Greentoy
Greentoy's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. I understand that JeepCoMJ kept the SFI from F body car, but I don't see any info on the fact that the oil pans do not swap from 2.8 to 3.4 without keeping timing cover and STD water pump. Then you would not have proper crank sensor for SFI. What am I missing here?
  2. We're in the middle of this swap in an 85 XJ. Was your modification to the oil pan absolutely necessary? I ask because our plan is to lift the xj about 3 " and I wonder if that will give adequate clearance for the pan. Thoughts?
  3. It threaded into a new m18 fitting perfectly and when comparing it to the one I got from the salvage yard, it’s a completely different part with a 13/16” hex on it too. Sent from my iPhone using Tapatalk
  4. I’m not sure, it was in the core pile ready for scrap. [emoji2369] it is definitely a very different thread and part than the one I had in there. Sent from my iPhone using Tapatalk
  5. I appreciate all the info on this topic. I ended up getting lucky and finding a fitting on a 4.0 core at a local salvage yard this afternoon. [emoji106][emoji106] So now everything goes together really well! Still wonder what vehicle ever had the 2.5 with an 18mm thread for filter since I can’t find any filters with that thread at my local parts store. [emoji2369] thanks again! Sent from my iPhone using Tapatalk
  6. If I could just run the metric filter, I’d be fine with that. The problem that is weird here is that neither the metric 20mm or the 7/8 imperial filters fit the truck. The threads of my adapter are 18 mm and I have no idea what it originally came off of. Sent from my iPhone using Tapatalk
  7. So I took my existing adapter down to the hardware store and the filter side of my current adapter is m18 thread. I’m trying to find a filter to put it back together for now. That way I can order the 3/4 16 part for next time. Thoughts? Sent from my iPhone using Tapatalk
  8. So, I was able to get it off and I’m guessing that I do have the 3/4 size if I understand the pictures properly. Looking at the fitting though it doesn’t seem so bad. Is this minor wear enough to make the filter so loose? Guess I need to go get something 3/4 to compare. Sent from my iPhone using Tapatalk
  9. This is good info! Thank You! I'm going to get it off today and see what i have for sure.
  10. I'm going to try to get if off again later this morning after work.
  11. I tried to unscrew it, but it was really tight. I was worried I would break something if I forced it. I am getting the filter for a 94. I doubt that the PO put the 88 nipple in it since he left everything else fron the 94 engine. Maybe I should be asking for a 95?
  12. Good evening all! I have a 94 (I think) 2.5 in my 88 MJ. Shortly after I got it, I changed the oil/ filter(stp) and when I ran the truck, the oil filter popped of dumping all the oil out (not fun). I went back to the parts store thinking I had a bad filter, exchanged it for a wix and it seemed to go on ok. I've done a few changes since then with no issues, but today I went to do another change still using wix filter and they won't tighten up (I've tried 2). I think that my threads may be stripped. It seems that the threads may be an adapter threaded into the block. Does this part unscrew from the block to be replaced? Does anyone know where i can get the part? or the part #? Any help is greatly appreciated!
  13. My old switch is missing. PO pulled all a/c stuff. That picture is the dryer I ordered from Rock auto for the system. Sent from my iPhone using Tapatalk
  14. Hey guys I was just searching posts to see if anyone answered this before and I came across this thread. I need a low pressure switch for my 88 Comanche with 2.5. It has the dryer mounted switch. I went to all my local parts stores and they show a switch with male fittings on the switch. Mine is a male fitting on the dryer which means I need a female fitting on switch. Does anyone know the part number for the proper switch I need? Thanks in advance. Here is a pic of my dryer fitting (sorry for the poor focus).
  15. This^^^ Sent from my iPhone using Tapatalk
