13
The u-clips that hold the hoses into the housing of the slave cylinder are crap too and are too short to really help hold the hoses in place which is dumb. Someone on here replaced those u-clips with either cotter pins or used a longer u-clip and bent the ends of the clip outward to prevent movement. I have had two slave cylinders fail on me because of those u-clips sliding out.
- 10 replies
Yeah it sucks to lose the original to the engine housing but I am glad I had another that was still era correct. Now I need to find another one to have as a back up. Aint that a lucky catch. All I decided to do was replace the pass leaf cause it was old and I had already replaced the drivers side due to a broken leaf. Ended up catching a ticking time bomb.
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
The aftermarket scene for the internal slave cylinders are crap. The only good brand that we hope you got was a Luk branded one. Some others have had luck with some other companies but Luk seems to be the only one that won't blow out a seal or a line for normal needed pressure for the clutch. Just time and patience, some teflon tape on the threads of some of the flare nuts can help make sure no air or leaks enter the system.
- 10 replies
Wow.....Glad I caught that!! Now she sits better and I can now see how crooked my parents driveway is. Thats the main leaf too!
- 657 replies
- pioneer
(and 2 more)
Tagged with:
What the hell?! Something that shouldve been an hour job turned into an ordeal. Replacing the T-stat, how hard could that be right? Very... Removed housing, removed t-stat, removed old gasket, cleaned surface, install new t-stat into housing, put gasket over, us bolts to help keep it all aligned, install, tighten down, leak, wait leak? Fought to fix the issue, tightened down the bottom bolt cause thats where it was leaking. Instead I cracked the housing. So I went and grabbed my spare housing from the other 2.5L I have. installed that, still leaked. Fought with it, sanded the engine side mating surface to make sure all gasket and hunk was off. Installed, still leaked. Took new housing off, sanded down new housing, installed. Still LEAKED!! I thought, the hell is going on here? Tightened the bolts to spec, cleaned both surfaces. Well turns out I ruined the gasket and my father looked at the housing cause he was right there and saw the bottom mount was bent downward. So I fixed that, went to the auto store, got two gaskets, a fel-pro and inhouse. Installed in house cause it had the sticky side and viola!! No more leaking and now I have a happy engine at 210*. Before it would only barely hit 210 but run at 200. I think the T-stat would get stuck open and here's why I think so: This thing is brown and I have no idea why. Go back to 2018, I had a bad head gasket and drove on it till she ran like major poo. Changed that and all the fluids, engine ran really cool like too cool to pass emissions. So I swapped in this stant 195 and she ran great up until this past winter where I think it was sticking open. We shall see.. Now to replace the pass rear leaf and valve cover and fix the other three valve covers paints with Mopar paint.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
Nope. Not 86 specifically. Best part about this set up is 86-90 or whenever Chrysler changed to the external again is the same bell house. So everything will be plug n play.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
So. Close! Just need the fork. External, front retainer, ball and line are NOS. Bolts, spacer and fork will not be. can't wait to have this mod done.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
Chunk, A 1984 XJ
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Here are the two power seats I am workin with. On the plus side, I can cut and modify the mounting brackets to fit the drivers side which ought to be a snap. The other one is just a base, might be missing a piece or two when compared to these two. -
*X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 105 Zone 05-Chrysler Military Sales 1AV Export O.M.S.C. U.S. Specifications 4FV Assembly Plant Tracking 4HA Special Scheduling Condition I 4HC Special Scheduling Condition III 5KM AMES Department Stores 8ED Miscellaneous Intl Dealers ALM Longhorn Southfork Package APA Monotone Paint ARL 300 Premium Group BAQ 61 AMP ALTERNATOR BCX Dual 700 Amp Maint. Free Batteries BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMF 4.10 Rear Axle Ratio DRJ Dana M235 Wide Rear Axle EPD ENGINE - 2.5L I4 TBI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3B STRIPE/BADGE/MOLDING/COLOR KKE LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PB3 Intense Blue Pearl Coat QB3 Intense Blue Pearl Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YCA Outside Lease 93016 YGA Without Billable Fuel Z01 Rear Spring Group I Z5A GVW/Payload Rating Z63 Left Front Spring Group XII Z82 Right Front Spring Group XI Build date 5/14/90 Body code JL61 Sold by OMSC - RTE DE LA GLANE107, FRIBOURG SWITZERLAND EX
Project: Cruise, a 1960 T-bird.
Major major progress. I still need to clean contacts and what not. But fuel is PUMPING!!! It’s a slow process but it’s gonna take a few battery charges to get it primed and ready to fire on its own. Once it does, gonna move forward, reinstall everything and do the brakes and hope she drives. -
1990 MJ starts but won't stay running
eaglescout526 replied to Epplebee's topic in MJ Tech: Modification and Repairs
It could be strong enough of a signal to tell the ECU that “we are good to fire” but the signal could easily die out afterwards. -
I would test that CPS too just to make sure it’s putting out the proper AC voltage signal for the ECU. -
Project "It's a Jeep Thing" - Huntr's 87 MJ Build
eaglescout526 replied to Huntr's topic in Member Projects: Your Comanches
Needs some hooks on the back side to hang wrench’s while working. -
Honestly, maybe a good weld right in that spot just might do it. Theres plenty of metal there since the engine mount is right there.
Chunk, A 1984 XJ
I still need to get pics of the seats but looking in the catalog at the drivers side version of the power seat, I might be able to go to town on cutting and fabbing for the seat mounts. heh. -
My long 87' MJ Story/Build Thread
eaglescout526 replied to 89comanch's topic in Member Projects: Your Comanches
The 87-90 blue cluster is rare as it was an 87 to early 88 cluster before the black cluster came along. You can find that cluster style with the older 84-86 XJs and 86 MJ's but they have a different speedo connection than their later counter part. As for the two spoke steering wheel, its uncommon but most of everyone swaps them out in favor of the stylish three spoke sport steering wheel. -
Youll need alot more than just the radio probably. Like the antenna, its wiring, the bezel, nut and speakers and any other wiring probably. What I find amusing is it has the full blue cluster but no radio and the two spoke wagon wheel. -
Holy crap! Radio Delete still in its place!! -
*X3 -YY AGC Black Ram 1500 Sport Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCK 4SPD MANUAL TRANS - AISIN SEIKI EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PYB Detonator Yellow Clear Coat QYB Detonator Yellow Clear Coat RAC RADIO - AM/MTR TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 2/24/88 Body code JL61 Sold by AUTONATION CHRYSLER DODGE JEEP, SEATTLE WA
Tasteful woodgrain swap *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ AGR AJY Popular Equipment Package CGX Head Restraints-Outboard Seating, RR DGZ Transmission- 3-Spd. Automatic EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE Build date 8/12/85 Body code TM62
Thats got a Jeep SE camper shell *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE ADB PROTECTION GROUP PACKAGE ADL SKID PLATE GROUP AGY AJZ APP TWO TONE PAINT PACKAGE - (MEX POLICE) BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGX TRANSMISSION - 3-SPEED AUTOMATIC DMN 4.10 Axle Ratio EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MD8 Delete Front License Plate Bracket MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY RAC RADIO - AM/MTR SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN WJM Wheels - 15 x 7.0 Chrome XEA TOW HOOKS Build date 10/11/85 Body code JP62
Sounds like a good excuse to give the engine a good bath on the outside and pinpoint some oil leaks. Can’t say I have had anything similar except when I put the gasket base on my TB on, which was the wrong one so it had a vac leak. Guess that comes close.
