AMC-MJ
Everything posted by AMC-MJ
AMC-343 V8 / AX-15 5spd / AMC-20 = Project MJ/343
AMC-MJ replied to AMC-MJ's topic in Member Projects: Your Comanches
Well i had 343 V8 found turned out to be a 290, I already have a 290 so wasn't interested in another right now. Found another 343 in Rockford. so i am trying to plan out and setup a time for picking it up. lost out on the AMC-20 but i think i have found another AMC-20. the floor repair the PO did turned out was just tinning over the old floor, Found a 22" x 11" area on the drivers side all rotted out ! so i am going to need a total floor pan kit i believe its 2pc kit cover the whole floor area. It was around $350-$450 any know where that can be purchased ? Can the engine harness be removed ? id like to strip the truck of all the un-needing wiring basically just the lighting system. is that possible ? Mike -
Still ain't got blinkers ! but i only need to drive it another week and than this truck is all done. Time to pull it off the road and rip it all apart. going to restore the body and interior and upgrade the whole power train. Mike
Ax-4 2Nd Gear Moaning ...
AMC-MJ replied to '87 fuel-miser's topic in MJ Tech: Modification and Repairs
your out or low on fluid, If your fluid is full and clean ? its dying soon it'll be 2nd 3rd and reverse. time for an AX-4 ! Mike -
Thanks for the tip! As soon as I get off work with daylight left, I will be doing this. Currently, driving truck as is. It is only going to be on the road until the end of the month. Then, hoping to start on this AMC V8 re-power. Once I start that, the truck will most likely get a re-wire. Sounds like that may be what it needs Mike
Parts list: 2 brand new flasher stat 2 brand new 20amp fuses(checked several times) brand new turn signal switch with wiring harness 8 brand new light bulbs Truck status Turn on headlight switch, all bulbs light. Step on brake pedal, all brake lights work. Pull back on blinker switch, high beams come on. Pull back again, high beams go off. Pull out hazard/flasher knob, all 4 corners blink. Push down for left turn signal, nothing happens. Same for right turn signal. No noise, no flash, no lights. This is where I am at now. I've downloaded your manual, and will be taking a look. Hoping for the answer. Mike
As stated earlier, switch harness, bulbs, and fuses have been replaced! I've tried everything I can think of! Getting more and more frustrated! H E L P ! ! ! Mike
If it is a grounding issues, wouldn't the other functions that operate the same bulbs and filaments also NOT function? Unless, 3 functions have separated grounds, I do see how it could be grounding? On a side note, the AMX is coming alng slwly, and in about a week here, I will be picking up the Comanche's 343 AMC V8! [/img] Here is a pic of fuse panel. [/img] Diagram Mike
Lost my turn signals! Then, lost my brake lights and flashers. Put in a new fuse, and brake lights and flashers worked again. But, still no blinkers. So, I bought a new blinker switch, changed all the bulbs, and STILL NO BLINKERS!!! Both flashers are brand new. Brake lights work, flashers work, on all, running lights, JUST NO BLINKERS!!! Has anyone else had this problem? What else can I do to get the $%&*# blinkers to work?? Now, the high beams are stuck on! Can't dim them. Any ideas??? Mike
local '92 Comanche was offered to me . . .
AMC-MJ replied to AMC-MJ's topic in MJ Tech: Modification and Repairs
When that happens mine oughta sell for $2000 easily :cheers: Mike -
"New Vendors 5spd transmission"? Do you mean New Venture? That would mean he has a new engine with an NVG3550 transmission, which is the tranny used in the 2000 and 2001 XJ and the 1999 and newer Wrangler 4.0L Jeeps. It's a much nicer (and slightly stronger) transmission than the AX-15. The tranny alone probably cost him $3 grand. If the body is in good condition, you're probably looking at a $5,000+ truck. I know y'all are having a collective heart attack over the notion of a $5,000 MJ, but go out and price a low mileage Ranger or S10 (or one with a completely renovated drive train) and see what you come back with. The truck you're describing has had the ENTIRE drive train replaced. $2,000 to $3,000 is a fair price for an all-original '92 MJ with maybe 100,000 to 150,000 miles on it. If I had a truck such as described and somebody offered me $3,000 for it I would be highly insulted, as well as knowing that the person has a tenuous grip on reality. ODO showed just shy of 135,000 miles. He may have mis spoke or I miss heard. Mike -
:eek: like I said well beyond my means ;) I will ask him if I can take some photos and post them, Its NOT my truck so I am leary of taking and posting photos of it. Definitely seems to of been built/setup for towing. Mike -
I guess I will have to ask even more questions Truck was built by JnL 4wd in Sun Prairie. Drive train was bought NOT removed from another Jeep. It has NOT been driven in winter, Typically parked Mid October and brought out Mid May. Its been driven in some rainy and muddy conditions. I did pull the floor mats back floor looked solid and sound but was coated with bed liner, I did the same with box too. I told him I thought the truck was nice but well beyond my means. His response was "Well its NOT technically for sale but if the right offer came up I might send it on its way" Mike -
AMC means Jeep to me ;) Mike -
I didn't take any pics of it wasn't my truck to do so, Well $2-3K is well beyond my means. I'm NOT to thrilled with Jeeps that have Chrysler logos any way. Thanks guys Mike -
I found a gentleman in town with a 1992 Comanche Shortbed 4wd. Its a sporty looking trailer towing beast of a truck. Info: 195hp 4.0L I6 crate engine. New Vendors 5spd transmission. New process transfer case. Dana 44's front an rear with 4.10s. LT245/75R16E Firestone MTs on 16" Jeep wheels. Metric ton springs. Roll bar with lights. Chrome trim. Brush guard on front. HD hitch bumper on rear. Fancy 7round n 4flat light hook up. Truck is bright metallic red and has black bedliner inside the box and on floor pans. HID head light conversion, and LED light bulbs through out the truck. He wanted me to make an offer on it. What ya think the truck might be worth ? Mike
I bought the DOT-5, Anywho trucks long been fixed almost got 1000 miles on the new clutch system ;) Mike
Well my Comanche has hauled AMC-V8s around, It actually carried one all day every day for 5mo nobody would help unload it ! I actually herniated my groin when I unloaded it myself ! ! I also used to load a pallet of salt on the bed for salting commercial sized condo walks in the winter time ! ! ! Truck's previous owner towed his fishing boat with it all the time too. My truck is a shortbed 2wd, AMC-2.5 I4, AX-4 4spd, D35 with 3.73s Mike
Amsoil only carries DOT 3 and DOT 4. The local stores only carry DOT 3 and DOT 4 in the large containers. O'Riely's carries DOT 5 but only in small containers. So, I purchased 2 little bottles, that's all they had. According to the store manager, there is not much of a calling for DOT 5. Is 22 ounces going to be enough? Now Weaver Auto Parts says they have a product called DOT 5.1. What's this? While snooping around another parts store, I think it was Car Quest, I found a product in a similar bottle to brake fluid, called Hydro Clutch Fluid, apical to all hydro clutching systems. Anybody use this? Mike
I bought all the parts to fix it, going to install them and drive on ;) Mike
Ya well filling it 3 times per round trip to work and back just isn't worth while. Mike
Full of fluid and blead out I only get 3 runs through the gears and its out of fluid, it is no longer driveable I have been without wheels for a while now. Mike
Its synthetic, I was under the impression that it didn't break down. Well I been using it to limp the dying system along so I may as well just get some new fluid than and play it safe I guess. I really was hoping NOT to invest any more into this power train so much for that eh ? All I wanna do is get my AMC-V8 swap done :wrench: but something always comes up on me job lose due to down sizing, unforeseen bills or expense. Such is life I guess I ain't giving up tho ;) Mike
:eek: you got to replace that too :ack: Yes the kit came with a pressure plate, throw-out bearing, clutch disc, master cylinder, and slave cylinder :D Silliest looking slave I have ever seen, looks like a brake caliper piston assembly ! I might get around to installing this clutch kit one day ! ! I have some prestone DOT3 synthetic left over from when I did the whole brake system 4yrs ago so that's what it'll get for fluid unless 2/3Qt isn't enough than I will order up some amsoil brake fluid . . . If I gotta buy fluid I buy amsoil ;) I bet once I switch over the AX-15 will require a whole new hydro system too ! ? ! ? ! Mike
The whole clutch system will be brand new! It is sitting here, waiting, on the bench. Clutch master and slave cylinder, line in-between, throw-out bearing, and clutch disk. Any bolts, screws, gaskets, and seals will also be replaced, as needed. I've got a little under a quart of Prestone DOT 3 synthetic fluid left. Will that be enough, or should I just order the Amsoil now? Mike
It is going into a whole new clutch system. Replacing it all! Not going to put it in the old one. Mike
