Wiggilez
Everything posted by Wiggilez
  1. Wiggilez
    Retro Review
    I believe that is where the boost gauge was on the diesel option. I can't remember his name but there's a guy here who has one who could confirm it.
  2. RIP I always enjoyed watching him and cruiser54 bicker and HO vs Renix.
  3. Same thing happened in my ramcharger, only it's to the right, I haven't looked into it yet but I'm really hoping it's a semi seized caliper.
  4. Considering it's only rwd it probably won't get one also I've run out of room for all of my cars. So I'm trying to sell it ( kinda hoping it doesn't sell so I can keep it) but if it sells the xr4ti is getting some go fast mods :)
  5. I was just there on the 15th so not even close haha.
  6. Depending when you were in lac louise we may have just missed each other.
  7. I'd just finished some grouting work on the heated portion of their outside play pen before setting up that pic. This pic is from before I grouted.
  8. Temporary weekend upgrade. I dropped off the metal to get cut and drilled this afternoon and the guy said it should be done by tomorrow so I'll be able to mount it properly then. It's mostly for looks. But it going to be mounted properly in case I need it.
  9. Other then a replacement sun roof frame I've pretty much ordered what I needed either through rockauto or UK Ebay listings.
  10. I'm currently feeling your lada pain, engine parts I can get locally, but it needs a new adjuster for the clutch which ford of Canada doesn't stock, but I was able to order from the UK.
  11. Mustang's svo 2.3 turbo but unlike the mustang this one doesn't have an intercooler.
  12. It is one of the big 3 Ding ding ding right anwser
  13. How bout a little guessing game of what have I bought now.
  14. Thank you dando for the bolt specs And also thank you to pete for the stud idea.
  15. Two questions. 1. I've heard that you can't replace the e12s because a normal socket won't fit. True or false. 2. I've miss placed all the Bellhousing bolts (even the starter ones) so now I'm just going to stop by the nut and bolt shop to get some. But I need to know what to get. Thank you
  16. The manuels zj you missed out on 5 years ago. Was it white and in southern Alberta?
  17. 242 have a rubber plug in the center of the case, it's beside/behind the shift lever. Might be worth checking out?
  18. You can put a ax15 behind a 2.5, but you need the bellhouse from a dodge dakota with the 2.5
  19. These gears would be from a 1990
  20. Depending on where you live i just removed a 21 spline input out of my 242 to swap in 23. Its still sitting on my work bench if you want it.
  21. Il try to verify the 86 2.8 ax5 np207 d35 this weekend. The drive shaft has to be in that damn shed somewhere.
  22. I have found the pin, and now after failing to remove I'm dropping it off at the shop across the street from my office.
  23. So I'm currently trying to swap in a 23 spline input in my t-case. From what I've seen on line there is a roll pin of some kind that must be removed, but ive also read that it's possible to pry over the gate enough to remove the fork assembly. I can't really see anything that looks like a pin. And i spent a few hours trying to pry on it but i don't want to break anything. Any tips on how to get this out. Thanks.
  24. shoveled the snow off it, Now I just need to wait for the lac under it to evaporate then I can start working on it again.
