AMC-MJ
Everything posted by AMC-MJ
  1. Sounds like your just starting out to a u-Joint failure, I'd repair it sooner rather then later :thumbsup: Repair parts: O'Reilly's also my suggestion is get the longest 5/16" wrench you can find, They stock them in store I'll be getting one when they open up tomorrow morning ;) hope i've been of some help :???: Mike
  2. The tough bolts: The Wrenches i'm working with: :wall: Yea it loads of fun :fs1: Mike
  3. Trucks smootj up to a certain speed, When it started vibrating the faster ya went the worse it gets . . . Until your Mirrors shake so much you can hardly see out of them, If you can get it up to the vibrating speed then put it in neutral it'll get violently worse ! ! ! If that's what you got I'd do some U-joints or you'll be like me layin in gravel far from home ;) Mike
  4. :wrench: They are on the bottom, already did the rotate the drive shaft deal :wrench: My wrench is about the size of my pinky :fs1: I got a few 5/16" & 8MM sockets but can't get none of them to fit well they fit but NOT enough to fit the ratchet on the socket, I must say this is the most retarded looking drive shaft i've seen :fs1: Mike
  5. New Parts: 2x Precision #369; 1x Precision strap kit #437-10; :wrench: Onto the repair :wrench: :wall: I can't get the other bolts out, My 5/16" is super short, I fought it til the storm blew in :fs1: Mike
  6. No NOT in the middle of nowhere, Just 140-Miles from home O'Reilly's is a bit of walk but we n boss lady made it twice but got all the parts I'll keep ya posted :thumbsup: Mike
  7. U-Joint strap kit Precision #437-10, Sweet the straps n joints are of the same brand ! ! ! The straps fit the Joint perfectly, Alrighty back to the truck ;) :wrench: Fix it time :wrench: Mike
  8. Yep shouldn't to bad almost to the parts store, Get 2 strap n bolt kits and then walk on back and put it back together :wrench: Good lesson in what to carry with ya :cheers: Mike
  9. Nope its the same Shortbed, 2WD, AMC-150 I4 / AX-4 4spd / D35x3.73 truck that left the factory 23/24yrs and 201K-miles ago . . . tho its wearing a set of 235/75R15's ;) Tho i think a P-O might have swapped Metric/Big-Ton springs under it cause it holds a load Smart phones and long hot walks, Shoulda took them joint straps with me :fs1: Almost back :wall: Glad they stay open late :bowdown: Mike
  10. It basically looks like a front bumper mounted to the rear . . . looks nice but i ma just and go chrome step on mine WHY ? ! ? Well, because i'd have to build a reciever hitch which will only lead me to towing things i shouldn't be ;) We'll see how it goes, I may be asking you about how to build or buying a set of mounts from you Mike
  11. Yup both little tab deal's are intacted, Stop and got a pair of U-Joints they appear to be a touch bigger then the joint in the truck, I wonder if the current Joint is the wrong/cheapo one ? :???: ? They have 3 different stud/Strap Kits may just get some for the peace of mind of it :thumbsup: :wrench: The new Joint "Precision" #369 Fits the tie downs better . . . :bowdown: Now lets see if remember how to change them its been a long while :hmm: I'll report back with progress :yes: . . . :ack: Mike
  12. Tires are balenced treads all look straight and true, My concern it the U-Joint moving in the yoke ? :???: ? I was wondering, should i replace the U-Joint currently i have the strap removed and it dosen't appear to be damaged :bowdown: Should I reinstall the strap and keep running it ? or should remove the other strap and replace the joint ? Mike
  13. First it vibrated at 70mph, then went away at 65mph then started again after a while, then 60mph then 45mph. So U-Joint right ? ! ? ! ? Ok trans end joint seems tight no play, rear had some slop 1/4"- 3/8" of it :wrench: Then noticed the it wasn't slack in the joint but one joint cap was sliding back n forth in yoke :fs1: :wrench: Tried snugging down the bolts, To no avail it still moves around :fs1: So where do i go from here replace joint ? strap ? :hmm: yoke ? :( Mike
  14. :wrench: they offer the above picutred in chrome :???: That'd work for me ;) Mike
  15. To answer your first question, yeah, Covering up chrome is a pretty stupid idea IMO. :fs1: But can't be helped. Now, as for the second question, If I recall correctly, I believe that SOMEONE on here had a picture of a stock chrome bumper... Although I don't remember who/what it looked like, although I believe it looked like this.... Circled parts remained "Gunmetal" colored, while the side indented tubing (arrowed sections) were chrome. Again, not 100% if this is what it looked like, but there are aftermarket chrome bumpers made for the MJ. I don't know if they're a 100% fit though. :hmm: So to keep this paint theme i would have to keep my black trim from this unit ? :hmm: Are they close enough only an MJer would notice ;) . . . Anybody got photo of these "fey" units ? :???: ? Mike
  16. Ok I'll PM ya some shot's :wrench: Mike
  17. So about these after market chrome rear bumpers, any body gota link or photo of the actual bumper ? :???: ? Mike
  18. :wrench: Nice project looking forward to it :wrench: :rant: I can relate, My MJ was a cheapie and its been a great truck, My FSJ is a big pile of parts that costs money to ge and I'll have a ton more invested before I get to find out weather it was worth while :fs1: Mike
  19. Ah ok so chrome fronts no bigie, Chrome rear's well those are the challenge ;) Seems to be the theme with everything I do these days . . . I may to check into your XJ to MJ rear bumper conversion :wrench: Mike
  20. It ain't gotta be OEM they could be off a toyota for all I care, I just don't want some D-looped winch bumper looking creature . . . I got a shortbed 2wd so I want "pretty" NOT "beastly" ;) Now is it just the Rear bumper that's a PITA to get or front too ? ! ? ! ? As I need a pair of them ;) Mike
  21. :bowdown: Just nice looking basic bumpers, lil'flat spot ball hitch type rear Ok window trim, So the black paint/coating can be removed with out damaging the stainless or doors ? ? ? Chrome grill mine got broke and was replaced with a black one :wall: Need a another chrome grill to match head light trim ;) Mike
  22. :( yea I was kind of wondering that myself, Why Cover up Chrome :fs1: So removing the coating is going to have to be choice of "Pretty" v.s. "longevity" :ack: :( What about bumpers front & rear in chrome :dunno: Mike
  23. :bowdown: The AMX-390 isn't much to look at been parked since 1976, i've owned it since i was 14yrs old :eek: It's what started my AMC & AM-J craze :nuts: Car was my fathers he ordered it winter 68' picked it up spring 69' drove it til 76' then parked it :fs1: :D Its a 390-Hipo / T10 4spd / AMC-20x3.91 configured car and lived a hard 75K-Mile 7yr life :yes: I could PM ya 4 some what current shots as NOT to disrupt yourthread here ? if ya want ? Mike
  24. :wall: I can find MJ chrome front bumper's, But i can't find diddly for rear bumpers in chrome :fs1: and what about the door window trim ? My one door the black coating peeled off and its shiny chrome under it can that be safely removed :huh???: Mike
  25. My window trim: It appears there is some sort of "COATING" on the door trim i'm guessing by the windshield it should be all chrome, Rather I can make the door window trim to match that of the windshield ? ? ? :???: What about Chrome bumpers :???: :wrench: I need NEW-DOORS i know :wrench: Mike
