When I start the engine it starts building pressure in the coolant system. But it does not get high enough to push coolant into the overflow canister, unless I open the radiator lid before the pressure has gone down. I have a Brand new radiator lid, so I believe the pressure relief valve is correct. If I run the engine without the radiator lid, coolant is pushed out of the radiator through the open neck.
I've changed the cylinder head, and replaced the gasket. Thermostat is new. Engine temp and heater system works fine. No access smoke. Oil is fine, no oil residue in coolant. So I hope that it's not the compression entering the cooling system.
Now, this is a 1986 2,5gasoline. But in Norway it has been registered as a 1987. I see that there are different water pumps ->86 and 87-> Could it be that the previous owner fitted a -87 waterpump on the -86 engine, causing too much flow? ( Wrong size belt pulley for example? ) Maby in conjunction with a partly clogged radiator? ( Have not cleaned the system yet, waiting for a new radiator. )
