13
*W7 Cloth Lo-Back Bckt/Red Accent Seats -SA Charcoal 8F6 Sweden Country Code 030 ADA LIGHT PACKAGE ADL PACKAGE - 4X4 PROTECTION AGL APA MONOTONE PAINT PACKAGE AWH POWER EQUIPMENT GROUP AWJ Visibility Group BCQ Battery - Maintenance Free CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGQ TRANSMISSION-4SPD AUTOMATIC DSA LIMITED SLIP DIFFERENTIAL DTA ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GTZ MIRRORS - MANUAL REMOTE JAY Instrument Cluster w/Tach JDA SPEEDOMETER - 140 KILO PRIMARY JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBF REAR BUMPER - STEP TYPE (BRIGHT) MFD BRIGHT GRILLE - TYPE I MUX MWB SPORT BAR NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Colorado Red QE4 Colorado Red RAC RADIO - AM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL XPF PROTECTIVE COATING AND REMOVER Z5B GVW/PAYLOAD RATING Build date 11/2/87 Body code JP62 Sold by HARRY KARLSSON BILIMPORT AB, PARTILLE, SWEDEN
Project: Cruise, a 1960 T-bird.
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Ok so it’s starting to warm up in a bad way so I may or may not be able to move more forward as I’d like with the T-bird. But I went over today and I cranked it a little bit till the battery died. Took out the battery and let it charge for the moment I was there. Replaced the starter solenoid with the one I thought was shorted. It wasn’t I was just dumb and put the ground cable on it the first time and that’s what caused it to short like it did. Whoops! Part of me knew this at the time but not well enough. Anyways new one installed, cranked it and she fired right up which is fantastic! -
16 gallon vs 23 gallon
eaglescout526 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
I bet if you either bent that vent tube up or cut it back a little, you might yield another gallon or two in an 18. -
WOW. Thats California prices right there. -
Short beds should only have the 18 gallon tank. If you got a long bed tank into a short bed, I would like to see that. I know some SWB guys would like to as well. -
BEST. UPGRADE. EVER... Got it all swapped and set up this morn. Just went for a drive and boy! Do I have to get used to a very light clutch pedal. But it engages soooo much better and I can drive without keeping my foot on the clutch from loosing pressure in the line. But I think I discovered something. Last night I get the trans separated. I noted how the clutch pressure plate looks due to me braking off a bolt a while back. So I get the new to me flywheel on and NOS clutch package on and noted how much more compressed the pressure plate fingers are. Looking back where the broken bolt was, 3 or 5 fingers were sticking further out than what the others were. I think that was my problem all along without really thinking one bolt would make that much a difference and I will say, it clearly does. Especially when the internal slave was probably working harder than what it was designed to do. Fun stuff though!!
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
No worries! here's your info: *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ CGX Head Restraints-Outboard Seating, RR DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NMC MAX ENGINE COOLING RAC RADIO - AM/MTR SBA POWER STEERING SUA TILT STEERING COLUMN WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 10/24/85 Body code JL62
You are short a digit on the VIN. I can't run it.
*X3 -SA Charcoal AGC APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCK 4SPD MANUAL TRANS EPD ENGINE - 2.5L I4 TBI GAS LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Colorado Red QE4 Colorado Red RAC RADIO - AM/MTR SBA POWER STEERING TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 2/10/88 Body code JL61 Sold by NORTHWEST CHRYSLER JEEP DODGE, BEAVERTON OR
Trans is out, bell house swapped, clutch swapped, NOS clutch hose tow the master swapped in, so far so good. Stopping for the night. Learned that the front bearing retainer bolts on the trans hold oil back so that was a fun little road block.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
Done. I’ll get a build sheet soon.
Perfect! -
*X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 131 Zone 31-Boston 1AA U.S. Dealer Retail 4EA Sold Vehicle 5KN Metro Cars of Detroit ADL Skid Plate Group ALN APA Monotone Paint ARL BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHN Command-Trac Part Time 4WD System DHT Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KKE LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRP Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z59 Left Front Spring Group Ix Z5B Payload Rating 1800lbs Z78 Right Front Spring Group VIII Build date 4/29/90 Body code JL62 Sold by MEDLYN MOTOR INC, MILFORD NH
And here I have the contradicting build sheet from the parts catalog: *X1 -YY 3LX AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DCB Transmission - 4-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY PWB QWB RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL
I’d be willing to do a write up on all the specs and what not of the gas tanks and FSU’s. Would be an invaluable thread with hopes that all those questions could be answered with one topic. -
Sending unit identification
Thats the fathers garage special lol. That hammer has actually proven mighty useful for its stature. What happened was many years ago, my dad was using it and the head fell off and the wood split. So he cut it down and whittled it to fit the head. -
My bad, it is longer than the 18 gallon tank. I edit my post to reflect. -
The 16 gallon is definitely longer than the 18 gallon tank. But the 23 and 16 gallon are one in the same tank only with the fuel "baffle" being different to let less or more fuel in. Once the light returns tomorrow morn I will edit the main post with the pic of the 23 gallon. @Torq_Shep, not sure if you installed the tank yet but would you mind providing us the dimensions of this lovely tank I sold ya? -
Actually I don't have a good pic of the internal to an 18. But I will say its the exact same, but it fills more direct rather than the fill tube on the 16/23 being curved toward the slosh pan. -
Pretty much! Call it a fuel hack lol. Hang on a moment. I have pics of an 18 gallon. -
I often dream that Chrysler did the right thing and kept the first one, or at least AMC doing so with both the first XJ and MJ. I am willing to bet they are either A, in the Romney family or B, somewhere in Chryslers storage.
I would like to just do a PSA since I couldnt find the internal difference anywhere via pics or word so I took it into my own hands to figure it out and I am glad I did lol. 16: 23.5: don't worry, I plan to clean it out before use. BUT! Note the shorter vent pipe. And only reason why I did this as the tank I bought a while back from a member in CA didnt have the tank ID plate on it so I had to find out and verify. External differences 23/16 tank: Dims: (from lip to lip) 37"L 17 1/2"W ~15H 18 tank: Dims: ? 16 and 23 side by side
SOLVED!! 16 gallons have a short lever arm! Thats why the gauge can go past full! So 18 and 23 share the same sending unit according to the catalog which means I can now sell those three sending units! Look at that arm! Its like a babys arm compared to the ones I have. -
Just a bit younger than Chunk by a month. jdog found one a while back that was made in 83.
