shelbyluvv
Moderators
    3
Everything posted by shelbyluvv
  1. shelbyluvv
    P&p Ing
    I need those tail lights!
  2. A TJ tank will fit there like it is made for it.
  3. When I bought my truck I had the same issue. A prior owner wired the radio wrong abd it would not shut off.
  4. You could but, I won't. I have emailed Doug and may have a definitive answer in a few days for all the long box guys out there.
  5. I know the 96 is OBD-II where the 91 is OBD-I. The steering column is also totally different. You will most likely need all the underhood wiring as well.
  6. Best I can tell on phone a D35 covered in rust and grime.
  7. I got mine for free! I traded a XJ D44 for it. The dude was trying to sell the MJ 44 with no luck so I traded him my XJ 44. He sold the XJ 44 a few days later for $100 more than he was asking for the MJ 44.
  8. 2" BB and a block in the rear. 15x7 wheels and 33x12.5 MTRs. It was a fun toy. I had like $500 into it including buying it. Look up "project budget beater" on NAXJA.
  9. I fit 33's on a XJ with a BB. Embrace the Sawzall!
  10. If you do the "hold the trip button and turn it to run trick" or "the three time key cycle thing" to get the codes. If it works, you will most likely only get a P0700 code. Meaning trans fault. You will need a scanner to dig into it to find the code.
  11. Not sure what you mean by "hardware". Are you talking about the 4 nuts and 3 Torx bolts? The stick bench has a cut out in the seat for the shifter. The auto bench is flat across the front.
  12. I put mine in the stock 97+ location under the overflow bottle.
  13. Color? Auto or stick? Condition wanted?
  14. http://comancheclub.com/topic/34536-diy-e-brake-fix/ Looking for this?
  15. If you can get it to me I will throw it in his parts pile. I will be up there in a few weeks to see some family.
  16. http://www.xjdb.com/...mId=7&g2_page=2 http://www.naxja.org/forum/showthread.php?t=17972 Owner, strokedwoody
  17. Search, it has been covered a lot around here. I say stay away from Glen Wakefield and his crooked ways. Hellcreek sales rear springs.
  18. http://colorado4wheel.com/images/jeepwheels/wheelsindex.html
  19. Semper Fi Brother! That almost brought me to tears...
  20. The column shift is not all too rare. Like anything with these trucks you will play hell finding parts. How bad is the column? Most GMs use a very similar column and can be robbed for parts.
  21. If you would like to send me just the drivers side rear flare I would fit check it on my long bed. That way if it does not fit I will have no use for it. If it does you get confirmation that it does and I will either have to buy a complete set or repair the damage to my truck by cutting it to fit. Most likely I will be buying a set if they do fit. I really like the look of them but need to see them on a long box first. Bo
  22. I can get his shell back to 29 palms if a socal member wants his. It is not my style. I'll keep my cracked Leer and fix it.
  23. I have the exact same shell but mine is cracked right above the rear window. I don't have the time to mess with it. Is yours a cab high shell or does it step up in the center? I'm not a big fan of those ones. Could you please grab the rear flares for me? I really need a set!
  24. We went to a different yard I guess. I would love to have that shell! Mine is cracked. If you want to pull it I will pick it up in a few weeks when I head back up there to drop off some stuff to a few guys.
