what did you do to your MJ today?
JeepcoMJ
I threw a breaker bar at it and walked away.
What didn't go as planned?
just a bad day at work. I carefully picked the rustiest door (which will get replaced) to throw it at.
this was the 90 eliminator I threw it at, not any of the other ones.
i got pissed a couple months ago and folded up a rag bucket at work and spent the next 30 minutes or so doin body work on it cause my boss was NOT pleased. :cheers:
i know allllll about the :headpop:
Took off the front Drive shaft and made sure it was greased up real good, than reinstalled. Added some Lucus Products in various places, checked my exhaust header bolts for the heck of it as well as intake bolts. I guess thats about it.....Dash is comin apart this weekend :cheers:
Trying to get it ready for an invite only ride in southern Ohio this weekend (and tenting in the snow).
Popped a bead to remove gravel from between the rim and the tire, then adjusted pressure in my tires (they ranged from 10 to 40psi :shock: ), rotated the tires, hooked vent tube back to front differential, drained chocolate milk from front axle and replaced with oil, checked rear axle but it was fine, installed new passenger mirror, McGuyvered driver mirror and ran out of time to fix my exhaust, so for the time being I rigged a glass pack straight to the front pipe and held it up with a piece of wire.
Immediately after posting this I find out the ride's been cancelled...
got a tag for it!!! :clapping: :clapping: :clapping: i own it finally instead of it being registered to my brother!
then on the way home the lower rad hose shot off and i had to pull over and make a trail repair... luckily i was riding around a buddys screwdriver i had to get warrantied for him and that was the only tool i needed! :cheers:
drove back to the shop and swapped it out for the volvo DD :chillin:
going JYin this saturday lookin for leaf packs, v8 tie rods, scouting for ax15s and mounts, fender, 2 doors, vent windows? unless i get 97+ doors, floor lights, and tow hooks!
Got the AX-15 and transfer case put in, tranny mount bolted on and started to put the rear driveshaft in. Found out that I need to swap the yoke from the donor rig's driveshaft to my driveshaft. Hopefully tomorrow I'll be able to finally get this conversion finished up!! :cheers:
you best be takin' pictures of that. :popcorn:
Took a few pics of the truck after the 4wd swap....still need to do the CAD fix and adjust the T/C linkage...
I spent a lot of time rolling through the water on my creeper...but it was time well spent :clapping:
I think the guy that cut my driveshaft down, shortened it about an inch too much???
