Backdraft Posted July 6, 2011 Share Posted July 6, 2011 Installed a winch. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted July 7, 2011 Share Posted July 7, 2011 Installed freshly painted factory 5-star wheels. Link to comment Share on other sites More sharing options...
deziped Posted July 8, 2011 Share Posted July 8, 2011 Installed a new 02 sensor. While I had the driver front up on ramp I noticed the oil dripping out the pass side axle. Must be an omen to get the seal changed out. Or I could just let more air out of the left front and keep the oil flowing to the left. Link to comment Share on other sites More sharing options...
MJRemi Posted July 8, 2011 Share Posted July 8, 2011 Replaced with new: Brake pads Brake lines Wheel bearings Clutch M/C and had front alignment. Link to comment Share on other sites More sharing options...
SW86 Posted July 9, 2011 Share Posted July 9, 2011 new O2 sensor, picked up some 760x joints for my newer shafts. next week its ball joints and hubs going in. then a Spartan to (almost) finish up the front d30 :banana: oh and finally picked up a spare 31. i learned my lesson after that blow out and had to drive on a flat! Link to comment Share on other sites More sharing options...
comanche12 Posted July 9, 2011 Share Posted July 9, 2011 otw to junkyard to get wj brake booster/mc and poss. ZJ front sway bar! :wrench: Link to comment Share on other sites More sharing options...
SW86 Posted July 9, 2011 Share Posted July 9, 2011 otw to junkyard to get wj brake booster/mc and poss. ZJ front sway bar! :wrench: if you come across a V8 ZJ grab the tie rod. its a huge improvement from our tiny weak ones. Link to comment Share on other sites More sharing options...
KYMJ Posted July 9, 2011 Share Posted July 9, 2011 Finishing up painting floorboards, been putting it off for a year, PITB. Fixed a few of the leaks, I think the back slider is leaking also. The leaks will be a work in progress. New parking brake cable and headliner while I have the interior apart, new carpet will have to wait on sufficent funds. Link to comment Share on other sites More sharing options...
SW86 Posted July 9, 2011 Share Posted July 9, 2011 Finishing up painting floorboards, been putting it off for a year, PITB. Fixed a few of the leaks, I think the back slider is leaking also. The leaks will be a work in progress. New parking brake cable and headliner while I have the interior apart, new carpet will have to wait on sufficent funds. make sure to check where the radio antenna comes in the cab. its behind a panel right in front of the pass door on the floor. mine was leaking like a mofo from there. Link to comment Share on other sites More sharing options...
KYMJ Posted July 9, 2011 Share Posted July 9, 2011 Finishing up painting floorboards, been putting it off for a year, PITB. Fixed a few of the leaks, I think the back slider is leaking also. The leaks will be a work in progress. New parking brake cable and headliner while I have the interior apart, new carpet will have to wait on sufficent funds. make sure to check where the radio antenna comes in the cab. its behind a panel right in front of the pass door on the floor. mine was leaking like a mofo from there. Yeah, I think I will leave the kick panel off until I find all the leaks. I did put a new door seal on that side. And I need to replace the smokers window with a stationary one as soon as I can go to the pull a part. I "shimmed" the latch, which seemed to cure the leak there. I don't want to leave the cardboard in there forever. Well, back at it. Link to comment Share on other sites More sharing options...
comanche12 Posted July 9, 2011 Share Posted July 9, 2011 i just came back to home from junkyard. i didnt buy the parts,. they charge me 150 for brake parts so i decide to buy it from autozone for only 120 dollars both booster and m/c brand new and lifetime warranty. even they r bendix ;) i can buy sway bar later. there plenty zjs and xjs in junkyard. edit: done bought booster and m/c for 120ish dollars and fuel filter too. :wrench: booster will be here at july 12 (tuesday) :cheers: Link to comment Share on other sites More sharing options...
ejndssn Posted July 9, 2011 Share Posted July 9, 2011 just replaced the wheel hubs bearing :banana: and rotors :jump: and ready for inspection and they where and what a pain after 22 yrs time for some and chill Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted July 10, 2011 Share Posted July 10, 2011 Put a Mavericks decal on. This is sure to get a few Blazers fans twisted. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted July 10, 2011 Share Posted July 10, 2011 Replaced the Starter in the 88....not feeling like doing much else Link to comment Share on other sites More sharing options...
meljr Posted July 11, 2011 Share Posted July 11, 2011 Was going to drive it to the shop Wednesday, but it wouldn't start. It would turn over just fine, but just didn't want to start, so I gave up, thinking it was the fuel pump or something related. Went to put it on the car trailer this weekend and decided to try starting again. The fuel pump pressurized the system and after a little more than usual cranking, it started and drove on the trailer, saving me from having to use the winch. When we got to the shop, the Comanche fired right up, drove off the trailer and into the shop. The body restoration starts tomorrow; I'll deal with mechanical issues later. -meljr Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 11, 2011 Share Posted July 11, 2011 Finally got the engine back in, now just have to hook everything up. Link to comment Share on other sites More sharing options...
ejndssn Posted July 11, 2011 Share Posted July 11, 2011 Was going to drive it to the shop Wednesday, but it wouldn't start. It would turn over just fine, but just didn't want to start, so I gave up, thinking it was the fuel pump or something related. Went to put it on the car trailer this weekend and decided to try starting again. The fuel pump pressurized the system and after a little more than usual cranking, it started and drove on the trailer, saving me from having to use the winch. When we got to the shop, the Comanche fired right up, drove off the trailer and into the shop. The body restoration starts tomorrow; I'll deal with mechanical issues later. -meljr :idea: you may want to check the cps they have a knack for doing things like that :brows: Link to comment Share on other sites More sharing options...
M2 CARBINE Posted July 11, 2011 Share Posted July 11, 2011 Replaced bent Axle shaft then regeared. Link to comment Share on other sites More sharing options...
jeepman 87 Posted July 13, 2011 Share Posted July 13, 2011 Got my headliner done and back and also pieces done for my one of a kind door panels Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 13, 2011 Share Posted July 13, 2011 ... my one of a kind door panels Pictures??? Link to comment Share on other sites More sharing options...
MancheKid86 Posted July 13, 2011 Share Posted July 13, 2011 97+ mirrors Link to comment Share on other sites More sharing options...
comanche12 Posted July 13, 2011 Share Posted July 13, 2011 got ZJ booster yesterday. its exactly same with wj but cheaper price :D right now, I'm at lunch break and waiting for guy to come pick my wegde up and hopefully able drill mill it at his engine rebuild shop :cheers: more projects r finally able to start work this week and weekend! :wrench: Link to comment Share on other sites More sharing options...
SW86 Posted July 14, 2011 Share Posted July 14, 2011 :brows: :D Link to comment Share on other sites More sharing options...
MancheKid86 Posted July 15, 2011 Share Posted July 15, 2011 lmao, here's another shot of the front of the truck since it seems like you liked it :thumbsup: :rotf: :yes: lol who am i kidding, i figured some one would point that out sooner or later :rotfl2: Link to comment Share on other sites More sharing options...
SW86 Posted July 15, 2011 Share Posted July 15, 2011 yeah see, you knew what you were doing :thumbsup: front end looks good. since thats a newer 8 slot you should of cut off that top piece above the grill and kept the full metal trim line. smoother line that way Link to comment Share on other sites More sharing options...
