Pannicthrottle
711 profile views
Pannicthrottle's Achievements
  1. Just wanted a place to document my build and share with friends of my I don't think this fourm thing is for me sorry please just delete my account Sent from my Pixel 2 XL using Tapatalk
  2. I would love to insulate the interior of my Comanche as well as be able to take a hose to it if I need to lizard skin and tractor implement paint worked great against a bb gun, rock, brick, hammer but as soon as I scraped it with a knife it came off. Any ideas? Sent from my Pixel 2 XL using Tapatalk
  3. I wanted to build a truck. I had a budget of 500.00 1989 Jeep Comanche Base 2.5l manual. 450.00 1996 Jeep Cherokee sport 4.0 auto. I traded something for it to swap the drive train and one day attempt a motor swap. Sent from my Pixel 2 XL using Tapatalk
  4. I will post some pictures as soon as.i start should have xj control arms today i am going to finish the front and then just figure out the rear Sent from my Pixel 2 XL using Tapatalk
  5. Yes i did Sent from my Pixel 2 XL using Tapatalk
  6. Well with all this wonderful knowledge i have just received both from here and the Google i will be going back to the soa set up and adding some ho.e made shackles Sent from my Pixel 2 XL using Tapatalk
  7. Well why not?? Sent from my Pixel 2 XL using Tapatalk
  8. So basically I have a Dana 35 soa from my 96 xj and a Dana 35 sua from. My mj. My plan is to install my Dana 30 with a 3inch lift. From my xj And then try to level it out in the rear with the parts I have off the xj I have already split the leafs and installed the helper springs from the xj in to the Comanche leaf pack. I can cut.and weld the Perchs but I'm worried about the pion angle I have never had to deal with that be for. Side not the sua seem to be sezed. Would it be better to swap internals and keep the soa setup? if so can that be done? This truck will be a DD that probably won't see any off road action at all. Sent from my Pixel 2 XL using Tapatalk
  9. Could some one please explain? Which way is better and why. Sent from my Pixel 2 XL using Tapatalk
  10. So I just pulled the trigger on new wj control arms and new moog.bushing for the axel thanks for the help Sent from my Pixel 2 XL using Tapatalk
  11. I see no real major advantage what ever I can get my hands on. Sent from my Pixel 2 XL using Tapatalk
  12. When you say box in I'm sure your meaning weld flat stock over open back u shape stock then. Trim all factory edges? Upper will be get another set of lowers and make work? And this will let tje front axel sweep fowrad but centering more under the block from swinging down a few inches? Sent from my Pixel 2 XL using Tapatalk
  13. That's an amazing answer. Exactly what I will do. What's a wj? Sent from my Pixel 2 XL using Tapatalk
  14. Sorry. I don't know what I'm doing. I swear I can turn a wrench though lol I'm also repalcing both.Sent from my Pixel 2 XL using Tapatalk
  15. Be for I try is it truly that hard to press out the stock control arm bushing. I have enough funding to by the ball joint press and the bushings. Or just by new stock control arms. Any suggestions Sent from my Pixel 2 XL using Tapatalk
