Sorry about the confusion the motor is not seized and I don't know if its getting spark at the plug kinda hard to turn the key and see if is sparking.
Thanks
I don't hear the fuel pump prime when i turn the key but i spray starter fluid/ gas into the Intake and turn the key and no turning over just crank and as for spark everything has been replaced and rechecked with volt meter and everything checks out good. I'm lost and confused!
Well upgraded all the grounds cleaned the C101 again my god that thing was still dirty changed out the CPS,plugs,coil,ignition control module from my DD XJ and no change.
I did it yesterday with cleaner along Q-tips and tooth picks and no change. Starting to get frustrated.also cleaned the grounds thinking of upgrading them to 4 gauge just to see if that will do something.
Thanks
Okay i haven't received the fuel pump yet but i checked all the fuses,relays and grounds and still can't figure out why its not turning over. It's very werid reminds me of when i had a 93 XJ i did a tune up on and after words wouldn't turn over i put the old distributor back on fire right up went and exchanged it samething went to 3 other big box stores and none would work ended up going to chrysler and paying $25 for one put it on and boom worked great.
any input would be great.
