13
Sounds good. I may just end up doing the new door handle route.
NOS tail light
eaglescout526 replied to Facuto's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
HOLY SCHNIKES!! -
Cranks but won’t turn over...
eaglescout526 replied to KatahGii's topic in MJ Tech: Modification and Repairs
On the fuse box. Big rectangle box closest to the wall on the drivers side kick panel. It will either be blue or black -
Ok. I see. Someone must’ve snagged it. Sorry about that. 1987-56000173. Supersedes to 56002521. There are three left. 1988-01. 56002857 goes to 56002858 goes to 55036328. None are left. I would oil it first just to try it and then move on from there.
You can try pulling it out and dabble some oil on the shaft and spin it to work the oil in. Probably some where from 93 down to 84 will work for a replacement OEM blower. There’s also a NOS blower on eBay(I think it’s still there)if you want to go that route.
High RPM Rattle/Noise
eaglescout526 replied to WanderingAccountant's topic in MJ Tech: Modification and Repairs
What kind of shape is all the rubber in? Motor mounts and suspension rubber. I don't know if that is your answer but it is a place to start checking. Having any of the rubber mounts and stuff worn out can lead to stuff like you describe. Someone else might chime in to give an idea to check. -
Lol, I don't know why but ive been hooked on saying it lately. A lot better than saying S**t ton.
Wow, that's damn clean for a NY MJ. Anyways, here's your build sheet: *D1 TRIM STYLE D1 - CLOTH BENCH -YY 169 Zone 69-Phoenix 1AA U.S. Dealer Retail 4HB Special Scheduling Condition II 5AL Low Series Tracking APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Elec,Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HAA Air Conditioning JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KDD LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PY3 Classic Yellow Clear Coat QY3 Classic Yellow Clear Coat RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA 19 SPKRS SRT High Perf Audio SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Build date 3/10/89 Body code TL61 Ok that makes a metric ton of sense why it is so damn clean. Its from the surface of the sun!! 169 Zone 69-Phoenix
Cruiser, glad you are alright. But this reminds me of the story of an old man who used a flame thrower because he didn't want to shovel 20 tons of white BS.
That’s the belt not buckled buzzer. There’s a hum that happens just before you start the truck. Have someone either turn the key or get under the fuel tank and listen for the pump to prime. -
HI-CNTRD - 1990 XJ Project
eaglescout526 replied to Drahcir495's topic in Member Projects: Other Cool Stuff
Well. You ain’t working on a Jeep unless there is blood and swearing. -
PM sent
You said you replaced the fuel sending unit. Did you replace the pump? When turning the truck on do you hear the pump prime for a second or two? Have you tested for spark as well? CPS is known to be a culprit for non firing conditions. -
I think you're right on that krusty. If you do have a set let me know. Surprisingly when I was looking at the catalogue today, There is one dealer who has the tube bumper bracket for the right side but not the left. I might call them and ask.
I wonder what the heck even has a 4.78 ratio.
That is true and I forgot you did buy those two. Better in someone’s hands than in the junk yard.
Thats a shame. When you do get to it and if it’s in good shape, shoot me a PM!
Just the one if someone has an incomplete set. If someone wants to part with a complete set but not separate them that works for me too.
Does anyone have a straight drivers side bumper bracket? I thought someone had those on repop status but I looked and came up with nothing. Unless I’m just missing them.
I no longer need these. I will hit my favorite salvage yard and snag some rear door handles from XJs.
I might have to get whole of this person for just the switch plate.
*X1 -Y1 APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JDA SPEEDOMETER - 140 KILO PRIMARY JFH TACHOMETER - MECH JGB Clock - Digital KQJ LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAG PE4 Punk'n Metallic Clear Coat QE4 Punk'n Metallic Clear Coat TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 9/15/86 Body code TL61 This is a Canadian MJ. Man I don't know how I missed this one but I'm glad Pete brought it to my attention.
Buck, I appreciate that. AMC salvage that I frequent doesn't have many XJ's with driver doors left. Ill probably head over there tomorrow to see if I'm wrong.
