Content Count
52 -
Everything posted by Greentoy
Need Help - Dashboard Replacement and Adding A/C
Greentoy replied to VintageJC's topic in MJ Tech: Modification and Repairs
This^^^ Sent from my iPhone using Tapatalk -
I hadn’t either, but as soon as I swapped the full Gage cluster in place of the dummy lights, my alternator quit charging. I figured it was a bad alternator since it took a few days to run out of juice and die. Replaced alternator and still no charging. The cluster I picked up was on a YJ with v6 I believe. The alternator on both the 4.0 and 2.5 both need an exciter wire circuit in order to start charging. That is handled by the light in the dummy cluster and somehow must be handled by a diode built into the gauge cluster. I suppose it is possible that the v6 models use a different alternator
No worries Gentlemen! Thanks for all the good info! Sent from my iPhone using Tapatalk
This truck was originally automatic? I would have never known! Whoever did the conversion, did a great job.
AX4 Sent from my iPhone using Tapatalk
1988 Comanche 2.5 2x4 Tag is unreadable On the road in great condition in El Paso, Tx Sent from my iPhone using Tapatalk
Congratulations! That is a great accomplishment! I never had the opportunity to do scouting growing up since we didn’t have a good troop near us at the time. I am currently the Troopmaster for a Trail Life USA troop here in west Texas. (TLUSA came out of BSA in 2014 when the board split) It has been an amazing experience to do with my son. We are getting ready for our annual 50 mile/5 day canoe trip through Big Bend National Park. It’s one of my favorite trips we do all year. What was your freedom project? Sent from my iPhone using Tapatalk
Jesse J, I just saw that gladiator bumper, and I like it too! I really am a terrible MJ owner! LOL
$40 for the pair! You did good!
Thank You. I have had some people really hate on it on another thread. (cardinal sin or something?) Most have liked it though. I like it, and that is all that matters. Cost $55 instead of $250-350 each on ebay for oem.
Coolwind57, That's pretty much correct. The mounting tab on the back of the watertight wrangler lenses matched up perfectly with part of the rear housing allowing a small bolt and locknut to be used to fasten it securely. I used a black adhesive caulk (Flex seal) to fill the small gaps in the cutout, then taped off the new lenses and shot the whole thing with spray bedliner to match the texture on both pieces while adding durability. I wish I had taken pics or video during the process, but the fact is that even I am amazed at how well they turned out.
Coolwind57, I used the original cracked tail lamp assemblies as a sort of adapter for the wrangler lights. I did not cut any sheet metal and retained the original mounting screws so I could easily go back to oem later if desired. Sent from my iPhone using Tapatalk
Let’s discuss taillights
Greentoy replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
KoopaKid, Yeah, mine were both broken and covered in tape when I got the truck, so I didn't have anything to lose. -
Ok, so today I got the new alternator installed and still no charging I wanted to explain what I figured out to possibly save someone else the trouble in the future. I figured that I needed to go back to the cluster swap again because that's when it started acting up. Everything I read online as well (as everything I've been told on the forums) is that the Tan wire dead ends at the cluster with gauges and is only used on the cluster with dummy light. The yellow wire did not change and tested good at alternator pigtail. I pulled the cluster again and inspected it more closely where the tan
I apologize for my stupid questions in advance. I am new to Renix jeeps. Most Gm CS130 alternators use the PLFS connector where only the S (sense) wire and the L (lamp) wire are used but it seems the Renix system uses only the L (lamp) connection (tan wire) and the F (field) connection (Yellow wire on mine.
