danbyrambler
Everything posted by danbyrambler
  1. Greetings - You're gonna like it here - lotsa help - - Here's a jack pic & jack instruction pic: http://comancheclub.com/topic/14760-jack-and-rod/#p157554 http://comancheclub.com/topic/23981-stock-jack-configuration-diagram-pic/ Search is a good tool - - Search using Google for CC info is better/easier - Enter SITE:COMANCHECLUB.COM & then whatever - fast & easy :thumbsup:
  2. Used them in my '87 factory/euramtec fixtures - 38mm length IIRC - - Have them in my '89 with the S-10 mod - pretty sure 42 mm length on these - Anyway, good upgrade - -- - Not expensive most places - - Here's a current eBay listing: http://www.ebay.com/itm/42mm-8-LED-Car-Interior-Light-Dome-Festoon-Bulb-Lamp-White-12V-New-hv2n-/251382037291?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a87897b2b&vxp=mtr :wrench:
  3. Search is a good tool - - - Search using google is a great tool - - When using Google, 1st enter SITE: COMANCHECLUB.COM & then whatever you're researching - - Anyway, Undo your Radio/sound system/whatever you changed & then go after any problems ONE at a time - whatever you deem most important - Lotsa help here on CC but to get the most from the best be specific & let everyone know what they're being asked to opine upon - - - The year, engine & transmission of your truck are the minimum amount of info you should supply when asking for guidance - - - Good luck :wrench:
  4. Might help - - http://comancheclub.com/topic/32391-air-box-to-header-tube/
  5. Favorite beer types are free & cold - - - Mostly been hunting someplace warm last few weeks - - :group beer:
  6. Try to pick a time when traffic is least if you have to be out & about - Staying home is best - - Other drivers are usually more of a hazard than road conditions - - Parking lot practice is great & lots a fun or it used to be anyways - - School lots are usually chained/gated, store lots ok mostly but both attract the attention of the 911 cell phone a$$ whole do gooders according to my son - - . :MJ 1: .
  7. Here or DIY? - - - Fel-Pro Pan/Cover & Gasket Holders - - - - ES 72863 ES 72864 ES 72865 SnapUps AutoPepO'advans got 'em - eBay also AZ link: http://www.autozone.com/autozone/accessories/Fel-Pro-5-16-in-engine-and-transmission-oil-pan-SnapUps/_/N-26pm?itemIdentifier=155047_0_0_ :wrench:
  8. I've used 2 of these in Toyotas - - Trimmed the bottom edge - fastened 2 pieces 2x4 to floor after 1st contouring them to consoles mount points - - '98/'00 or so Nissan frontier & Xterra
  9. Answer is: A fairly frigid temperature - 4 degrees below zero :doh:
  10. Well, congratulations indeed - And here's a little post grad quiz - - What does the following represent? 0 AA BS MA PHD The answer is both germaine and contemporary :smart:
  11. Wow - Nice, clean, understated job - Few white PUs look that sharp - - :thumbsup:
  12. LCAs look like older Motion Offroads - Newer MOs have 3 zerks for their poly bushings - Not an expert, just been lookin' /tryin' to decide on replacement adj LCAs recently & yours with the shorter female half remind me of motions. :hmm:
  13. Grand Wagoneer - Forget the year - in my '87 - Ultra comfy wJs in the '89 - - '06 IIRC - Nice but the Grand Waggys spoiled me - Don't know what I'd do if a pair of grey GWs came along :wrench:
  14. I've used Rotella 15w40, a 40 base, higher temp, diesel oil for a long, long time in many vehicles - - - I have recently switched to Chevron Delo 400 LE 15w40 because of this info which I deem reliable - - Seems to be a tad better for the Jeep 4.0L & is no more expensive than Rotella. http://comancheclub.com/topic/36262-preferred-oil-weight/ :wrench:
  15. A Lights out/No nothing Quit's usually electrical prob A Stutter/sputter/stumble/whatever's usually fuel prob No start/No crank - Begin at starter & work backwards until you find power - Starter terminals then relay then ignition switch & so on
  16. BIOTEX - - IIRC - MJOTM May 2013 - Search is a good tool :thumbsup:
  17. This Forum or The Pub? Dunno, Anyway - lotsa ideas here - Not talkin' price - just stuff to get the brain working - Click on SHOP UNIVERSAL WIRING SOLUTIONS - - - - Some things that caught my eye for future projects: Momentary Start Switch Push/Pull On/Off Switch Headlight Switch - 4 Position Push-Pull Battery Cable Terminal Crimp Tool Auxiliary Fuse Block Assembly 1157 Led Bulb- Red 1157 Led- Amber 1157 Led- Blue 1157 Led- White 1156 Led Bulb- White 1156 Led- Red 1156 Led- Amber Modublox Courtesy Light Module Led Turn Signal And High Beam Indicator :wrench:
  18. How does it die? Sudden or sputter? - - - Next no start, if somewhere practical, begin at starter & work backwards looking for power - - - - Gonna have to get a volt meter or rig up a test light - - - - Inexpensive multimeters everywhere $3-$10 - - eBay HarborFreight Wal Mart . . . .
  19. All you need is the lever mechanism - Been covered here on CC a few - http://comancheclub.com/topic/32740-alexias-1987-to-1997-comanche/ comes to mind - also on NAXJA & Pirate - Anyway I used Alexias build IIRC - Is simple - Don't need new cable - existing cable just makes a big loop under seat & done - Worst part for me was removing foot assembly - After that just a matter of cutting the cable anchor/attachment thingy offa the FB bracket - attach to lever - grind/cut btm of L assembly flat- ck position/alignment of lever & console & bolt/fasten everything - I used a 97+ console & lever - took approx 2 hr - I'ma no so fast or care to be anymore :wrench:
  20. Mechanics wire will work - - - epoxy probably - I'd rough the tube surface & apply the stuff 3/8-1/2 inch wide-maybe 1/16 high - - - were it mine I'd use a torch & the round end of a big ball peen hammer r something similar to flair the tubes end - a little heat on the hammer-a little pressure & done - :wrench:
  21. Been done - - - Member here on CC used 87 celica seats - - no big dif 87-91 mr2 seats othern fabric - 87 celica seats basically same as mr2 - - all kinds info in DIY - - - Do the passenger side 1st - - - - Search is a good tool - - - :wrench:
  22. Six TBs? http://comancheclub.com/topic/11623-the-worlds-fastest-comanche/page-8?hl=clifford http://comancheclub.com/topic/11623-the-worlds-fastest-comanche/page-11?hl=clifford :wrench:
  23. Remind me more of Fleagle :brows:
  24. :rotf: Yes, I remember Joe. :rotf:
