eaglescout526
Administrators
    13
  1. I think it’s vacuum controlled so I wonder if a vac tester can prove that it works. I also have a speedo needle if you need one for the cluster.
  2. Holy fricken crap!
  3. Any XJ from 84-96 will work, you’ll just need to get the Renix era thermistor and push it through the core if you find an HO box. I can walk ya through it.
  4. Sweet!!! I think @carolinajeepman was/is looking for the alt bracket for his set up.
  5. Lock smiths can recode and I learned from one of my coworkers that he does code and recoding of key cylinders on the side. Problem is is that the techs these days don’t get taught everything they should know so something like recoding a cylinder has gone the wayside like tuning a carburetor or simple diagnostics.
  6. Welcome!
  7. Wellllll list on them is $66 but I usually get CC members only a deal for parts. I’ll shoot you a PM and explain so I don’t get a bunch of folks bombarding my inbox.
  8. You won’t believe this. But Chrysler made these caps until 2005. I can still order them actually but they are a pretty penny.
  9. Yup! Was taking another look at all was still good on that MJ.
  10. Such a shame. It still had some good parts.
  11. *X8 Cloth Low-Back Bucket Seats -SA Charcoal 132 Zone 32-New York 1AA U.S. Dealer Retail 5AM Largo Tracking 5KM AMES Department Stores ALM APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMF 4.10 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS EPD ENGINE - 2.5L I4 TBI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3X STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PX6 QX6 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAE TBC Compact Spare Tire TBM Tire Carrier Winch TMW Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z64 Left Front Group XIII Z82 Right Front Spring Group XI Build date 1/27/89 Body code JM61 Sold by SCERBO AUTO CENTER, PARSIPPANY NJ
  12. Both of those numbers are correct. I can also still get them from Chrysler....Kinda for the original number.
  13. Nothin more dumb than entering the MJ world and tossing MJ specific stuff not knowing you can’t get them easily. So all is good there. I think there might be some as NOS out there. Not sure.
  14. Just the mounting brackets for both the alt and the compressor along with the hardware attached. I mean I already have AC but I like having the parts ready and on hand for those in need.
  15. Hahahaha I’m glad you did. Shame it doesn’t have AC but the other two are just as important. Would you mind leaving that pipe that’s in the valve cover already with it? Seems to be something folks are missing. But sounds like a plan. Shoot me a PM and we can work out the finer details.
  16. I definitely need that valve cover. Unless someone else needs it more than me to hoard them. I’ll take the whole TBI too.
  17. Yeah that AC set up scares me a little. Sure 2.5Ls were a bit lawless with how the AC system could be added and theres not much documented info out there on the kits you could get but jeez that set up just gets me.
  18. I’m leaning towards the radiator at this point. I still had air in the main return hose which isn’t till surprising me at the moment so I know what I need to do when refilling the system.
  19. You’ll never be able to find them. Only way is to find them used. A member on here is making them but he’s a one man show with very slow production times.
  20. Maybe a very late replacement model used by AM General until they made the new body style we all know and see every day?
  21. here's what I have learned with the aftermarket scene of mirrors. First: don't. Second: they fit mediocrely, honestly I wish they were better but they arent. I had one that would not stay tight and all because they arenth threaded so they have to be threaded and once theyre threaded and you get them tightened, they love to strip. So honestly if you guys can, get an OEM mirror just because of this. Now granted these will get you out of a pickle if you can't make a run to a junkyard to get one but otherwise theyre crap.
  22. Oh I am absolutely happy with the time I took to source the parts and install it. Actually only took me a weekend to install everything. I had several factors to keep me with the 2.5L. An uncommon engine, everyone swaps to the 4.0L because it’s better, not a lot of knowledge out there and I decided a year into my build to keep my MJ stock so I only stuck to doing things right and the factory way. Overall, keep invested and that little engine will take you for a long time.
  23. Yes, but the vehicle has to have the factory set up as there’s a dealer installed set up as well that looks like a bunch of small bracket pieces cobbled together to have the AC in the system. Unfortunately the catalog I have access to only shows the bracket I have only lets me see vehicles to 84 and it says the bracket was used from 83-90 in the XJ, CJ, YJ and MJ. As long as it’s factory installed, you’ll find the brackets.
  24. Here’s what the AC bracket looks like. It’s missing the rear compressor support piece but I found them at a now defunct Jeep yard.
  25. So it’s a two piece set up. The alt bracket and AC bracket go together. The diagrams I provided show all the pieces you will need for this set up. I had to spend a couple years hunting down my set up. I do actually have the AC portion of the bracket but I do not posses the alt pieces. Now this set up is shared by its cousin, the 4.2L AMC I6 which is kinda nice meaning the parts can be found. Unfortunately the 2.5L is such a hard engine to find accessory parts for because everyone hauled them off to the scrap yard in favor of the 4.0. So finding one fully loaded is a trick. The alt bracket you can possibly get fabricated but the AC bracket can not be.
