up dude :bowdown: 33x10.5 BFG Mud Terrains. coils are 6.5" Rustys Offroad
jeeping31 Posted June 15, 2010 Posted June 15, 2010 Why not 8' coils and two poly spacer? you got the long arms!
89eliminator Posted June 15, 2010 Author Posted June 15, 2010 Why not 8' coils and two poly spacer? you got the long arms! because its already too tall.
Darren Posted June 15, 2010 Posted June 15, 2010 What's your problem Wade? Why wouldn't you want to be running a twelve-inch lift?
89eliminator Posted June 16, 2010 Author Posted June 16, 2010 What's your problem Wade? Why wouldn't you want to be running a twelve-inch lift? :shake: :rotf:
89eliminator Posted June 16, 2010 Author Posted June 16, 2010 got some new to me Bilstein 5100s the other day. it rides SO much better having the whole truck on Bilsteins.
DJM/78 Posted June 16, 2010 Posted June 16, 2010 got some new to me Bilstein 5100s the other day. it rides SO much better having the whole truck on Bilsteins. Can't go wrong there , I'm using the RE version and LOVE them ... :thumbsup:
CWLONGSHOT Posted June 16, 2010 Posted June 16, 2010 got some new to me Bilstein 5100s the other day. it rides SO much better having the whole truck on Bilsteins. I couldn't believe it what I did mine!!! CW
89eliminator Posted October 28, 2010 Author Posted October 28, 2010 long time no update. been REALLY busy with school lately. done some stuff to the MJ over the past months. mainly wheeled it. but... i changed over to black flares then my last trip ended early and bad... damage was both ball joints leaving the inner C, which in turn ripped/broke the u-joint out of the shaft. the ears on the shaft stretched so that to is junk. had to winch into a tree to lift the front end off the ground to get the tire and brake assembly off so we could drag the truck onto level ground.
JeepcoMJ Posted October 28, 2010 Posted October 28, 2010 ouch. you have 297 joints, right? if so, you're in luck...the parts xj's driver's shaft is in nice shape... i'll give you a good price on it. doesn't look like your inner C is bent, either...
500 MJ Posted October 28, 2010 Posted October 28, 2010 I bet that was an interesting experience. Ouch.
neohic Posted October 28, 2010 Posted October 28, 2010 i changed over to black flares Wow! Just a subtle difference really changes the overall appearance of the truck! I like it!... kinda reminds me of another red/black Eliminator on here... :thumbsup:
btm24 Posted October 28, 2010 Posted October 28, 2010 Looks very nice but I'm not so sure about that half door :ack: I love the truck tho Brandon
