eaglescout526
Administrators
    13
  1. It’s a 7 piece grill. So behind the headlamp/turn signal bezel is a little bezel to round off the upper and lower trim pieces. Chrysler did away away with the 7 and simplified it to a 3 piece where the upper and lower metal trim is now apart of the grill and headlamp bezels along with the side marker round off piece. I’ll post the parts diagrams later.
  2. Is it at the Prescott valley junk yard?
  3. *X1 -YY 3LX AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Colorado Red QE4 Colorado Red RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL YJP NEW VEHICLE SERVICE - WINDSOR Build date 10/18/87 Body code TM61 Sold by SOUTHERN CHRYSLER JEEP AT, CHESAPEAKE VA
  4. *W7 -H9 ADA LIGHT PACKAGE ADB PROTECTION GROUP PACKAGE ADL SKID PLATE GROUP AGL AHL HEAVY DUTY INSUL PACKAGE APB TWO TONE PAINT PACKAGE - I APC TWO TONE PAINT PACKAGE - II AWH POWER EQUIPMENT GROUP BCQ Battery - Maintenance Free CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGQ TRANSMISSION-4SPD AUTOMATIC DMR 3.55 Axle Ratio DSA LIMITED SLIP DIFFERENTIAL ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LNJ Fog Lamps LPE EXTERIOR CARGO LIGHT MBF REAR BUMPER - STEP TYPE (BRIGHT) MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWB SPORT BAR MWF BOX SIDE RAILS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL PA2 SILVER MET CLEAR CT PRIMARY PAINT - FA2 QYC RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE TBL TIRE CARRIER - INSIDE WJN 15" Aluminum Wheels XEA TOW HOOKS XJH LOCKING FUEL FILLER CAP YJ9 YJA NEW VEHICLE SERVICE Build date 3/3/87 Body code JP62 Sold by FCA US LLC, ORION TWP MI
  5. Sounds like key parts needs to make these things too.
  6. I went with a company local to me but does ship nationally and specially designed theirs dashmats to withstand the sun and heat. Dash covers I think is the name, been a bit since I’ve looked at one of the boxes at work but I love it and it’s great. I don’t have a pic on my phone but I do in my build thread.
  7. Ouch. It should be an AMC35 still. I can’t remember but the differences between the two are subtle. I remember watching a video about it with the guy also working on his Eagle.
  8. Actually I found two issues. The original radiator was more plugged than I expected. I ran the system with fresh stuff twice and the coolant still came out brown. So I said to hell with it, swapped in a new radiator. Made the trans lines play nice with the new radiator without really messing anything up and was still having over heating issues. Except! A twist. Once it got to the 240* line, it actually fought to stay cool and I couldn’t think as to why it was doing this with having the new radiator in. Then it dawned on me. The owner or previous owner changed the hose from the intake manifold to the T-stat out with the wrong hose and it looks like the arch you would find in St. Louis. Basically how it is supposed to operate with the flow is push water through the manifold to the T-stat to open it up sooner than let the water boil in the block. Well the cooling system doesn’t create enough pressure to push the water through that U bent hose to do that. So that being the only thing at this point that isn’t factory leads me to believe this is the last issue and as I removed the hose and found little to no coolant in it and felt the hose to be quit cooler than the rest of the system. Plus it also took the t-stat a long time to open since most the air was hanging around there and not the back of the block as I tried to bleed it all out. So we shall see when the new hose comes in.
  9. Chrysler 9"?
  10. They are discontinued but it looks like a dealer in my state has one.
  11. This one is. Let me see what’s out there.
  12. That’s the lazy route lol. No there’s a few spots that need some new plaster put down so we shall see what ultimately happens.
  13. Oh yeah I forgot to throw in a part number. I’ll get it but something that can happen, if you route the belt the wrong way, there will be a lot of slack. It’s one of those trial and error things.
