13
Yup! It’s a newer number but still made to this day.
I haven’t seen anyone on here sell them but I did say at some point that Chrysler still makes the water pump for the 4.0L. I have two reman 2.5L pumps.
No problem. Just remember. AMC was All Makes Cars
91-92 are the HO years and are incompatible with the Renix years. 84-90 should work just fine with 84-85 being carb years for all engines and 86 being TBI for the 2.5L. The fuse block is the same as what is used by GM in the same time period.
'91+ 2wd knuckles on '88 2wd?
eaglescout526 replied to Coyote's topic in MJ Tech: Modification and Repairs
Yeah it’s a weird thing AMC did but I’m sure it was a cost effective design for 2wd but they probably weren’t selling as many 2wd Jeeps as they were 4wd. If you think it’s genius to have the hub and rotor into on assembly but dumb when the entire thing has to be changed. But yeah I only recently discovered this with an 86 2wd axle I just got. later year knuckles will work, just if you’re after that big brake upgrade, I think the knuckle is completely different later than the early years. -
The older 84-86 2wd knuckles are the same as 4wd knuckles. You’d just need the spindle, hub and rotor. The later ones are smaller in terms of big brakes. -
86 comanche Cherokee to comanche swap?
eaglescout526 replied to Wvmountandrifter's topic in MJ Tech: Modification and Repairs
AX4/AX5 and the Chrysler A900 series. -
Might want to get a 55 gallon drum of brake cleaner for that.
*W7 Cloth Lo-Back Bckt -YY 3LY ADA LIGHT PACKAGE AGL APA MONOTONE PAINT PACKAGE CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT CUF FULL LENGTH FRONT CONSOLE DGQ TRANSMISSION-4SPD AUTOMATIC ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBF REAR BUMPER - STEP TYPE (BRIGHT) MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWF BOX SIDE RAILS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHB HVY DTY/AUX TRANS OIL COOLER NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY PE4 Colorado Red QE4 Colorado Red RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT TBL TIRE CARRIER - INSIDE WJN 15" Aluminum Wheels XEA TOW HOOKS Build date 11/2/86 Body code JP62 Sold by J J AUTOWORLD, INC., ASHLAND OH
Trouble in the Suez!
There’s some NOS ones. I might have one for cruise but none for without.
*X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 141 Zone 41-Cincinatti 1AA U.S. Dealer Retail 5KN Metro Cars of Detroit ADL Skid Plate Group ALN APA Monotone Paint ARL BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHN Command-Trac Part Time 4WD System DHT Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3D STRIPE/BADGE/MOLDING/COLOR KKE LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon NHM Speed Control PS3 DOVER GRAY MET CC PRI PNT - HS3 QS3 DOVER GRAY MET CC SEC PNT - HS3 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRP Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z59 Left Front Spring Group Ix Z5B Payload Rating - 1800# Z78 Right Front Spring Group VIII Build date 8/27/89 Body code JL62 Sold by BALES MOTOR CO INC, JEFFERSONVILLE IN
Lol right place right time for me.
Lol no worries. I caught that it needed to be moved anyways so I figured I would post the build sheet and what not.
That interior looks like something out of those concept drawings of what the future could look like from the 20's and 30's. And a little bit of futurama too with the interior. Kinda neat they touched an old Kaiser/AMC designed Jeep other than the SJ.
*A6 Seats - Vinyl High Back Bucket -H9 APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP KD8 STRIPE/BADGE/MOLDING/DELETE LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) PYC Amped QYC Amp'd SBA POWER STEERING TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 2/24/87 Body code TL61 Sold by TAYLOR A-J-R INC, TAYLOR MI
Oh yes it will be and I can't wait for it!! Also went and finally saw a Street Comanche in person. No. 20 to be specific. Got some nice glamor shots. I absolutely LOVE @CactusComanche's street MJ. I also got a tour of the whole farm while I was there. Both learned a few new things and learned you could easily mount an XJ rear bumper using how the Street MJ mounted its custom rear bumper. Was absolutely worth the drive, plus needed to brake the oil change in LR and the new T-stat which both worked great! And that new rear leaf did a great job too! Which means no more vibes woooo! Now to be annoyed by two different looking leafs under my truck lol. Gotta meet up again and hit a couple car shows as they start returning.
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
That’s a failure right there. How old did you say that one was? I’d try to get it warrantied or something like that. Also when you’re new one comes, I’d put in longer u-clips or cotter pins to avoid their self removal.
- 10 replies
Front Engine Stabilizer 1986 Comanche 2.5L
eaglescout526 replied to MOS86MJLB's topic in MJ Tech: Modification and Repairs
Really? This I didn’t know. Wonder where they all went. -
Trying to get you the history but the VIN look up isnt responding.
*Q7 Cloth Low-Back Bucket Seats -SA Charcoal 167 Zone 67-Charlotte 1AA U.S. Dealer Retail 26H Customer Preferred Package 26H 2TH Customer Preferred Package 2TH 3VU Customer Preferred Discount 4HA Special Scheduling Condition I ADA Light Group ADL Skid Plate Group APA Monotone Paint ARM Radio AM/FM Cassette BAR 90 Amp Alternator BCD 500 Amp Maintenance Free Battery BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHS Floor Mount Automatic Shift Lever DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ Dana 35 Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KLT KWD LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE Ambient Light LDA Underhood Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Bumper MCA MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank NHM Speed Control PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z83 Right Front Spring Group XII Build date 9/8/91 Body code JL61 Sold by BOB FISH JEEP-EAGLE INC, GRAFTON WI
If you got an adapter for the quick connect on both ends they could. I think the Renix era has unions as mine still has a union for the lines.
- 10 replies
