eaglescout526
Administrators
    13
  1. As far as I have seen, the only difference in early vs later is how they get installed. Early is riveted and later is bolted in.
  2. I got one of those. I put it on the rear window of my camper shell. Reminds me of what I am driving in the rear view lol.
  3. *Q7 Cloth Low-Back Bucket Seats -SA Charcoal 173 Zone 73-San Francisco 1AA U.S. Dealer Retail 4AF American Coin Merchandising 5AP Airport Connection APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKB Floor Carpet CKN Cargo Compartment Carpet CKT Cargo Tie Down Loops CKV Cargo Area Storage CLE Front &&&& Rear Floor Mats CSA Spare Tire Cover CSC Cargo Compartment Cover CSR Passenger Assist Handles CUF Full Length Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH Dana M30/181MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle DSA Trac-Lok Differential Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GED Tinted Rr Drs/Qtr/Liftgate Glass GFA Rear Window Defroster GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GRB Entire Fleet Key Alike (FREQ 6) GSB Right Convex Mirror GTB Power Heated Mirrors HAA Air Conditioning HGA Hood Insulation JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBE Instr. Panel Diamond Weave Bezel JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JHB Rear Window Wiper/Washer JJA Cigar Lighter JKB MOPAR Hood Lock K3S DESERT SAND P/C - FENDER FLARES KKE LAF Seat Belt Alert-Driver Seat only LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LCD Map/Dome Reading Lamps LDB Cargo Compartment Lamp LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps MB3 Bright/Body Color Front Bumper MB7 Bright/Gray Mist Rear Bumper MCA Front Bumper Guards MCB Bronze Fascia Applique MDA Front License Plate Bracket MFM Grille-Black/Bright MHB Bright Windshield Moldings MMC Rear Qtr Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I MMP MOLDING - DOOR EDGE GUARDS MTA Rear Fascia Skid Plate Applique MWA Roof Rack NAE California Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NFA 20 Gallon Fuel Tank PQ9 DRK BALTIC BLUE M CC PRIMARY PAINT - HQ9 QQ9 DK BALTIC BLUE MCC SECONDARY PAINT - HQ9 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBL Inside Mounted Spare Tire TMW P215/75R15 OWL All Terrain Tires WJN 15" Aluminum Wheels XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z03 Rear Spring Group Iii Z58 Left Front Spring Group Viii Z5B GVW Rating - 4900# Z77 Right Front Spring Group VII
  4. D35....sadly. The 44 still has its own code.
  5. Thank ya! Oh yeah and thanks! Best part is the damage and holes are are no where near where my supports were mounted so everything lined up good. The rear supports were interesting to figure out though. Also took three packs of 1” grip tape and cut them with a cut off wheel to get the right width to fit in those grooves.
  6. Oooo how about you pay us a penny to buy it? Lol. I am interested. Curious as to how you found a company who said they would make them to Mopar spec.
  7. I killed an REM with this trick
  8. Hmmm. As soon as it dies, have you check the voltage at the battery?
  9. Can you keep the truck going long enough to get a multimeter to the battery to see if it’s outputting? I’m almost wondering if something in between the battery and the alt is bad. without the solar panel.
  10. Oooo this is a tricky one. @SoCalManche is having a similar issue that is still trying to solve. Except his runs and drives. Well let’s start at the top. Is the battery itself good?
  11. Actually quite a beautiful AZ springish day
  12. I’ll get some a little bit later today
  13. Short beds don’t cut it out here. You should see the Ford and GM trucks modified to haul other peoples scrap junk they come and collect.
  14. My girlfriend says the same thing all the time and I’ve witnessed it a few times. Kinda sad when an Arizonan can drive in the rain better than those who live in a state where it rains a lot.
  15. Weird. You’d think AZ would be the one to freak out over rain storms. Instead we just get people who can’t drive in the rain.
  16. That has been added to my shopping cart! Good find. Problem is is the car has sat since 98 which was the last time it was on the street. Something tells me the PO's father was messing with it at one point for a moment to see why it was running hot. Its missing a fan shroud which probably at the time was no longer made until now.
  17. Someone made use of a Ford latch. Wonder if it was JMO.
  18. @jdog Didnt you make use of a ford one?
  19. Finally got a set of ventshades in. Had to order a Cherokee kit but thats ok, same doors, just extra rears now. Also did get a set for Chunk.
  20. Mopar Power Antenna for Jeep Cherokee Comanche 56003151 | eBay
  21. I’ve never used centric. Had the luk slave cylinders for a while and they were great! The crown units I have used were cheap and are cheap but I didn’t have time to wait for the parts to show up.
  22. Thank you all!! Part has been secured!
  23. Perfect! May I task you with this challenge?
