Puritan21
Puritan21's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Direct bolt-on. It's an excellent upgrade from the MJ box.
  2. I would like to be heading that way...Been trying to get up to Edwardsville, Il to pick up a shortbed bedliner and a front and rear bumper from a guy that had them on craigslist.
  3. :agree: I have two and love them. I have owned Gerbers, Buck, and Kershaw's over the years, but the M16 line from CRKT tops them all!!!
  4. The wiring should be there, just make sure you have good bulbs. In order to get them to light up you will need to get the vacuum switch that runs down to the cad on the front axle if you have a pre-92 axle.
  5. That Willys looks great.....no rust holes!! You need to fix that thing up and cruise it around!
  6. I used the same CPS. The plug on the B/A (2-pronger) is the Reverse lights...the plug on the passenger side of the AX-15 is the reverse lights as well. You have 2 options, splice them together or go a plug from the boneyard. My truck is an 89 and my donor was a 90 XJ, so I just swapped the plug where it connects to the wiring harness from the tranny...plugged right in!! Clear as mud?? Good Luck
  7. Err, something you need to come clean about there 500? :eek: :peek: Great stuff....never thought this would turn out to be a coming out of the closet thread!! :yes:
  8. Thanks for the reply...I was banging my head trying to figure it out :cheers:
  9. Nice rig, If you would have spent the $3800 two years ago, you would of missed out on all the fun and aggravation it is working on your own truck!! :D
  10. :drool: Wow...that is gorgeous!
  11. You got a heck of a deal...even with the floorpan repair!! Enjoy it...my wife won't part with hers, I even told her we could trade it in on a newer one!
  12. Happy B-day, Fellas!!!
  13. I hope you carry a fire extinguisher on board!! :yes:
  14. Swapped headlight switches and dome lights go out when doors shut/on when open. That's with the switch in the center position. :???:
