comanche12 Posted July 16, 2011 Share Posted July 16, 2011 Starting work on brake booster and master cylinder Link to comment Share on other sites More sharing options...
comanche12 Posted July 16, 2011 Share Posted July 16, 2011 done remove booster and M/c but pause work on it because need vise grip to hold the rod to able drill it with 5/8" drill bit Link to comment Share on other sites More sharing options...
dfreeman616 Posted July 16, 2011 Share Posted July 16, 2011 replaced for cluster for full cluster...but the speedo cable broke, and the oil gauge doesn't work :fs1: yes, i swapped sending units. Link to comment Share on other sites More sharing options...
cody4359 Posted July 17, 2011 Share Posted July 17, 2011 temp. got the pigtail for my harness done, need to connect to hazard switch and the rear should be complete. yesterday i swapped in the dana 30, HO coils and spacers and put new tires on. Link to comment Share on other sites More sharing options...
MancheKid86 Posted July 17, 2011 Share Posted July 17, 2011 gave it its first full tank of gas, $78.07 later :roll: Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted July 18, 2011 Share Posted July 18, 2011 Picked up 4 new studded snow tires and steelies for this winter and replaced the amber corner marker on the drivers' side. Link to comment Share on other sites More sharing options...
jeepman 87 Posted July 18, 2011 Share Posted July 18, 2011 Headliner in door Panels done, new front tires, new lights in bezel, and finally got to get it driven :banana: Link to comment Share on other sites More sharing options...
Jerry Posted July 18, 2011 Share Posted July 18, 2011 Pulled the old rad in anticipation of the nice new all metal 3 row jobbie that's winging it's way from Jacksonville, FL as i type :banana: Link to comment Share on other sites More sharing options...
SW86 Posted July 19, 2011 Share Posted July 19, 2011 ordered some timken hubs and picked up axle seal for one piece swap. just need gears, locker and maybe a gusset or two, the 30 will be done! Link to comment Share on other sites More sharing options...
ComancheKid45 Posted July 19, 2011 Share Posted July 19, 2011 Did alittle "wheelin" around the house with a friend. :D Link to comment Share on other sites More sharing options...
cody4359 Posted July 19, 2011 Share Posted July 19, 2011 made some temporary brake lines that are ugly, but shouid have brakes now. put stock track bar on since i robbed the double shear to repair the zj a while back. tomorrow ill hook up the tranny shifter cable, throw the front driveline in along with a bucket for a seat and take it for a test drive. Link to comment Share on other sites More sharing options...
dfreeman616 Posted July 19, 2011 Share Posted July 19, 2011 replace oil pump and rear main seal. Link to comment Share on other sites More sharing options...
Backdraft Posted July 19, 2011 Share Posted July 19, 2011 Got the air conditioner charged up and working. No more sweating like a dog anymore! Link to comment Share on other sites More sharing options...
SW86 Posted July 19, 2011 Share Posted July 19, 2011 Did alittle "wheelin" around the house with a friend. :D i hope you put those sliders to the test. hell you've got a locker too. should of tried to crawl over some of that $#!& man! Link to comment Share on other sites More sharing options...
ComancheKid45 Posted July 19, 2011 Share Posted July 19, 2011 Ha Ha....i did crawl over a few things but nothing crazy, I love having those options there though for when the time comes :D Link to comment Share on other sites More sharing options...
mvusse Posted July 20, 2011 Share Posted July 20, 2011 Buttoned up the bottom of the truck after swapping out the AX4 for an AX5. Still need to fill the transmission, transfer case and crank case as well as reinstall the center console. As a bonus, I found 5 quart jugs of Mobil 1 10W30 API SL at Wally World for $25. Usually I have to get 4 stroke motorcycle oil (API SJ) by the quart. I will never use SM or SN in my Jeeps. Link to comment Share on other sites More sharing options...
SW86 Posted July 26, 2011 Share Posted July 26, 2011 finally installed my MOOG ball joints. then i gutted all the CAD stuff and made a cover plate. cleaned the axle tubes and installed Alloy axle tube seals. which are bitchin as hell. got my new hubs and shafts ready for tomorrow when the RTV cures fully and ill be wheelin again! ah and I'm having to replace the rear pinion seal on the turdy5. maybe i should just swap the 8.25 in already Link to comment Share on other sites More sharing options...
Blue88Comanche Posted July 28, 2011 Share Posted July 28, 2011 I got a phone call from the Mechanic telling me the "bad news" about my BA10 tranny... the input shaft broke and damaged some clutch parts with it... ...So i started looking for an AX-15, and the parts required for the swap... I now have 2 Comanches I can't drive... one with an engine, but no tranny, one with a tranny but no engine... and no i am not moving the engine to red, and reds tranny is an auto 2wd and i don't have the drive shaft... so no quick fix Link to comment Share on other sites More sharing options...
comanche12 Posted July 29, 2011 Share Posted July 29, 2011 preparing to finish two projects on my jeep this weekend zj booster&M/C and metal wedge for front spring. :wrench: pictures will come up later :cheers: Link to comment Share on other sites More sharing options...
AMC-MJ Posted July 30, 2011 Share Posted July 30, 2011 Kinda boring but I drove it to the grocery store and back 5miles round trip ;) Mike Link to comment Share on other sites More sharing options...
btm24 Posted July 30, 2011 Share Posted July 30, 2011 Got my snorkel in the mail :D going to go and get my "new motor" Sunday. Brandon Link to comment Share on other sites More sharing options...
SW86 Posted July 30, 2011 Share Posted July 30, 2011 ^^^^sweet please tell me that STP is not for the MJ. i put one on and not long (like 2 weeks) after it was @#$%ed up and caused my low oil pressure issue. which cost me dough since i bought a high flow pump but all i needed was a WIX. Link to comment Share on other sites More sharing options...
AMC-MJ Posted July 30, 2011 Share Posted July 30, 2011 :bowdown: I been running WIX filters and AMSOIL 20w-50 high Zinc :thumbsup: Mike Link to comment Share on other sites More sharing options...
comanche12 Posted July 30, 2011 Share Posted July 30, 2011 pics tell everything what I'm doing Link to comment Share on other sites More sharing options...
AMC-MJ Posted July 30, 2011 Share Posted July 30, 2011 Cruised on over to the Jeep dealership here by the inlaws with my MJ, To ask about this JK-8 Kit truck What a waste that was they knew nothing of it, Then tried to make ma a trade in offer on my MJ :nuts: She told the sales man "You couldn't afford this in your wildest dreams" . . . How cool is that ? My girl stuck up for my MJ ! ! ! Mike Link to comment Share on other sites More sharing options...