  14. Hahahaha be my luck I’d break an ankle doing that.
  15. Holy hell does this house aggravate me at times. Today I learned that one circuit(Garage outlet, door opener, guest bathroom, outdoor outlet, outside motion light and probably a couple others)is all on one GFI. Pretty damn dumb and terrible. I hate saying that yes this house was built in the late 70's and completed in 1980 but dammit there was better practices with electrical by then! Also the pool has been drained! Lots to be done in terms or maintenance and making it look nice again. It clearly has been drained prior to me as there is some plaster repair but theres lots more to be repaired than just the first step. Also going to be replacing all the jet gaskets as those have all but disintegrated. I am at the point now where I am locating and eliminating spots where water will leak away and keep constantly filling and ramping my water bill to $500 a month. We did however discover that the autofill has a leak somewhere between the control valve and the floater(kinda like a toilet bowl) where it is just leaking up and out of the skimmer. Have not decided my next course of action but I am gonna get a lot of do it right and professionally the first time if I just leave it. Now here's a pic of the pool drained: Oh I also will be doing an acid wash as well to rid of that rust stain and all the calcium build up.
  16. I actually worked on Chunk this weekend. More or less painting parts but I am working on putting the rear section back together. The body is actually in good shape, some of the floors could use a replacement but I digress. Now I am at a point where I am replacing deteriorating parts unfortunately. Kinda odd but I guess these plastics break down pretty badly. Looks great though!! Little bits at a time.
  17. *X1 TRIM STYLE X1 - CLOTH BENCH -YY 161 Zone 61-Atlanta 1AE Daily Rental 3AG Price Protection - Code G 3XR Daily Rental Purchase 4DH Prepaid Holdback 4EA Sold Vehicle 4FM Fleet Option Editor 4PA Misc Daily Rental W/O Client Code 5AM Largo Tracking 5KN Metro Cars of Detroit ALN APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JGB JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3T STRIPE/BADGE/MOLDING/COLOR KKG LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PY3 QY3 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TMW Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 11/14/88 Body code TM61 Sold by EDD KIRBY'S ADVENTURE CHRYSLER, DALTON GA
  18. *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGW CGY CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGX TRANSMISSION - 3-SPEED AUTOMATIC EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFA ELECTRIC HEATED REAR WINDOW HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED MWA LUGGAGE RACK NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY Build date 6/9/86 Body code JL72
  19. *C1 TRIM STYLE C1 - BENCH SEAT -H9 172 Zone 72-Portland 1AA U.S. Dealer Retail 25C Customer Preferred Package 25C 2TC Customer Preferred Package 2TC 3VN Customer Preferred Discount 4BJ Wheel Credit 4M1 Retail to Bid Diversion Tracking 4UA SCA Tissue North America LLC ALA APA Monotone Paint BAP 75 Amp Alternator BCC Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KER KWR STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PW7 QW7 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TMW Tires TZH Michelin Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build date 9/4/91 Body code JL62 Sold by PONDEROSA MOTORS INC, COEUR D'ALENE ID
  20. *X1 -SA Charcoal 3LY ADL PACKAGE - 4X4 PROTECTION AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black NAA ESA W/CATALYST (EXC CALIF SYSTEM) PS4 QS4 RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 11/8/87 Body code JM61 Sold by LAHTI'S INC, LEOMINSTER MA, still an active dealer. Bought many old parts from them.
  21. *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGX Head Restraints-Outboard Seating, RR DGF H D A904 AUTO TRANS EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MWB SPORT BAR NAE EMISS CONTROL TESTING &&&&&&&& LABEL NFA TANK - 23 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING Build date 5/6/86 Body code JL62 I still see some good stuff including that light blue interior.
  22. Lol all is good, just a comedic nit picker.
  23. Is it bad that I can see you're missing the upper trim piece? Haha looks nice and glad to see you made the move safely.
  24. Does yours have AC or not? I can get you a part number to cross reference.
  25. I have an entire short bed assembly. With powder coated bracket.
