mnkyboy Posted April 20, 2017 Author Posted April 20, 2017 Slowly getting it dialed in. https://youtu.be/68yUuUGzElQ
HOrnbrod Posted April 20, 2017 Posted April 20, 2017 Man, that sounds like four angry squirrels on steroids, and smooth as silk. You need to invest in a dyno run to see the numbers. Definitely sounds like it's ready.
mnkyboy Posted April 20, 2017 Author Posted April 20, 2017 It's running pretty good,i swapped the 19lb injectors for some 24s so AFRs seem to be happy under boost now. I tried some 30s but they were too much at idle,the 24s seem to be as big as the stock ECM can handle. I'm curious to see what it can do on a dyno too.
Wiggilez Posted April 20, 2017 Posted April 20, 2017 i'm pretty sure now that you have both boost and backfiring that it's now officially a rally car :P
mnkyboy Posted April 20, 2017 Author Posted April 20, 2017 It's the original 89 Renix block and head but it's dressed as a 2.5l MPI. It's a mixture of 91 MJ and 95 YJ.
HOrnbrod Posted April 20, 2017 Posted April 20, 2017 I used to have dyno runs done once or twice a year after i started modding my basic 4.6L crate stroker. It really helped to see what effect the changes you have done affects performance and reliability. Most all the changes helped, but some not so much. I thought it was a good investment and a valuable tool. Sooner or later you should do it just to establish a baseline. There's not much data out there I'm aware of available for the 2.5 like there is for 4.0 strokers. What you are doing I think is very cool mate. :cheers:
Minuit Posted April 20, 2017 Posted April 20, 2017 Your dedication to the little 2.5L is admirable mnkyboy :thumbsup: I'm not typically a 4-banger kind of guy but even I have to admit that thing sounds mean as hell and it sure looks like it goes like hell too. I'd love to see what kind of numbers you're getting out of it.
mnkyboy Posted April 20, 2017 Author Posted April 20, 2017 Another short video the wife got of the MJ. https://youtu.be/Z1lrnkQp3Ro
mnkyboy Posted May 26, 2017 Author Posted May 26, 2017 I took the MJ to a clean up a couple weeks ago,we removed 3,360lbs of trash from a local OHV area. Afterwards i got to play on the trails a little. Here's a video someone put together,towards the end is some footage of the MJ in action. https://youtu.be/a62czF7_4jo
mnkyboy Posted May 28, 2017 Author Posted May 28, 2017 I decided to finally install the RCVs that have been sitting in the garage for the last few months.
mnkyboy Posted June 18, 2017 Author Posted June 18, 2017 A link to my YouTube channel,it's got a bunch of footage of the MJ. https://m.youtube.com/user/Nathen2990
mnkyboy Posted July 2, 2017 Author Posted July 2, 2017 Took the MJ to NAXJA's NWfest,didn't get much for pics but other than a few minor issues the truck did great.
mnkyboy Posted July 3, 2017 Author Posted July 3, 2017 So far i like them,I haven't been able to break them yet. They felt pretty smooth the little bit that I've driven on them with the hubs locked in.
Me&my86MJ Posted August 7, 2017 Posted August 7, 2017 Picked these up from the shop yesterday. Hey Mnkyboy, what shop did you get your lovely driveshafts made at?
Me&my86MJ Posted August 7, 2017 Posted August 7, 2017 Thank you Mnkyboy, I was kinda figuring that would be the best spot to go for a new(custom) drive line. Especially at the price you had paid for both, I would probably pay for one.
mnkyboy Posted November 12, 2017 Author Posted November 12, 2017 Haven't posted in a while, i messed up my knee so i haven't done much with the MJ lately. I have been gathering some parts, i have parts to build a sector shaft support for the steering box, a new header to replace the one that cracked,a new larger PS cooler, an adjustible FMU, and a much smaller pulley for the supercharger so it will be getting a big increase in boost. Hopefully i can get on these projects here soon.
Kickin’Chicken Posted March 15, 2018 Posted March 15, 2018 Love those coils. They look awesome crossed up! What kind and size are they?
bslaws Posted March 15, 2018 Posted March 15, 2018 I have some supercharger questions. How did you plumb the air/water cooler and radiator? Where did you get the one you show? What did you use for a pump? How did you hook up the oil supply and return? What boost are you running? Are you retarding timing under boost? No additional fuel? Thanks, bslaws
mnkyboy Posted March 15, 2018 Author Posted March 15, 2018 The water/air system has a 4 gal icebox/reservoir in the bed, a 12v pump moves the water through copper pipes under the truck to further dissipate heat before it goes through a bar & plate style heat exchanger in the grill then through the Laminova intercooler. The pump is a clone of a Bosch style 12v pump for a water air set up that's used on a few OEM systems. I bought the supercharger and intercooler used and adapted them to my engine, Avenger superchargers use to sell the same set up in their TJ kit but it's not available anymore. The supercharger gets oiled like a turbo, it has a feed line coming off the oil pressure sending unit and a drain to the oil pan, it also could have been set up self contained like many OEM superchargers. In all the videos you saw on You Tube the boost was at 3psi, i have a pulley to bump it to around 10psi but I haven't put it on yet. Currently it has MPFI with 24lb injectors and a MAP adjuster, i also have an adjustable FMU but i haven't got it set up yet. I monitor AFR with a wideband and so far it's happy at low boost. I currently have nothing to pull timing, eventually i might do something but so far it hasn't been an issue,
