eaglescout526
Administrators
    13
  1. *A6 Seats -YY 3LR APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DDQ Transmission - 5-Speed Manual DMR 4.10 Axle Ratio DSA LIMITED SLIP DIFFERENTIAL ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MWB SPORT BAR NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY PXH QXH SBA POWER STEERING SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE TBL TIRE CARRIER - INSIDE Build date 5/4/87 Body code JL62 Sold by STEVE CHRISTY CHRY-JEEP, TUCSON AZ
  2. The metal ones are vastly superior. I had one of the plastic inserts break and I just took a plastic one, cut the hook off and used it to retain the metal one.
  3. Not a clue. One of those gut feelings. Plus it also acts like it’s kinda out of time but that could be a vac/distributor issue and not a carb issue.
  4. Something tells me that I rebuilt the carb wrong.
  5. Hmmm. Interesting.
  6. Parts came in. I should be able to get at it this weekend, dump some gas into the tank and install some stuff and hopefully she will run in her own without the assistance of an electric pump. We shall see.
  7. You’d think there would be more info on just general things like having a damn catalog from way back when on accessories.
  8. I know I’ve jokingly asked parts specifier if they have any accessory catalogs from the 80’s. They told me no.
  9. I like the pic of the plate that says 231 AMC. Don’t see that plate much.
  10. I can't take all the credit for that, jdog did most of them, but power housing what you and Pete did with all those auction MJ's took me back to when I first started the venture.
  11. Sounds possible. I know my original one snapped at the e-brake lever.
  12. Did you adjust the equalizer nut? (The nut that holds 10 to 16)
  13. I don't see any springs but I see some clips that I have never seen before anywhere. I did zipties once and it still moved. Its fine right now as its pinched by the corner of the gas tank. I wonder if its just because its 30+ years old.
  14. Talk about flipping a 180*.
  15. I just remembered about this. If I am right, its the cable that goes from the TB to the trans, there arent any left as NOS.
  16. Now that is a damn neat find right there. Wish I knew the straight story about LR. All I have to go off of is she came from NY and my grandfather bought her from some people towing her behind a motor home.
  17. Has anyone ever had any issues with this cable? Mine likes to go back to a position to where it grinds on the back side of my rim. Than being said, I unbolted the loop it is held in and moved the cable to over the gas tank corner so it is more pinched into place but it still wants to move but only moves about a millimeter. Second question is, was the cable over the corner of the gas tank from the factory? I dropped my gas tank in 2016 and never paid attention to such until the wheel and cable started getting shaved.
  18. He’s been pretty damn busy lately.
  19. There’s a Will Smith interview somewhere where he says, “social media allows you to share how stupid you are and get made fun of for it, as to where when I was a kid, we could be stupid and no one would know about it”. Just a paraphrase.
  20. Electrolysis or vinegar work best for just metal stuff but vinegar is a bit harsher on the metal vs electrolysis. Could just strip the whole truck and dunk it in a giant MJ shaped tank for electrolysis lol. But what most of us do for rust on the body is just cut out the cancer and put in new metal. Sometimes sanding or wire wheeling the light stuff away isnt bad either.
  21. *Q7 Cloth Low-Back Bucket Seats -SA Charcoal 167 Zone 67-Charlotte 1AA U.S. Dealer Retail 5KR Midland Corporation ADA Light Group ALR APA Monotone Paint ARM Radio AM/FM Cassette BA1 100 AMP ALTERNATOR BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUF Full Length Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2B STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KLH LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE Ambient Light LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Bumper MCA MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 10/4/89 Body code JL61 Sold by GOWEN CHRYSLER PLYMOUTH JEEP EAGLE, CHARLOTTE NC
  22. Great question! I am not at my computer at the moment but I will look. If not, I know where three XJs with the 2.8L with an auto tranny are.
  23. New head bolts won’t hurt. When I removed my cylinder head, some bolts were rusty, damaged threads or both. I blew out my current evap with compressed air. No problems. Idea is to make sure there is not moisture or oil left from the old system in the evap. Course Minuit might get onto me about such. Not sure on how to flush them though.
  24. Crown actually makes those. They’re called well nuts. P# 34201348
